Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Feb 10, 2025 at 1:58 PM
    #271
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    2013 Crewmax sr5 4x4
    Interior led, reverse led bulb
    Does that matter for which scanner I have? I have the Creader elite this one.
    https://www.amazon.com/dp/B0CDPKN3X4
  2. Feb 10, 2025 at 2:03 PM
    #272
    AZBoatHauler
    So.Arizona
    Which scanner you use makes no difference as long as it can perform the reset.
    Hbcon20 likes this.
  3. Feb 10, 2025 at 2:07 PM
    #273
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    OK thanks. I’ll let my gauge get down to about 3/4 I’ll do the reset and then fill up the remaining of the tank with new regular 87. Then I should be good? I’m new to tundras and especially flex fuel trucks lol sorry for all the questions
  4. Feb 10, 2025 at 2:45 PM
    #274
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    What scanner did you use?
  5. Feb 10, 2025 at 3:01 PM
    #275
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Is “learning” the same as reset?
  6. Feb 10, 2025 at 3:01 PM
    #276
    AZBoatHauler
    So.Arizona
    Yes
    Hbcon20[QUOTED] likes this.
  7. Feb 10, 2025 at 3:05 PM
    #277
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    did you reset/relearn? Add gas, then just drive normal. Then check it again later for the alcohol %?
  8. Feb 10, 2025 at 3:09 PM
    #278
    backcountryj
    backcountryj New Member
    GA
    2016 Crewmax
    All I have to do is crank my truck to move the gauge.
    Florida AF and Hbcon20 like this.
  9. Feb 10, 2025 at 3:09 PM
    #279
    Timwfm
    Timwfm New Member
    On mine, there a special function option then select Fuel Density value reset (But just turn the key to on and not start the engine). Try that to see if it reset 20250210_180402.jpg 20250210_180420.jpg
  10. Feb 10, 2025 at 3:16 PM
    #280
    RobertD
    Robert
    DFW, Texas
    I missed the official process. I reset, drove 2 miles, got gas, and then drove. Truck still runs much better but I am planning to run the reset again when I have some gallons of gas in a jug or I'll just take my scanner with me to the pump since it doesn't take long to run.
    Hbcon20[QUOTED] and Timwfm like this.
  11. Feb 10, 2025 at 6:53 PM
    #281
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Same one you posted you have
  12. Feb 11, 2025 at 5:43 AM
    #282
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    is that the Creader elite scanner?
    Whizzit and Timwfm[QUOTED] like this.
  13. Feb 11, 2025 at 7:09 AM
    #283
    Timwfm
    Timwfm New Member
  14. Feb 11, 2025 at 8:00 AM
    #284
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Timwfm[QUOTED] likes this.
  15. Feb 13, 2025 at 7:23 AM
    #285
    tbmastermind
    tbmastermind New Member
    Great post here. I was having this same issue with my 2015 Tundra that now has almost 200K miles. The dealership gave me the same spiel and were quoting me $1688.75 to perform TSB0166-19, reprogram ecm, replace fuel pump and perform fuel alcohol value relearn. I asked them if they could just perform the fuel alcohol relearn and skip the other stuff and they said no and wouldn't budge on that (probably cos it wouldn't make them any money).
    Anyways, I found the Launch X431 2025 Launch reader Elite OBD2 Scanner for Toyota Lexus on Amazon for $130 (is back to full price of 170 now). I ran the updates when I received the tool and then was able to read the Alcohol Fuel Density Level that was also 85% on mine (I had also seen this at the dealership). I followed the same steps in this post to then perform the relearn and my truck started right up, drove it around for a few miles (its currently 5 degrees in Kansas City - very cold) and I rechecked the levels and still at 0% and my truck is running like a chump!!!
    Thanks again for this post that helped. I'm happy with the results.
    B.Ross, MatD13, Hbcon20 and 3 others like this.
  16. Feb 13, 2025 at 10:26 AM
    #286
    Timwfm
    Timwfm New Member
    Heck yeah
    Whizzit likes this.
  17. Feb 13, 2025 at 1:35 PM
    #287
    Appleju
    Appleju New Member
    Hey quick question. I got the big Launch X431 to fix this issue a few months ago, and I hated that it had a one year subscription that would have to be renewed to keep using it, so I went ahead and returned it on Amazon. Well the issue has come back and I want to try this Creader Elite, does it also have a subscription that will expire or is it something I could leave in my truck for years and pull it out if I ever run into this issue again?
  18. Feb 13, 2025 at 2:18 PM
    #288
    Ericsopa
    Ericsopa Old man and the sea
    According to the description on Amazon, it's free lifetime wi-fi updates for the Toyota or Lexus vehicles, but also can be used on other brands when you download the other vehicle brands and that download is for one year free, after which there appears to be a subscription price. But if using only the Toyota/Lexus functions it's free for life. (but you know how that sometimes goes.....)
    Whizzit and Hbcon20 like this.
  19. Feb 13, 2025 at 6:09 PM
    #289
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Can the scanner be used to check other vehicles check engine lights? My wife’s got a 2011 Honda Pilot.
