Reverse Lights not working
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Akry21, Feb 11, 2025.
  1. Feb 11, 2025 at 3:24 PM
    Akry21
    Akry21 [OP] New Member
    Trying to figure out an issue with my reverse lights not coming on. Replaced bulbs, checked fuses…
    From what I have been looking into it seems to potentially be the back-up light switch on the transmission or the neutral safety switch. Curious if anyone has had this issue before, it’s a 2011.
  2. Feb 11, 2025 at 4:06 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    For future reference here are your wiring diagrams if you ever need them.
    Ultimate SEQUOIA Wiring Diagrams Collection | Toyota Tundra Forum
    Did you check the relay?
    Did you test and see if there is power sent to and from the park/neutral switch when in reverse with your DMM?
    Pin 1 lilac/ w red stripe wire, should be hot when in reverse with the ignition on.
    Pin 2 green wire to the switch from the battery, should be hot with the ignition on.
