1974 Fiat 124 Spider: perpetual project
Discussion in 'Other Builds' started by FiatRunner, Feb 14, 2025.
  1. Feb 14, 2025 at 7:44 AM
    FiatRunner
    FiatRunner [OP] 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Figured I’d post the story of my 1974 Fiat 124 Spider in here. It’s not much of a build, just an ongoing project.
    I was lucky enough to drive around this beautiful Alfa Romeo Spider for most of the summer of 2021:
    I knew I needed something like it for myself. Only issue is that vintage Italian sports cars tend to be pretty expensive, which is a big roadblock for a kid in high school. So I waited for a deal and ended up buying this Fiat Spider in October of 2021:
    I somehow purchased it for $6,000, which is pretty cheap for one of these. A little about Fiat 124s if you don’t know much:
    Designed originally in 1966 and sold until 1984, it’s got four wheel disc brakes, 5 speed transmission with overdrive, independent suspension with coil springs, and most importantly: an engine designed by famous Italian engineer Aurelio Lampredi.
    In the mid 60s, Fiat paid Lampredi to design the “Lampredi Twin Cam”, a competition engine for use in rally cars. However, they ran out of money to design an engine for the road cars. So they just de-tuned the racing engine and stuck it in. Even in the road cars, it’s got dual overhead cams, a timing belt, forged rods, and lots of compression. It was a very high-tech engine for the time, and the car was quite sophisticated too. It truly drives like a modern car.
    Ok, back to my car. I purchased it from the second owner, who had only had the car for 6 months or so. Here’s the story that I have pieced together: the car was purchased new, and driven for about 23,000 miles. Sometime in the 80s, the engine blew up. It was then stored until 2013 when the owner decided to have the engine rebuilt/modified, interior redone, and body painted. The car looked great, but many parts were still original and completely worn out.
    I truly believe that the Fiat 124 is one of, if not the best vintage car bargain right now. They are cheap to buy, cheap to fix, easy to work on, parts are readily available, and they drive much much better than similar MGs or Triumphs.
    Trooper2, shifty`, RealTruck and 6 others like this.
  2. Feb 14, 2025 at 7:47 AM
    FiatRunner
    Jack
    My work started out pretty small. I knew that I wouldn’t have the budget to tackle the big items for a while, but I still wanted to drive the car as often as I could.
    I did a full tuneup. It’s had an aftermarket electronic ignition installed, so really all it needed were spark plugs, wires, and a distributor cap.
    Next it got fluids and filters. You can really tell that it’s a de-tuned racing car when you’re working on the drivetrain. The oil filter is absolutely massive- and the engine holds nearly 7 quarts of oil.
    Shortly after I got it, one of the front wheel bearings got really loose. Turns out that the bearing nut doesn’t use a cotter pin- but the nut gets staked into a key way and isn’t reusable. The nut had been reused and pieces of it came off, ruining the bearings and races. I ended up replacing both front wheel bearings with new seals, races, and nuts.
  3. Feb 14, 2025 at 7:50 AM
    FiatRunner
    Jack
    Lots and lots of little stuff followed.
    New drain plugs, originals were stripped:
    New tie rod end:
    New/used tachometer:
    Somehow the panhard rod got bent? Wasn’t me.
    New steering linkages and other tie rod ends:
    One thing that is impossible not to notice on this car is just how small all the fasteners are. The engine mount bolts are 12mm. The oil pan bolts are 8mm. Biggest wrench I’ve ever used is a 17mm. Everything is tiny. Not weak- just tiny. Engineered very well.
  4. Feb 14, 2025 at 7:53 AM
    FiatRunner
    Jack
    I was able to drive it for a whole spring/summer without needing to do any other work, but the suspension clunks were getting pretty hard to ignore. It also rode like shit and would wheel hop badly if you tried to do any kind of burnout or drift, which was an issue. I was planning on replacing only the shocks and ball joints, but ended up replacing literally everything.
    New control arms, bushings, ball joints, progressive rate lowering springs, shocks, control arm bolts, alignment shims, everything.
