Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Feb 1, 2025 at 7:41 PM
    #121
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Not to throw wrenches, but according to rock auto sequoias have 30 spline axles, and tundras have 32 spline axles. I dont know, just dipped my toe into this rabbithole.
    The Black Mamba and FrenchToasty like this.
  2. Feb 1, 2025 at 7:44 PM
    #122
    bmf4069 [OP] Captain wtf
    If that's the case, I may be keeping the sequoia diff and we can go from there. Just filed my taxes. Getting $3700 back. That should let me do a few more things.
  3. Feb 1, 2025 at 7:54 PM
    #123
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I don't think that's right from what I remember. My Eaton is 30 spline.
  4. Feb 1, 2025 at 8:04 PM
    #124
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    but you have a sequoia sport trac. I didnt check DC’s. I’ll poke around a little more tomorrow when i can write stuff down.
  5. Feb 1, 2025 at 8:25 PM
    #125
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    MMMMMMM
    Add those two masters to the pile of parts to to put up in a sale thread.
    A hydro handbrake would be fucking siiiiick though. Add a line lock and now your calipers are a parking brake instead of the factory setup...
    Dustbox likes this.
  6. Feb 1, 2025 at 8:29 PM
    #126
    Dang. Monster S550 there
    JakeJake[QUOTED] likes this.
  7. Feb 1, 2025 at 8:37 PM
    #127
    JakeJake
    2000 Tundra AC 4X4
    :eek2:
    As far as I saw the 1st gen tundra and the 1st gen sequoia diffs are interchangeable. I'll pull the sequoia diff tomorrow and drop in my spare tundra unit to make sure we don't have any square peg round hole action going on.
  8. Feb 1, 2025 at 8:48 PM
    #128
    JakeJake
    2000 Tundra AC 4X4
    Yeah I'm going to have to study the brake systems on the abs side. You definitely don't want that pump though, all that extra wiring, different ecu etc. Wishfully thinking that we can fool all the tundra stuff to think nothing has changed in the rear, but that's a bunch of tone ring/sensor values/wiring diagrams that I haven't dug into yet.
    Me? I'd just delete all that mess :rofl:Im up to give it a hard effort to make it work though.
    bmf4069[QUOTED][OP] likes this.
  9. Feb 1, 2025 at 9:05 PM
    #129
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    If it's worth anything-
    I've never felt the need or been in a situation in my truck where I wished I had ABS. For some reason my truck wasn't equipped with ABS, but I've always found it super easy to modulate brake pressure and since I'm the only person that drives it 95% of the time, I frankly don't see the need for it. My vote is to rip all that crap out.
  10. Feb 1, 2025 at 9:40 PM
    #130
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ve wanted abs in a neon srt4. Mainly because i was trying to drive it like it was rwd. Learned my lesson when i puckered a button into the seat on a road i wasnt familiar with. Havent driven a fwd car fast since.
    bmf4069[OP] likes this.
  11. Feb 1, 2025 at 11:20 PM
    #131
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My junkyard sequoia 3rd member fit perfectly in my Tundra.
  12. Feb 1, 2025 at 11:28 PM
    #132
    whodatschrome
    lots of dents
    To be on the safe side, i’d grab both the booster and MC. Plug all the ports that don’t pertain to your tundra. (it’s par for the course to swap out a disc/drum MC for a disc/disc MC when converting over to rear disc brakes). Then install an adjustable prop valve. And no rule that you have to install that valve under the tail end of the truck (if you don’t want to). I have an adjustable prop valve located under the dash on my ford highboy, and an adjustable prop valve located under the hood on my jeep cj7.
  13. Feb 1, 2025 at 11:42 PM
    #133
    whodatschrome
    lots of dents
    I’d highly recommend to grab a tape measure and fully articulate the truck to get the shock length measurements. Remove the current rear shocks, and if you don’t have an RTI ramp, put about 800 of shtuff in the bed (generators, welders, ect make great ballast) and cross the truck up in a deep ditch. Get one bumpstop smooshed tight to the frame on one side, and have the other side’s tire dangling in the air. Then take notes down on paper of the distance between the upper and lower shock mounts. Then cross up the truck once again, but have the opposite side tire in the air and make a second set of measurements.
    There’s a whole ton of different length 5100 shock options. Download the options before you head out to measure your shock mount distances so that you can mull over the different lengths while you’re laying under the truck with a tape measure. Some 5100’s have different valving than others, so keep that in mind too.
    And FYI, lots of the time the suspension measurement at full extension will be different if the rear axle is articulated, compared to the whole axle just hanging straight down (as in if you had jack stands under the frame rails).
    Just trying to throw out some pro tips from my own personal suspension experiences.
  14. Feb 1, 2025 at 11:47 PM
    #134
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  15. Feb 2, 2025 at 5:35 AM
    #135
    ABS deletion is probably the ideal solution. I drove through our latest snow storm w/o it and did fine with these tires and non functional rear brakes it's easy enough to modulate the brakes to not lock them up. But, if it's easy enough to make them work, I'd be fine with that. If we can't make them work, I'm fine with that too.
