First time oil change at home
Discussion in '2.5 Gen Tundras (2014-2021)' started by 478 tundra, Feb 7, 2025.
  1. Feb 7, 2025 at 6:59 PM
    478 tundra
    478 tundra [OP] New Member
    Lol I would love to but oil definitely needs to be changed before that. Never been in Louisiana other than driving through when we went to Arkansas last year. That small part I saw was very beautiful and interesting. Interesting part was I saw a dead alligator on the side of the interstate.i assumed someone ran it over. I told myself this got to be only in Louisiana. Shortly after coming back to ga the small town next to mine had an alligator stopped the whole traffic on I75 lol
    Fotnot[QUOTED] likes this.
  2. Feb 7, 2025 at 7:58 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Do you have a door for the filter? Longest part of the oil change for me is taking the skid plate on and off.
    Haha yeah I'm 155, I can slide right under, it's a little tight but just easier than dragging out the jack and stands. I won't use ramps anymore since I redid my driveway.
  3. Feb 8, 2025 at 12:07 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Shoooooorter drive. I'm even closer in central Bamaland (Hoover, just south of Bham). Come on by. I've done over two hundred engine oil changes in my garage and driveway.
  4. Feb 8, 2025 at 12:09 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    There's a diagram on the side of the Mama Toyota oil filter box that shows you where to install the O ring. AND shows you where NOT to install it!
  5. Feb 8, 2025 at 4:12 AM
    478 tundra
    Lol yes I wish I was 155. I'm pushing 290 right now. No I don't have a door on skid plate. I need to go ahead and take it off. In the future I'm thinking about investing some after market skid plate to avoid taking it off every time
    Joe333x[QUOTED] likes this.
  6. Feb 8, 2025 at 4:26 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    RCI skid. Get it when they do a 20% off deal, fairly often.
    https://rcimetalworks.com/product/07-19-tundra-engine-skid-plate/
    250000yota likes this.
  7. Feb 8, 2025 at 4:55 AM
    478 tundra
    OHwendTrd[QUOTED] likes this.
  8. Feb 8, 2025 at 4:59 AM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Is one still able to get to the pool drain plug with the RCI skid plate? I see the little door to get to the filter, but not the drain plug :monocle:
  9. Feb 8, 2025 at 5:01 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Yes, zero access problems. Purpose of the V cut. Now, you may have to remove during your front differential OCI.
    20manny1996[QUOTED] likes this.
  10. Feb 8, 2025 at 5:03 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Rci does not cover up the drain plug. There’s no need for door.
  11. Feb 8, 2025 at 5:03 AM
    20manny1996
    Manuel (Manny)
    In that case, I'll add it to my wishlist as well :D
  12. Feb 8, 2025 at 5:06 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    OP @478 tundra
    While you're at it. Consider adding other routine DIYs. My personal schedule (others may weigh in, personal preference, etc.):
    Oil & Filter: 5k miles or 6mo. -- Pennzoil Ultra Platinum 5w-30
    Transmission Fluid (drain/fill): 30k or 6yrs. -- OE Toyota Brand.
    Coolant: 50k miles or 5yrs. -- OE Toyota Brand.
    F/R Differential: 30k (OE or aftermarket). -- 75w-90 Amsoil Severe Gear
    Transfer Case: 30k (OE or aftermarket) -- 75w Ravenoil
    Power Steering Fluid (OE or aftermarket Fluid) -- OE Toyota Brand.
    Brake Fluid DOT 3, inspect at 3 years (aftermarket)
    Sparks Plugs: 120k (OE)
    Edit: most of what I typed up here are the recommendations of Car Care Nut (youtube)
    WILLINH and 20manny1996 like this.
  13. Feb 8, 2025 at 5:07 AM
    BrandonL812
    Brandon
    Talon2006 and 20manny1996 like this.
  14. Feb 8, 2025 at 5:49 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    No door ... stole this picture off the internet.
    I also put 1 sheet of pig mat on top of skid plate to catch the drips when removing filter.
  15. Feb 8, 2025 at 5:58 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    X2 on Talons skid plates
    Plus he's here active on the forum for any questions...
    @Talon2006
  16. Feb 8, 2025 at 7:29 AM
    Joe333x
    Joe333x Member
    Boston
    Interesting! So you can get the housing off from the side?
