285/75/17’s anyone?
Discussion in 'Wheels & Tires' started by DMB4x4, Mar 11, 2019.
  1. Aug 10, 2022 at 8:55 AM
    #61
    Pman432
    Pman432 New Member
    Jon
    2016 Tundra Platinum
    SB gen1 RTT, RCI HD 18”, OME 612, Method 316, TOYO AT3
    Nice. How often are you getting your alignment done? I just started running the same setup as you except +25 offset M316’s my bad for all the questions
  2. Aug 10, 2022 at 9:04 AM
    #62
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I grew up in Monroe!
  3. Aug 10, 2022 at 12:11 PM
    #63
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    All good!
    I bought the Firestone lifetime alignment so I just swing in every 6 months or so for a check and tweak
    Pman432[QUOTED] likes this.
  4. Aug 18, 2022 at 6:46 PM
    #64
    Pman432
    Pman432 New Member
    Jon
    Im sitting on these alignment numbers… looks pretty good to me on the stock UCA’s. Still gonna do SPC’s soon though.
  5. Aug 23, 2022 at 4:52 PM
    #65
    M13tundra
    M13tundra New Member
    Icon 17" bronze rebounds with 285/75r17 toyo at3s. Toytec eibach kit with JBA UCAs. I trimmed the skid plate and removed the front mud flaps just in case prior to install. No rubbing. Love the setup.
    mayan, equin, Pman432 and 1 other person like this.
  6. Aug 23, 2022 at 6:05 PM
    #66
    Pman432
    Pman432 New Member
    Jon
    Method 316, 285x75r17 toyoAT3, OME Nitrocharger front/rear
    mayan, KWC and equin like this.
  7. Aug 15, 2023 at 12:03 PM
    #67
    WaTrout88
    WaTrout88 Toyota Family
    Ben
    Spokane, WA
    1978 FJ40, 2002 Tundra TRD, 2018 Tundra
    2002 Toyota Tundra - Billy's 5100 2nd Notch, 285/75/16 OEM Wheels + 1.5" Spacers, Archive Garage HD Leaf Springs, AG Bump Stops, Freedom Offroad UCAs, ARB Coil Springs 2887
    I am due for some new shoes on my 2018 Toyota Tundra this fall. Currently running 35x12.5x17 but thinking about switching over to 285/75/17. I have always thought 12.5 is too wide for the driving I do. It will be a slight downgrade on size width by about 1" and height by about .6". Also, hoping to pick up a bit of MPG. Any thoughts on this? I always lean towards BFG KO2s but I am considering the Toyo
    AT3s as well.
  8. Aug 17, 2023 at 4:37 PM
    #68
    M13tundra
    What size lift are you running? I have a 3” front and 1.5” rear with the 285/75/17s At3s. Smooth ride and gas mileage is the same as stock. I will say they look a little small. Overall though it’s a great setup.
  9. Aug 18, 2023 at 7:44 AM
    #69
    WaTrout88
    Ben
    Spokane, WA
    I believe I have about a 3" lift to fit the 35s but the guys that I bought it from, bought it off the showroom floor with it already lifted so I am not exactly sure what was done. Billy's 5100 from what I have seen. Awesome to hear you are getting similar MPG as factory, I have been running about 14 mpg on average currently.
  10. Nov 23, 2023 at 1:47 PM
    #70
    brkncly
    brkncly New Member
    Oregon
    What is the offset & back spacing on your wheel?
  11. Apr 8, 2024 at 10:34 AM
    #71
    ardnut5102
    ardnut5102 New Member
    Mine are running on 285/75R17 Yokohoma Geloander AT G015 with Method 314 on +25MM offset. Have RCI skid plate. Has rubbing with full turn on the back mudflaps but will probably remove or install aftermarket mudflaps. I did remove the front mudflaps. Discount Tire had them on 45 PSI but adjusted between 35-40 PSI rides better for me. Has Bilstein 5100 front and back on the highest setting.
    mayan likes this.
  12. Dec 12, 2024 at 8:12 AM
    #72
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    Anyone confirm if the 285 75 70s will work with stock suspension? Reading through the thread it seems like most of you are running some type of level or lift.
    Plan is to run Method 316s with +25 offset and the Toyo OC AT3s.
  13. Feb 1, 2025 at 9:39 PM
    #73
    mtb_ripster
    mtb_ripster New Member
    2017 Tundra DC
    Bump because I have the same question.
    I have Method 703s +35, would like to run wildpeaks or k03s, hoping to stay on the stock suspension if possible and also be able to store the spare underneath in the normal location.
  14. Feb 8, 2025 at 8:11 AM
    #74
    danb
    danb New Member
    Minnesota
    I threw on the combo you quoted and it works great. Had to remove the front air deflectors on the front wheel wells and push that area in about an inch with a heat gun, but no rubbing now. Took maybe 20 minutes with the gun and checking by myself. Pic has the deflectors on but gives an idea
    mayan likes this.
  15. Feb 8, 2025 at 8:37 AM
    #75
    mtb_ripster
    2017 Tundra DC
    Awesome, thanks for the reply. Truck looks great. I am trying to decide between 255/80/r17 e rated or 285/75/r17 which have a c rated option. I'd prefer the pizza cutters for gas mileage and snow performance but I'm nervous about ride quality with the e rating.
  16. Feb 8, 2025 at 8:44 AM
    #76
    danb
    danb New Member
    Minnesota
    Thanks man. C rating is plenty for the trucks. I get about 13mpg with winter fuel right now, hoping it goes up with summer blend. I went with the Toyos because they weigh a lot less per tire than the Wildpeaks. I wasn't a big fan of the KOs when I had them an F350 few years back. Lot of people run the Toyo here in Minnesota because they do great in the snow, dont weight a ton, and road noise isn't super loud. I might run the Michelin Defenders once these wear out because I think they're probably the best all around tire out there, I dont do hardcore offroading.
  17. Feb 12, 2025 at 8:25 AM
    #77
    brent.ff
    brent.ff New Member
    Anyone got 285/75/17s on a third gen with no lift?
