RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Feb 2, 2025 at 3:13 PM
    #1261
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  2. Feb 2, 2025 at 3:31 PM
    #1262
    RobertD
    Robert
    DFW, Texas
    :benchpress:
  3. Feb 8, 2025 at 10:08 PM
    #1263
    RainMan_PNW
    Casey
    Clark County, WA
    Did front brake pads/rotors today at 91570 miles. I was down to under 1mm on those pads. :eek2: Went with OEM - can’t complain about performance.
    I did misplace the new “W” wire clips I had bought and one of them isn’t in gear shape so I’ll have to swap those out when I have the wheels off next time (probably next weekend to do an oil change).
  4. Feb 8, 2025 at 10:09 PM
    #1264
    RainMan_PNW
    Casey
    Clark County, WA
    Also installed the RCI Fuel Tank Skid Plate today (reach out to Colton at Hotshot Offroad). Pretty easy install since my truck has the straps with the studs on them for the plastic TRD “skid”
  5. Feb 18, 2025 at 7:02 AM
    #1265
    TRDSPEC
    TRDSPEC New Member
    Thanks for the pics and installation approach.
    My opinion is once the Fogster is experienced, it becomes a requirement for the Tundra. Especially if you have high output fog lights like the DD SS3 MAX.
  6. Feb 18, 2025 at 5:14 PM
    #1266
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I’ve been looking through your build and finally found this bumper. Your attention to detail makes me look at myself and step my game up.
    Thanks for the pics and details throughout your build. I’d like to get a winch but for now my focus is this bumper in the front.
    Thanks for sharing
    Question: you said you hit a Yahtzee but the only damage I saw was from the dear. So what was the Yahtzee??
    Be well
    R/
  7. Feb 19, 2025 at 7:53 PM
    #1267
    RainMan_PNW
    Casey
    Clark County, WA
    Honestly - that was so long ago I don’t recall.
    Probably a perfect shitstorm at work and home with a dose of animal damage on top
  8. Feb 20, 2025 at 10:05 AM
    #1268
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    So i think I've figured it out...
    you have my sense of OCD and @TRDFerguson 's desire to refactor everything multiple times over...
  9. Feb 20, 2025 at 10:07 AM
    #1269
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Sounds like a terrible combination
  10. Feb 20, 2025 at 10:10 AM
    #1270
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I mean...yes?
  11. Feb 20, 2025 at 10:40 AM
    #1271
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Anybody got a code for rci off-road gas tank skid plate?? Thx
  12. Feb 20, 2025 at 10:43 AM
    #1272
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    I'm prepping to swap Platinum mirrors (adding power folding and puddle lights) onto my 21 TRD Pro along with swapping in the non-memory mirror switch. Following your post above since it's a similar situation and truck, but trying to compare my N5 connector to what you show above.
    See pic below for N5 at my driver side mirror. Unless I'm reading the diagram wrong (which is highly likely) I don't seem to have wires 13 and 14 for Auto Dim -/+. Any idea why my connector would be missing these - your diagram would indicate they should be there from the factory. The colors also are different than the diagram states, e.g. Pin 2 is Y-B vs W-B. How do I make sense of this? Or should I just add the wires as needed?
    bulldog93 likes this.
  13. Feb 20, 2025 at 6:42 PM
    #1273
    RainMan_PNW
    Casey
    Clark County, WA
    It’s a debilitating affliction
    TaquitoBandito, Mater and TRDFerguson like this.
  14. Feb 20, 2025 at 6:43 PM
    #1274
    RainMan_PNW
    Casey
    Clark County, WA
    Reach out to @memario1214 - if there’s one to be had, he’s gonna have the hookup
    WILLINH and TRDFerguson like this.
  15. Feb 20, 2025 at 6:51 PM
    #1275
    RainMan_PNW
    Casey
    Clark County, WA
    See the column in the screenshot you quoted that says “present”? The Y are present in the connector, the X are added by me, and the grey/black are not there and not added by me during that install. Pins 13 & 14 are the ones that aren’t there and that I didn’t add.
    As for wire color - that is precisely why I always say to use the pin-out before using wire color. Over time/different suppliers the wire colors can change but the pin-outs should (99% of the time) be correct.
    I’ll also warn you that the platinum mirrors do not have their BSM circuit in the same place as that pinout shows.