  17. Feb 8, 2025 at 7:44 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Yup, unless Conan the Wrench Man put it on last.
  18. Feb 8, 2025 at 11:11 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That’s what I do too with the motiv x kit. I leave the skid plate on and just get the filter off from the side and attach the drain hose and let it flow. So much easier than removing the annoying black factory plate.
  19. Feb 8, 2025 at 11:44 AM
    Joe333x
    Joe333x Member
    Boston
    Going to give that a try next oil change
  20. Feb 8, 2025 at 11:49 AM
    #50
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    Have a breaker bar ready in case the dealership monkeys overtorqued the filter housing.
    WILLINH likes this.
  21. Feb 8, 2025 at 4:35 PM
    #51
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I'm 6'2" 285lbs. I can easily fit under my sr5 2wd and change the oil.
  22. Feb 9, 2025 at 4:04 AM
    #52
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    And it has enough hose to cut a piece and use on a Fumoto if you get the one with short nipple. I keep large pieces of cardboard in my garage for oil changes. I have 2x6s doubled up that I drive truck onto. The extra 3" works fine for me but also have 2" lift on front. The oil drain is on back of the pan so elevating the front probably helps when draining it.
    RobertD[QUOTED] likes this.
  23. Feb 10, 2025 at 11:35 AM
    #53
    Rlachermeier
    Rlachermeier New Member
    Randy
    2019 Toyota Tundra Crewmax Platinum Edition
    Good idea. I know the manual on mine says 8.5 quarts but 8 always fills it. And I do replace the filter every time.
  24. Feb 10, 2025 at 1:11 PM
    #54
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    That’s how mine is. Many have suspected Toyota started recommending 8.5 whenever they changed the OCI to 10k
    Rlachermeier[QUOTED] likes this.
  25. Feb 10, 2025 at 4:45 PM
    #55
    478 tundra
    Thank you for the info. Right now I'm at 28k and will do rear diff and transfer case drain and fill next.
    I'm not much different than you are. I'm 6'3'' 290lbs. When I lay under my truck from whatever side front or side my chest barely clears the bottom and my arms definitely not comfortable to do any kind a work lol.
    Definitely who tightened up my filter housing...
    I wanna thank you all for all the messages and great knowledges y'all share with me. I did my oil change and everything went smooth until it was time to take filter housing off. With motivex tool and 24'' ratchet and another 18" pipe attached to end of it finally gave up and break lose. I really surprised that they didn't break the housing. Replaced filter and installed it back of course did not torqued that much lol. Drained from filter and pan around 8-8.2 quarts of oil. Installed fumoto valve and add 8.5 quarts of oil. Fired her up and let it run couple minutes. Checked under the truck where valve and filter is. No leak seen. Turned it off and installed skid plate. Found out dealers service tech broke one of those plastic tabs that screws goes into at last oil change. Only 2 screws was there. One of the biggest reason I stopped going there. But finally take her out to drive and parked on a flat ground. Check the dip stick after couple minutes. It was right at the full dot. Everything went pretty good with y'all info. I greatly appreciate it.
  26. Feb 10, 2025 at 6:19 PM
    #56
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Dealership left 1 bolt out of my skid and 1 other was not the original bolt. Gave them a 0 on survey and service manager called me. He ordered 2 new bolts. When I picked up he said "do you want them installed". I said hell no will do it myself.
    TacomaTRD4x402 likes this.
  27. Feb 10, 2025 at 6:32 PM
    #57
    478 tundra
    They didn't called me yet to setup my service appointment. They should call soon. I'm gonna tell them why I quit taking my vehicle to them. Will it change anything? Probably not but at least I feel better about it. I totally understand they rushing this techs or tech just don't care. I wish they just let me know and ordered the part to fix it instead of I found out myself almost 7 months later when I do my own oil change.
  28. Feb 10, 2025 at 7:42 PM
    #58
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    Dear lord baby Jesus, you’re probably right.
  29. Feb 11, 2025 at 9:07 AM
    #59
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I broke a cheap oil filter tool on my wife's VAN the other day, the dealer had done her oil change the last few times. I was forced to leave it at oil change only; I just ordered the Motivx tool and am hoping that and a breaker bar does the job. Amazon has new OEM housings for sale, maybe I order one of those just in case!
  30. Feb 11, 2025 at 9:19 AM
    #60
    BrandonL812
    Brandon
    Get the non plastic housing.