    Even though I was very intimidated by the project, it was really pretty easy. You don’t even need a spring compressor if you have a spare jack handy.
    The old bushings were the original 48 year old ones, and pretty shot:
    The difference with the new suspension was staggering. Tuns were sharp, precise, controlled, and F’n fast. No more creaks, pops, or sketchy alignment. But most importantly: the ride quality. It’s really good. Firm- as you’d like it to be, but it soaks up bumps quite well. It got a massive amount of suspension travel, as it was designed to be a rally car after all. Takes our shitty Midwest roads like a champ.
  5. Feb 14, 2025 at 7:54 AM
    FiatRunner
    Jack
    Not long after I replaced the suspension, I started having weird issues with the clutch. Sometimes it wouldn’t return fully, and sometimes it wouldn’t disengage fully, making it really hard to get into gear. It would snap clutch cables frequently too. It turned out that the clutch pedal had bent where the clutch cable attaches, just from years and years of use. (And maybe some aggressive clutch kicks from me. Maybe.)
    I also found that I was missing a spring that attaches to the clutch pedal and not only assists to push the pedal down, but helps return it fully. This spring takes hundreds of pounds to extend, which means I had to get creative to fit it in the car.
    There’s barely any space underneath the dashboard, even for my tiny hands. Picking up that spring with all the washers jammed in it felt like holding a live grenade. Fixing all of that was another immense improvement to the driving quality. The clutch is so much easier to use and I was able to adjust it much better.
  6. Feb 14, 2025 at 8:00 AM
    FiatRunner
    Jack
    By the spring of 2023, I had started to hear a ticking noise coming from the engine. Actually, I had been hearing it since I had purchased the car, but always assumed it was a valve tappet that was a bit out of spec. The guys on the Fiat forum told me not to worry about it, so I didn’t. However, that ticking noise was getting a lot worse. But the really confusing part was that the valves were all very much within spec.
    The ticking noise ended up being the connecting rod bearings. However, this was actually a blessing in disguise. Turns out that the crankshafts on the Fiat Twin Cam engines are nitrided, specifically so new connecting rod bearings can be slapped in. The bearings will wear out long before the crankshaft will get damaged. Racing engine stuff! You can see the heat discoloration on the crankshaft- not from bearing/journal damage, but from the nitriding process.
    Thankfully, I didn’t need to remove the engine to swap out the bearings. I had to remove the exhaust header, intake manifold, and loosen the engine mounts. After doing this I could lift the front of the engine up with a jack, and place a 2x4 between the block and engine mounts. Then I had barely enough room to remove the oil pan.
    The bearings were really, really bad. I can’t believe it was running so well on these bearings.
    However, I ran into an issue when I went to install the new bearings. They didn’t fit!
    This was really confusing as the 1.8L engine only had one crankshaft size- and the 1974 cars only came with 1.8s. Turns out that when the engine was “rebuilt” in 2013, it was actually just replaced with a European-spec 1.6L engine. This is actually a good thing, as the Euro spec motors have more compression, bigger cams, and take to modifications much better than the American spec ones.
    I also repainted the exhaust header and oil pan while they were out.
    After swapping out the rod bearings, I’ve started running Valvoline VR1 20W-50. The original spec calls for 10W-40, so the VR1 isn’t a huge jump. Plenty of oil pressure.
  7. Feb 14, 2025 at 8:03 AM
    FiatRunner
    Jack
    Later that spring I started having issues with the brakes. I was having lots of issues with calipers sticking, or the brakes getting hot. I started by replacing the soft brake lines, which was a major pain since the hard lines were original and pretty stripped out.
    That didn’t work, so I ended up rebuilding the calipers. Super super easy, and I think it cost me $22 to rebuild all four calipers.
    I still was having trouble getting the handbrake to work though, so I ended up buying two reman rear calipers which fixed the issue I think they were like $120 total? Super cheap to fix this car. New handbrake cable too.
  8. Feb 14, 2025 at 8:04 AM
    FiatRunner
    Jack
    Since then, it’s been really quite reliable. There’s always going to be small stuff to fix, I had to replace the transmission output seal, but that cost $11 and took an hour.