  16. Feb 20, 2025 at 7:05 PM
    #1276
    littlebus01
    Tobias
    21 trd off-road
    Thanks will do
  17. Feb 22, 2025 at 4:36 PM
    #1277
    RainMan_PNW
    Casey
    Clark County, WA
    Drilled a small (1/8”) vent hole in the inner “baffle” in the washer fluid reservoir - gained almost a quart of additional capacity.
    Also switched out the original wiper blades finally…
  18. Feb 27, 2025 at 6:10 AM
    #1278
    RainMan_PNW
    Casey
    Clark County, WA
    Do NOT recommend these wiper blades.
    I’ve got a spot and 8” wide and 6” tall near the middle of the windshield that the passenger one simply doesn’t contact the glass at all. Similar issue (but smaller area) on the driver one right at the point it goes vertical (so the far left of the windshield). That and the drivers side one is about 1/2” less coverage than OEM, while the passenger one is over 1” less coverage.
  19. Feb 27, 2025 at 6:13 AM
    #1279
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've always heard that OEM wipers are about the best we can do on our trucks. Of course, I rarely use mine and it spends most of the time in a garage (until the 86 kicked it out), so my experience may be not applicable to you people with weather.
  20. Feb 27, 2025 at 6:22 AM
    #1280
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah
    This was the first time I’ve changed mine since new (92k miles).
    Bought them while picking up some other supplies - I’ll be ordering factory replacements today.
  21. Feb 27, 2025 at 6:28 AM
    #1281
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I’ve had good luck with the PIAA silicone ones. Don’t order the wrong ones as I did. They make 2 kinds and only one works for our wiper arm connections.
    TRDFerguson likes this.
  22. Feb 27, 2025 at 6:28 AM
    #1282
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I was gonna tell you 'don't do it' on those, but figured you'd pull some rainman shit and make em work :laugh:
    OE blades are the only thing I run now!!
  23. Feb 27, 2025 at 6:31 AM
    #1283
    Tripleconpanna
    Yes, OE are the best in rainy climates as well. I hated chaging out blades on the '08 every freakin' fall in vegas, but they'd bake in the summer. Thought the OE was just crappy rubber or something, but nope... they all rotted every summer, but everything else didn't work in the rain or winter either...
    Now that I'm somewhere w/a decent amount of rain 200+ inches a year :rain: same/same... the only difference is I'll be entering my 4th summer on the orignal set this year and they haven't dry rotted yet :D
  24. Feb 27, 2025 at 6:37 AM
    #1284
    1794TX
    Steven
    N.TX
    '20 1794
    There was a warning in an old post somewhere about factory blades as well. Apparently Toyota switched to another manufacturer at some point, and the quality dropped.
    OEM parts, and a quick word from a member on the non-original part, if you don't already have it:
    https://www.tundras.com/threads/wip...u-using-do-they-all-suck.115735/#post-2979706
    I replaced mine last year with Bosch Icons, and they're fine, but I'll likely get OEM next time.
  25. Feb 27, 2025 at 7:28 AM
    #1285
    COTundra23
    COTundra23 New Member
    install the front bumper yet?
  26. Feb 27, 2025 at 5:44 PM
    #1286
    RainMan_PNW
    Casey
    Clark County, WA
    Still at the coater.
    COTundra23[QUOTED] and RobertD like this.
  27. Feb 27, 2025 at 5:44 PM
    #1287
    RainMan_PNW
    Casey
    Clark County, WA
    Thanks for the link to the part numbers.
    1794TX[QUOTED] likes this.
  28. Feb 27, 2025 at 5:56 PM
    #1288
    SAGE63
    San Diego County
    powder coat or a lineX type coating
    I am on the fence between a type of lineX and powder for the replacement rear bumper.
    I say lineX type as most of the shops here use something else since Line X corp got gready with their distributers
  29. Feb 27, 2025 at 6:11 PM
    #1289
    RainMan_PNW
    Casey
    Clark County, WA
    Getting it powder coated to match the rear. Guy I know that does a bunch of custom work has a local guy that does a good job. He throws my stuff in with one of his “loads” and charges me next to nothing (usually trade for a little computer support or a twelve pack of decent beer)…as long as I’m ok with his specific shade of satin black.
    TundyManFL, COTundra23, Mater and 2 others like this.
  30. Feb 27, 2025 at 8:14 PM
    #1290
    TaquitoBandito
    Joel (AKA Bif)
    Been running Bosch Icons on mine too - doing fine.
