Second, Third, Fourth Opinions wanted
Discussion in 'Sequoia 1st Gen (2001-2007)' started by bhb983, Feb 3, 2025.
  1. Feb 3, 2025 at 10:17 AM
    bhb983
    bhb983 [OP] New Member
    Brandon
    Indiana
    2006 DoubleCab 4x4
    As you may or may not be aware I have been on the search for a 05-07 sequoia for some time. I have found one, in California. I live in Indiana. The seller has sent me this video of the undercarriage but I am unable to attach it for some reason. I have paused the video and taken a screen shot of the area in question. It looks super clean to me but I want to make sure I’m not missing anything. I am not sure if there is something leaking up around the rack or not. Any help or opinions would be
  2. Feb 3, 2025 at 11:49 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Sure looks wet. Add says pending.
  3. Feb 3, 2025 at 12:01 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    Right, he listed it as pending as we came to an agreement on price. He then sent the video/pictures and I what I thought was a leak of some sort. I think I’m going to try and find a mechanic, out that way, to take a look at it before I fly all the way out there.
  4. Feb 3, 2025 at 12:02 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
  5. Feb 3, 2025 at 12:02 PM
    AZBoatHauler
    So.Arizona
    Looks like it was sprayed with fluid film.
  6. Feb 3, 2025 at 12:09 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    It’s a CA vehicle so I don’t think that’s the case. He did say that the timing belt/water pump were replaced in the last 2k miles and does have paperwork showing that. I wonder if it has to do with that.
  7. Feb 3, 2025 at 12:24 PM
    AZBoatHauler
    So.Arizona
    I see it’s in California - not far from the ski mountains where they lay down tons of salt every winter. Maybe I’m wrong but I wouldn’t say it’s unheard of for CA vehicles to have any rust prevention.
  8. Feb 3, 2025 at 12:32 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    You maybe correct! I just had him send me some more pics and the calve covers are definitely leaking.
  9. Feb 3, 2025 at 12:39 PM
    AZBoatHauler
    So.Arizona
    I’d be more interested in the story behind the butt splice. Leaking valve covers and exhaust leaks off the manifold both very common on these.
  10. Feb 3, 2025 at 12:41 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    Funny you say that! I circled that and sent the pic back to him asking what’s up!
    AZBoatHauler[QUOTED] likes this.
  11. Feb 3, 2025 at 12:58 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    Do you know what that sensor is? Is is something to do with the SAIS?
  12. Feb 3, 2025 at 1:02 PM
    Lifer
    Lifer New Member
    Vince
    It has been leaking for awhile it appears, did they run it low on oil? Is it 2 wheel drive? I am not too far, maybe 90 minutes. Those trucks are a dime a dozen out here for less. I have an 02 LTD 4WD that to me is only worth 6-7G's
  13. Feb 3, 2025 at 1:07 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    It’s 4x4. I’d prefer a 05-07, if you know of any pass it my way! Or are you saying you want to sell yours?!?!?
  14. Feb 3, 2025 at 1:08 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    That's the wiring connector to that specific fuel injector.
    Lifer likes this.
  15. Feb 3, 2025 at 1:13 PM
    Lifer
    Lifer New Member
    Vince
    No I am not plugging lol. If you find anything around Sac or Stockton I can check it out. The 07's and up cost more obviously. We are casually looking for a 20-22
  16. Feb 3, 2025 at 1:14 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    What does it connect to on the other side? Can it be replaced or is it part of a bigger harness?
  17. Feb 3, 2025 at 1:16 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Definitely part of a bigger harness. Should tie into a large loom that has all the injector wiring and works it's way back to the ECU. If it works I'd probably leave it alone or just solder the wires together in a less redneck fashion
    AZBoatHauler likes this.
  18. Feb 3, 2025 at 3:59 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    Right on, I believe the other wire looks chaffed too. So they will both get the soldier treatment!
  19. Feb 3, 2025 at 3:59 PM
    bhb983
    Brandon
    Indiana
    2006 DoubleCab 4x4
    By the way, I would not give what he’s asking!
    Lifer[QUOTED] likes this.
  20. Feb 3, 2025 at 11:42 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Looks like the leak I had. Might be coming from the oil cooler o-ring and/or valve cover. Leak tends to travel on the oil pan lip and spray the back flywheel inspection plate.
    i was loosing about half a quart of oil every 5k miles. Had the leak for about 2 years