    Jake is making a custom rear shock mount, adding about 4" of travel. He's got a pic of his and what he's gonna do that he's can post up. That and U-bolt eliminators.
  16. Feb 2, 2025 at 5:38 AM
    #136
    JakeJake
    2000 Tundra AC 4X4
    Great point's here on the bias/proportioning valve. Mine is underneath out back just because that's what everybody in the community had done before me. It would be very convienient to have it under the hood adjacent to the master cylinder. Although I haven't touched the thing since making a few adjustments after installing.
    I drove myself nuts pulling measurements when I did my rear suspension work, but haven't ventured into articulated measurements. Archive garage has laid the groundwork here though and a ton of guys are running their extend shock mount with a 12" travel shock with good performance.
    I cant find anything within Billstein's data that suggests the 5100 shocks have different valving across the different part numbers.
    This set I'm running is only 11" of travel, but I've got other issues limiting my articulation.
    Next time!
    If you saw the puny oem sequoia links you would be disgusted. Also the spring over setup with all the links and brackets etc those things are a mess under there. Cant wait to cut all that bracketry off the axle.
  17. Feb 2, 2025 at 5:43 AM
    #137
    Yeah, those upper links were about the size of the sway bar links. Embarrassingly small. Also, I ordered new rotors and pads last night. Let me know if you find anything else I need to get.
  18. Feb 2, 2025 at 5:47 AM
    #138
    JakeJake
    2000 Tundra AC 4X4
    Re: parking brake. @bmf4069 have you ever used yours? :rofl: because I only hit mine when I think about it to keep the rear drums adjusted.
    Fell down the rabbit hole of line locks last night, and I do see a great off-roading use for one.
    An electronic solenoid style would be awesome on trail if you need to get out of the truck in a precarious position. Pump the brakes twice and hit the button to have all four wheels locked up tight. Great for recovery, or just to run around back to get refreshments out of the cooler.
    A manual valve could be used in place of the mechanical parking brake, but there's some room for error there with loss of pressure etc. I wouldn't rely on that say parked on sloped terrain on the street unattended.
    https://www.summitracing.com/parts/tci-861200
    455h0le_dachshund likes this.
  19. Feb 2, 2025 at 5:48 AM
    #139
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is that where it meets the diff?
    Keep in mind I've got Sequoia 4.10 gears in mine now
    Sirfive[QUOTED] likes this.
  20. Feb 2, 2025 at 5:50 AM
    #140
    JakeJake
    2000 Tundra AC 4X4
    Yes the axle shafts are splined on the carrier side. I'll snag you a picture today.
    I've driven a lot of vehicles pre abs and definitely prefer it. Glad my tundra is abs free. Someday im going to make use of all that extra passenger fender space.
    Dustbox likes this.
  21. Feb 2, 2025 at 5:53 AM
    #141
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    the almighty rockauto was wrong?
    Wait. You have a tru-trac or something. But yea, looks like everything is 30 spline. Even ‘95-‘15 tacos.
  22. Feb 2, 2025 at 7:30 AM
    #142
    des2mtn
    Shady Grove
    Tonto cover
  23. Feb 2, 2025 at 7:35 AM
    #143
    des2mtn
    Shady Grove
    Tonto cover
    I put my LSPV at the master cylinder, glad I put it up there.
    Put this tee in place of the LSPV. Put a plug on it but could also put a bleeder I guess.
    https://www.amazon.com/dp/B01N2HLYC6?ie=UTF8
    Originally ran all three lines to the tee, but deleted the return line and it performs better. Also had to put a plug in the tee right beneath the master cylinder
  24. Feb 2, 2025 at 7:35 AM
    #144
    Anyone used a 1995-2004 Tacoma third with the E locker?
  25. Feb 2, 2025 at 7:36 AM
    #145
    Pretty sure I've never used it except when trying to adjust my brakes.
  26. Feb 2, 2025 at 7:49 AM
    #146
    des2mtn
    Shady Grove
    Tonto cover
  27. Feb 2, 2025 at 8:18 AM
    #147
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah TrueTrac. Speaking of which... It's time to show some humility and admit I was wrong about 3/4 of my previous hateful statements about my TrueTrac. I had bald tires and that was the cause of much of my issues. Bitch hooks up instantly on dry pavement now. Jury is still out on power slides . But in the rain, I does nice donuts.
  28. Feb 2, 2025 at 8:27 AM
    #148
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I only use mine on the trails, when I get out the truck somewhere sketchy
  29. Feb 2, 2025 at 8:30 AM
    #149
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    8" rear? Nah
    Maybe check what the second and turd gen tacos use. I think it might be an 8.4" like ours.
    Only the non e-locker first gen tacos used 8.4"
  30. Feb 2, 2025 at 8:54 AM
    #150
    des2mtn
    Shady Grove
    Tonto cover
    Pretty sure you're going to run into the same mounting issue.