    Replaced a tire that had a nail stuck in it. Actually pretty pissed about this one- the nail was from my own driveway.
  9. Feb 14, 2025 at 8:09 AM
    FiatRunner
    Jack
    So yeah, this is where it’s at today:
    I’ve driven it nearly 10k miles, and in the spring and summer I drive it rain or shine. Including the purchase of the car, my total investment has been a bit less than $10,000. That’s excluding gas and insurance, but it gets 23mpg and insurance is super cheap. If you’re willing to spend a couple hours in the garage every couple months, you can stay ahead of a lot of issues and really make it quite inexpensive to own and use.
    I’ll continue to update this thread when it inevitably needs more work. Right now I’m fighting the right side headlight- the low beam doesn’t wanna work.
  10. Feb 14, 2025 at 8:09 AM
    Retired...finally
    KNABORES and FiatRunner[OP] like this.
  11. Feb 14, 2025 at 8:11 AM
    FiatRunner
    Jack
    Heck yeah! Do you have one?
  12. Feb 14, 2025 at 8:31 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Nice rides!
    An old female friend of mine had a Spider Veloce with the straight 6. It was a sleeper for such a little car.
    She had it meticulously maintained at Ferrari of Seattle.
    "Drives like it's on rails" comes to mind. Fond memories driving that convertible around.
    90's era Lotus' would be my choice if I was in the market for a lil' affordable convertible.
    FiatRunner[OP] likes this.
  13. Feb 14, 2025 at 9:38 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Fun ride....you should keep it forever
  14. Feb 14, 2025 at 10:28 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Nice work and a fun looking car.
  15. Feb 14, 2025 at 12:30 PM
    Retired...finally
    Well sorta. My wife's first car was a 124, I bought an 81 Lancia Beta Coupe and put 175,000 miles on it before I gave it to my Stepson, In the year 2000 found an 81 Lancia Zagato in a local junkyard and restored it to show class condition, sold that to help pay for our oldest son's college then finally bought a new 2017 124 Abarth. Put 44,000 fun miles on it before selling it in May '24. It was too difficult for my wife to get in and out after she broke her femur. No we have a BOOORING. Honda Civic. I feel like I need a Groucho Marx disguise when I drive it.
    P.S. Fiats and Lancias have three position headlight switches: Off, Dim and Flicker. All kidding aside, most problems can be traced to body grounds.
  16. Feb 14, 2025 at 12:50 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    What a cool little car! I might have to look around for one.
  17. Feb 14, 2025 at 2:31 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I had a 1980 Spyder 2000, miss that car. So cool.
  18. Feb 14, 2025 at 3:08 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Miss Mitchell my 5th grade teacher in 1975 had one-pea green. It was her baby.
    Your car looks great. I had a GT-6 in my youth so always partial to that big ole 6 in a tiny body
    Enjoy the ride!
  19. Mar 7, 2025 at 3:59 PM
    FiatRunner
    Jack
    Home for the weekend, did an oil change. Been about 18 months, pretty overdue.
    I started it up to get the oil warm, and it had a dead miss on one cylinder. Immediately identified it as cylinder 4- as there was a pool of water around the #4 plug. Turns out that there’s supposed to be a seal at the front of the cowl, and mine is missing. The car sat outside in the rain a couple days ago, and I pushed it back into the garage as I didn’t have the keys on me. That water sitting on the spark plug must’ve killed it.
    Red line is the seal, blue is where the water pools. New seal is on the way.
    The rest of the oil change went smoothly. I run 20W-50, and it gets pretty thick after sitting in the garage all winter. Warmed it up with the space heater.
    I also picked up this Liqui Moly friction reducer while I was at the store, it was on sale. I’ve used their oil and engine cleaning products with great results before, but never something like this. Apparently all it does is add molybdenum (moly) to the oil to reduce friction and decrease engine wear. I ended up not using it- I got kinda spooked as it turns the oil dark gray. I like seeing the condition of the oil based on it’s color. Anyone used this stuff?
