Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Feb 3, 2025 at 5:43 AM
    #181
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    A narrower axle in the rear is supposed to help with the turning radius. That being said, every time i’ve built or have had built custom axles, i’ve made the front and rears the same length. I’ve always preferred a bit wider.
  2. Feb 3, 2025 at 5:53 AM
    #182
    bmf4069 [OP] Captain wtf
    We'll see what they look like w/o, and if I need I can get some 3/4" spacers to get it back to where it is now.
  3. Feb 3, 2025 at 6:42 AM
    #183
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    you want my KSP spacers? They be 1". Hub centy.
  4. Feb 3, 2025 at 6:46 AM
    #184
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Can do. This evening
  5. Feb 3, 2025 at 6:51 AM
    #185
    If they're tucked a tad more than I like, I will definitely hit you up.
  6. Feb 3, 2025 at 6:57 AM
    #186
  7. Feb 3, 2025 at 7:29 AM
    #187
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    When I pull my open diff I can just swap the flanges?
  8. Feb 3, 2025 at 8:25 AM
    #188
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
  9. Feb 3, 2025 at 9:36 AM
    #189
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just a thought on the parking brake. I blew a hard line in moab once and had to use my e-brake to limp off the trail. I was very glad to have a mechanical backup that day.
  10. Feb 3, 2025 at 9:56 AM
    #190
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm almost certain that's what Toy Lex did for mine.
  11. Feb 3, 2025 at 9:58 AM
    #191
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If he doesn't, I might.
    FishNinja[QUOTED] likes this.
  12. Feb 3, 2025 at 12:55 PM
    #192
    whodatschrome
    lots of dents
    Most disc brake’d conversion E brakes suck bad enough that they’re only good on flat ground…if there’s no wind. I’ve lost a brake line a few times over the years while out wheeling. The quick fix was to hammer the metal hardline completely flat (with a hammer, wrench, jack handle, rock), fold it over itself two or three times (each time hammering it flat again), and carry on for the remainder of the trip with 3 brakes. Keep the speeds down though. Coming in hot at 55mph into a 35mph corner while applying the brakes will make a jeep cj7 take up all 3 lanes on a 2 lane road.
    I was at the Easter Jeep Safari many years ago in Moab. I rolled my CJ7 (different CJ than the one above) in Devil’s Hot Tub. The rollcage partially collapsed and the steering wheel broke completely off the column. Like there was not even any spokes left to grab, and what was left to grab was very sharp stainless steel (yes i tried, but it wasn’t possible to use vise grips as a steering rudder). I ended up having to drive the rest of the way out of the Hell’s Revenge trail and an additional 30 minutes back on the highway to get back into town. I wore a leather glove so my hand didn’t get sliced open from the sharp metal, and had to literally palm my hand where the small circular horn pad used to be. I pretty much had a 3” diameter steering wheel to steer with. It was sketchy as all get out and the pucker factor was very high. Hell’s Revenge trail is no joke, and even less of a joke one handed with no steering wheel!
    JakeJake likes this.
  13. Feb 3, 2025 at 12:58 PM
    #193
    whodatschrome
    lots of dents
    When i swapped a junkyard sequoia 4.10 3rd members into my tundra, i didn’t have to swap the pinion flanges. That being said, i sold my existing tundra 3.90 3rd member to a random guy on craigslist, and he ended up having to swap his drive flange onto the 3rd member that he had just bought from me.
  14. Feb 3, 2025 at 1:21 PM
    #194
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    This here exactly. In addition, the 8" elocker uses smaller 10mm studs, while the 8.4" uses larger 12mm studs if memory serves right. Regardless, the 8.4 has a larger mounting footprint, and is stronger with the bridged carrier caps and larger bearings, gears and carrier. To get an 8" in, you'd be looking at a custom housing which I think negates the entire idea. Not worth the money or time involved.
  15. Feb 3, 2025 at 2:47 PM
    #195
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Might as well just buy an Eaton e-locker. I love mine.
    FrenchToasty and whodatschrome like this.
  16. Feb 3, 2025 at 3:41 PM
    #196
    250000yota
    Russ
    Berthoud, CO
    Exactly. I did a Harrop way back when they first came over to the US. Cruiser Brothers, the company I bought it though, was originally the only company importing them at that time, and they gave me a discount on the locker in exchange for photos for advertising. According to them, I got the first Harrop in the US. I can't find the ad they used my truck in anymore unfortunately. I love mine though, never had an issue with it.
  17. Feb 28, 2025 at 6:20 AM
    #197
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    75 and sunny today, a great day for @bmf4069 and I to get this project kicked off.
    Todays plan is to get Ironman cleaned up and stripped to a bare rear frame.
    -Measure pinion angle
    -remove rear bumper
    -Remove bed
    -drop spare tire
    -Pressure wash
    -remove axle/springs/shocks
    -remove brake lines to LSPV and LSPV
    -tack in temporary x member
    -remove factory spare tire crossmember
    Should look something like this
    LETS GO!
  18. Feb 28, 2025 at 7:30 AM
    #198
    Y'all should toss a brand new Denso fuel pump into 'ol Ironman while you got the bed off eh.
  19. Feb 28, 2025 at 8:48 AM
    #199
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    ...and the fuel filter :boink:
  20. Feb 28, 2025 at 2:31 PM
    #200
    JakeJake
    2000 Tundra AC 4X4
  21. Feb 28, 2025 at 2:33 PM
    #201
    Fuck that fuel filter! Never again!
  22. Feb 28, 2025 at 2:36 PM
    #202
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Who’s the ahole that put those spring shackle bolts on backwards? :D
  23. Feb 28, 2025 at 3:08 PM
    #203
    SUrgery started today with @JakeJake and Dale. Everything went smooth as butter, thanks to Jake. Having done this before and having a shop with a forklift, pressure washer, and air compressor helped a shit load. I think start to finish was maybe 2-2 1/2 hours. I've done what I can; the rest is in Jake's hands. PICTURE TIME!
    Fork that bed!
    Fork that bed again!
    Bed removed. QC checker Dale approves.
    Two tundras tundraing.
    Our QC expert got distracted, probably a squirrel or something.
    A little cleaning.
    QC Dale checking the cleaning.
    Axle out. 30 minute job w/o the bed.
    Sequoia axle in place
    Sequoia axle top view.
  24. Feb 28, 2025 at 3:10 PM
    #204
    He's gonna get some new titanium legs! (I forgot what his legs were made from)
  25. Feb 28, 2025 at 8:48 PM
    #205
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Cuz we know it didn't need a fuel filter :wink: :burp:
  26. Feb 28, 2025 at 8:48 PM
    #206
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Beat me to it
  27. Feb 28, 2025 at 8:49 PM
    #207
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yall planning any different leaf springs configuration?
  28. Feb 28, 2025 at 8:53 PM
    #208
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If we only knew @JakeJake for the first Panhandlemonium we'd have finished you truck the first day and hit Merus as planned haha
  29. Feb 28, 2025 at 9:47 PM
    #209
    This is why we multi quote! Read all the texts then reply!
  30. Feb 28, 2025 at 10:30 PM
    #210
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Where's the good axle pics???
