General Supercharger Thread
  1. Feb 8, 2025 at 1:38 PM
    SLOWER
    SLOWER New Member
    I’ve only got a few hundred miles on my SC, but man is it fun. Dyno results were 446/376 up from 293/251. Truck is a 2020 with 58k miles.
    The wife talk is hilarious. I ended up with the SC after she saw me watching YouTube vids. “Why don’t we have that?”
  2. Feb 8, 2025 at 2:53 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    When opportunity strikes...pounce.
    bflooks and Tripleconpanna like this.
  3. Feb 8, 2025 at 3:52 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Before I started tuning, I installed an SC for a customer, and they failed to follow directions to get the tune downloaded in time. They wanted to go ahead and drive it home, bout 2.5hr drive. So I told em keep rpm low and def under 3k. They had zero issues. If you want to send me a log, I can take a look for n the morning after I walk the dogs. wehlinc@live.com
  4. Feb 8, 2025 at 3:55 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    When I was doing gear installs, Tundra 4wd was $1600 labor basic install. Just cuz that 10.5 is so damn heavy, and the 9” big pinion race is nerve racking install.
  5. Feb 8, 2025 at 4:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I deleted the 9 inch diff pinion head shim under the race. I just shimmed under the pinion head bearing. So much easier.
  6. Feb 8, 2025 at 4:15 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    That’s what I would do as well. So much easier just getting that race in once.
    Mdl[QUOTED] and NatesNightMare like this.
  7. Feb 8, 2025 at 4:27 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    well heres to hoping ive got an affordable shop. not much to choose from here lol
    maybe ill do rear first then front later since as ive mentioned before, i rarely use 4x :notsure:
  8. Feb 8, 2025 at 4:49 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Logs sent, thanks!
    There is a tune currently, it is for the old 143k motor with 2.3" pulley & FIVE-0 650s & now it has a 70k motor with 2.2" pulley & PS 750s.
    I'll most likely wait until next week to avoid issues, I feel bad, the engine builder has wanted it gone for 3 weeks.
  9. Feb 8, 2025 at 4:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He needs his injector constant/offset changed which affects the MAF/timing/PE. Well...you know.
    The ECU is compensating on the difference in IC, fuel trims but needs to be addressed.
  10. Feb 8, 2025 at 5:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Forgot @snivilous is at KOH.
    HulkSmurf14 likes this.
  11. Feb 8, 2025 at 6:08 PM
    e30cabrio
    Yup, the shop picked a bad week to finally give me back the tree. :p
  12. Feb 9, 2025 at 10:17 AM
    e30cabrio
    No codes this morning, it shifts well, shifts into 4LO/HI/ 2WD. I'm afraid they didn't fill the transmission properly. What is the best way to verify the ATF fluid level?
    Ponderosa_Pine likes this.
  13. Feb 9, 2025 at 10:28 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    This is the official procedure, although you can skip the check mode and verify temp with a scan tool, after procedure add 1 qt.
  14. Feb 9, 2025 at 10:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Others may differ.
    Level ground. Pin thermostat, start, run through all gears, at 100 deg pull check and look for a light stream not a dribble. If nothing add a 1/2 to quart, cool down and repeat.
  15. Feb 9, 2025 at 11:12 AM
    Saltyhero13
    Wish we could pin posts in this thread.
    Mdl, Ponderosa_Pine and e30cabrio like this.
  16. Feb 9, 2025 at 11:14 AM
    e30cabrio
    Thanks, gentlemen!
    armyoffoo and Mdl like this.
  17. Feb 9, 2025 at 11:35 AM
    bflooks
    bflooks New Member
    Metrowest MA
    So, what ended up being the final problem? The injectors or an O2 or both?
    e30cabrio, HulkSmurf14 and Mdl like this.
  18. Feb 9, 2025 at 11:49 AM
    e30cabrio
    If I believe them, injectors solved the misfire & it needed a new O2. I said I'd deal with it, & ordered an O2 from NAPA, it was for the right side so would not connect so I cleaned the one I had & that solved the O2 issue.
    I am 99.9999999% certain they fixed the wire(s) they broke but refused to admit breaking them.
  19. Feb 9, 2025 at 11:50 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hey, I forgot that the prospeed 750 injectors are really 715cc, according to @snivilous. So go from 650 to 715 is what 10% increase and Viktor told me the ECU can handle up to a 10% difference in fueling. Just thought to let you know that.
  20. Feb 9, 2025 at 11:51 AM
    e30cabrio
    am I better off with the PS or should I have the 5-0's reconditioned & use them?
    Mdl likes this.
  21. Feb 9, 2025 at 12:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'd stick with the PS for the power your at. Once your tune is adjusted your injector duty cycle will be good. I've been dealing with occasional extended starts, 5-O 750's. It starts on 2nd cycle when it happens. It's just annoying.
    e30cabrio[QUOTED] likes this.
  22. Feb 9, 2025 at 12:38 PM
    e30cabrio
    Thanks, my DS were crazy low per Sniv with the 5-0's.
    We'll see what Sniv sees when he looks at the logs.
  23. Feb 9, 2025 at 1:11 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I just had a customer send me his injector info for the PS 750s and they were measured at like 690cc lmao. Prospeed REALLY rounding up on their claims. Hell even injector clinic or whoever they get their shit from says 725cc and that's already rounded up from every spec sheet flow test I've seen.
    reywcms, Saltyhero13, Wynnded and 3 others like this.
  24. Feb 9, 2025 at 1:40 PM
    e30cabrio
    This is what Army sent me on the injectors I got.
    Mdl likes this.
  25. Feb 9, 2025 at 1:52 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    FYI, Those cleaning before/after numbers are at 43.5PSI, and the paperwork that came with the injectors had deadtime settings for FID700's. PS claims they are 750cc, but they only flow that much if they have 60PSI of pressure.
  26. Feb 9, 2025 at 2:32 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s crazy, so really they don’t have much capacity advantage to DW 650s which are rated at 43.5 psi?
    @TurboKits are your 880cc injectors rated that at 43.5psi?
    HulkSmurf14, e30cabrio and Mdl like this.
  27. Feb 9, 2025 at 2:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Their site only list the offset and not flow. One thing I like about the 5-0 750's is they flow that at 43.5 psi on up to 880cc at 60psi. But they are tempermental.
    e30cabrio and Silver17[QUOTED] like this.
  28. Feb 9, 2025 at 3:02 PM
    snivilous
    SW UT
    Coincidence that the TurboKit injectors and the 5-0 are both rated at 880cc? Seems like an oddly specific number to get repeated across manufacturers.
  29. Feb 9, 2025 at 3:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    But the turbokits 880's could be rated higher at as fuel psi increases. I'm sure he'll post the data. I guess with my recent purchases I could of picked up a set of 880's instead but decided to deal with occasional extended starts with the five-O's.
    e30cabrio likes this.
  30. Feb 9, 2025 at 3:12 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    My PS “750” injectors are about 726 average. It’s like when you’re 6’2 but in the WWE you’re 6’5!
    Tripleconpanna, Mdl and armyoffoo like this.