  20. Mar 21, 2025 at 4:04 PM
    FiatRunner
    Jack
    Replaced the cam cover gaskets with rubber ones instead of the cork ones that it had. The cork ones didn’t really leak, but they were constantly seeping just a little bit. Hopefully the rubber gaskets will stop the seeping.
    Also replaced the fiber washers that go around the hold down bolts.
    KNABORES and camron1039 like this.
  21. Mar 21, 2025 at 5:24 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Nice! I want a project car when i retire. Was always fond of the TR6 because my mom had one but more spendy and my dad said it was a pain mechanically. This seems like a good alternative choice.
  22. Mar 21, 2025 at 7:43 PM
    FiatRunner
    Jack
    Of course I’m a bit biased- but I truly believe that the Fiat 124 is the best car deal in the country right now. Can’t recommend one enough.
    Let me know if you’re ever in the market- I could put together a buyers guide.
    ACDC2ZZTop[QUOTED] likes this.
  23. Mar 23, 2025 at 8:35 AM
    ACDC2ZZTop
    Travis
    Oregon
    My other dream car would be a 1965 Lincoln Continental. Image is of Dax Shepard’s 1967 and the Matrix 1965.
    FiatRunner[OP] and KNABORES like this.
  24. Apr 25, 2025 at 9:56 PM
    FiatRunner
    Jack
    Over the past few months I’ve been slowly accumulating parts for this car. This summer it’s finally going to receive a lot of attention that it’s needed for a long time.
    First up is a new timing belt. This engine, designed in 1966, was actually the first mass produced car engine to have a timing belt.
    However, it is of an unknown age, and it’s supposed to be changed out every 5 years. It’s probably been closer to 15… so definitely due. Supposedly it only takes 30min.
    Next is the rubber flex joint that connects the driveshaft to the output flange on the gearbox. I didn’t worry about this much recently, until a member of the Fiat forum had his explode while he was on the highway. The driveshaft fell down onto the ground, got caught on a seam in the pavement, and lifted the whole car in the air. Damage to the unibody caused by the driveshaft totaled the car. Not good! Based on my photos from when I diagnosed a gear oil leak, my flex joint has been cracked since late 2021:
    Definitely going to replace it before I take the car on the highway. That driveshaft is spinning close to 5000rpm at 70mph, and is probably 4” from your ass in the seat. I do not want to experience it breaking apart.
    I’d also like to get new tires. I’ve patched two different holes in the current set, and they’re 8 or 9 years old. They aren’t dry rotted or cracked, and they have lots of tread left, but they’re due. The car has aftermarket 15” wheels, which makes tires easier to find. I’m thinking about the Nitto Neo Gen, anyone have a suggestion?
    But none of that is the cool part. See, I’ve done some research and based on the cylinder head and engine block numbers, the engine in the car is a 1608cc Euro-spec engine that came out of a 1973 Fiat 124 Coupe. This is great, as Euro spec motors had more compression, and a square bore and stroke. They also came with more aggressive cams than the US-spec engines, and my car has an aftermarket longtube 4-2-1 exhaust header and full Ansa “performance” exhaust. It should make roughly 120hp, peak power should be around 6000rpm, and it should pull deep into the 7000rpm range.
    However, this is not currently the case. It makes great power and torque at low revs, and pulls strong to 4500ish, but it really falls on it’s face above that. The carburetor that it has on it is a double barrel Weber, and it would’ve been stock for a 1973 USA-spec car, not a Euro spec car. I think it is really restricting the engine at higher RPMs, and it’s a bit finicky in general. It doesn’t idle very strong, the choke makes it too rich, and the vacuum operated secondary doesn’t always work as it should.
    So, I’ve purchased a numbers-matching set of dual Weber IDF carburetors, which would’ve originally came on a Euro-spec car (or a factory rally car!).
    I got them as well as an intake manifold for super cheap from a forum member, as they haven’t been on a running car in decades. They’re going to need a good cleaning and rebuild, but with a harbor freight ultrasonic cleaner, I can do that easily.