  20. Feb 13, 2025 at 6:15 PM
    #290
    RobertD
    Robert
    DFW, Texas
    Don't buy the Toyota/Lexus one then
    Either go universal or buy 2 (one for Toyota/Lexus and the other for Honda)
  21. Feb 13, 2025 at 7:06 PM
    #291
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    I had to buy the Toyota specific one to reset my alcohol density. So I was just wondering if it could read other car obd2 codes. Thanks for the advice.
  22. Feb 13, 2025 at 7:10 PM
    #292
    RobertD
    Robert
    DFW, Texas
    Sadly, I don't think it will work for her Honda but I'm by no means 100%. Just based on how this one is listed for Toyota/Lexus only and their other ones were for specific manufacturers makes me think they only work for the ones they have listed.
  23. Feb 13, 2025 at 7:22 PM
    #293
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I have had three flex Toyotas now and have never had this problem. I still bought the scanner just in case.
  24. Feb 13, 2025 at 7:47 PM
    #294
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Another success story with the
    LAUNCH Creader Elite Bi-Directional OBD2 Scanner for Toyota Lexus, 2025 Full System Diagnostic Scan Tool, All Reset Service Code Reader, ECU Coding, Battery Registration,AUTO VIN,Lifetime Fr-ee Update https://www.amazon.com/dp/B0D176ZCXQ
    Had the TSB and a fuel pump replacement 3 years ago. Started having the slow starts last winter. Bought the tool and reset last week following all the advice in this thread.
    This week freezing temps, no issues. Problem solved. Great thread!
    Whizzit, Timwfm, MatD13 and 2 others like this.
  25. Feb 14, 2025 at 4:22 AM
    #295
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    The Launch Elite will do global obd2 like any other basic scanner and will pull global obd2 codes from the Honda.
  26. Feb 15, 2025 at 3:05 PM
    #296
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Finally got around to running the procedure. Alcohol at 0% now.
    Thank you, everyone.
    kbahus and OldGuy03 like this.
  27. Feb 25, 2025 at 9:41 AM
    #297
    jsloden
    jsloden New Member
    Ok, apparently I'm pretty dense. I created an account just so I could ask a question. I can't get this to work. I have a 2012 FF sequoia. Ordered the tool c reader elite T, did all of the updates, followed the directions about how to get to the alcohol content reset. The problem I'm having is after that. I drove to the gas pump, with the key on did the reset and it said compl, left the key on while I filled up with gas, I think I messed up when I got back in the car I turned the ignition switch of and back on. After that it said incompl so I just unplugged it. I then drove for about 15 minutes and checked the density when I got home and it was still at 75%. I read through this entire post and didn't see explicit instructions on how to do this part of the procedure. Should I leave the key on the whole time? Turn it off and then back on? Leave the scanner plugged in the whole time? Any help would be greatly appreciated.
  28. Feb 25, 2025 at 7:30 PM
    #298
    BluegrassRules
    BluegrassRules New Member
    Justin
    2017 TRD Pro white
    17 Pro 38gal/flex was down for the last few months while trying to find a fuel pump. 2000 plus OEM fuel pumps are backordered at the moment through Toyota, according to Joseph Toyota in Cincy.
    My truck was a crank/no start after a few months of hard starts. We were having some very cold temps here, and I wasn't aware of the flex fuel issues with these trucks until I had the crank/no start, so I figured it was just cold temp related until it wouldn't start at all. I figured the fuel pump was dead, so I'd been trying to find one at a good price. Didn't need the truck repaired in a hurry, so I let it sit, unable to start.....until
    I figured I'd go ahead and buy my own OBD2 scanner and give it a go, since the dealerships wanted around $500-600 to do the fuel density reset/ecm flash. I thought I'd buy a scanner and do it myself, especially after reading how the issue eventually pops back up later after the reset. I bought a TOPDON Phoenix Nano on Amazon to do the fuel density reset, and my truck started right up. No hesitation, no rough idle...started like it was new, and feels like it runs a little better on the road with slightly increased fuel economy(went from 13ish to just under 15). When the Nano came in, I charged it and ran the updates, then took it out to the truck to start the procedure. All of that took about 30 minutes. Very easy to do.
    Thanks to everyone on here for all the info about this issue... it helped me tremendously!
    Cheers!
    ohsandy, Whizzit, Timwfm and 4 others like this.
  29. Feb 26, 2025 at 8:32 AM
    #299
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    thanks @lowercaseg for starting this thread and sharing!
    i own a 2017 SR5 FFV and was curious what my alcohol density was (i don't run E85 ethanol personally).
    i purchased a 2025 LAUNCH Creader Elite off eBay the other week. all in all, it's decent although updating firmware is a bit wonky.
    one thing i noticed is it shows my vehicle as a TRD Pro when using the VIN auto-detect:
    my truck is NOT a TRD Pro. anyone else notice this? not sure if it really matters but figured i'd ask here.
    thanks again for all the useful info everyone's provided in this thread :thumbsup:
    Timwfm likes this.
  30. Mar 6, 2025 at 8:20 PM
    #300
    Florida AF
    Logan
    North Florida
    Just got home from being out of town for work... I am 99% sure I need to address this now.
    Anyone in Gainesville/Trenton/Newberry or Pinellas County that has one and can help a member out? I will most likely order the elite if not so I can do this, but hoping to save a couple bucks.
    Lastly, there is an in town shade tree mech I may swing by and bring a gas can.
    Timwfm likes this.