    Swapping dual Webers onto these Fiats is a super popular modification, and there is tons of information on them out there. They’re also very popular with the VW beetle/bus community. I’ll be able to get the engine tuned very well, much better than the current setup.
    I’ve spent a ton of time compiling a list of every single little part I’ll need. All in all it’s going to cost around $1000, which is a pretty good deal to me, considering how much the driving experience is going to improve.
    It’s going to make slightly more power, be much more responsive, start easier in both hot and cold weather, sound way cooler, and be infinitely more tunable than the current setup. It’ll also delete the hodgepodge of emissions stuff, which will clear up some space in the engine bay.
    I’ve already bought a ton of parts. Rebuild kits, gaskets, jets, venturis, all sorts of stuff, and I still need a lot more.
    I really can’t wait. Look at how much fun it's going to be: https://youtu.be/Vo_xSa6ojdY?si=GbkNWKASUmMSo-VP&t=844
    I’ll be updating this thread as the project progresses.
    shifty`, w666, rock climber and 2 others like this.
  25. May 4, 2025 at 10:38 PM
    FiatRunner
    Jack
    Got to spend a few hours at home this weekend cleaning and rebuilding the new dual carbs.
    It was obvious that they hadn’t been run in decades:
    The ultrasonic cleaner I got from harbor freight worked really well. This was after just one 10 minute cycle:
    I used warm water and some pine sol, and I didn’t run them for too long. I know that I could’ve kept them in there a bit longer and made them squeaky clean, but that would make the rest of the engine bay look bad! I think they still turned out pretty nice though.
    Rebuilding them was really pretty easy. They got new needles and seats, gaskets, floats, diaphragms, and all sorts of different jets. Lots of good youtube tutorials. The left (rear) carb is missing the lever for the cold start enrichment system, which might be a bit pricey to find on its own. Most people block off that system, but most people with dual carbs only use them during warm weather.
    KNABORES, rock climber and shifty` like this.
  26. May 24, 2025 at 9:54 PM
    FiatRunner
    Jack
    Waxed the car for the first time in my ownership today.
    I liked the Adam’s Graphene Wax so much when I used it on the Tundra that I figured I’d use it on the Fiat. The paint really isn’t that good- the clearcoat is chipping in a bunch of spots, there’s wet sanding marks everywhere, and I honestly haven’t put that much effort into keeping it nice. But the difference the wax made was shocking. There are so many swirls and marks and shallow scratches that the wax pretty much made disappear.
    I really like now nice it makes water bead off the paint.
    Sirfive, KNABORES and mountainpete like this.
  27. Jun 8, 2025 at 10:23 AM
    FiatRunner
    Jack
    Noticed a squeak from one of the brakes when turning left. Found the drivers front wheel bearing to be a tad loose.
    Just tightened it up a bit. I redid these bearings sometime last year and they must’ve worn in.
    Put on a new dust cap because I had a spare. Took 20 minutes and now I have confidence that the front wheel bearings won’t come apart while I’m driving. (Which has happened to me before)
    KNABORES likes this.
  28. Jun 9, 2025 at 9:31 PM
    FiatRunner
    Jack
    The gas tank started leaking again, this time really bad. I filled it up yesterday morning, and it probably leaked out a gallon by the afternoon.
    I’ve patched the gas tank before, there were two pinholes, and I patched it with JB weld TankWeld. It worked for one of them, but not the other. So this time I scraped off the JB weld and stuck a sheetmetal screw in the pinhole. Then I put more JB weld on it.
    I also discovered that the gauge sender is original. This script on the rubber hose means it’s from the factory. I siphoned out the gas via the hole for the sender.
    A new tank is $220, but I don’t feel like spending that. I think that if I have to patch it one more time, I’ll replace it. It wouldn’t even take that long to
  29. Jun 10, 2025 at 7:03 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Why so many hoses?
  30. Jun 10, 2025 at 9:16 AM
    bfunke
    bfunke Tundra Curmudgeon
    Looks like the Rock sells gas tanks for it
