One thing after another
Discussion in '1st Gen Tundras (2000-2006)' started by Moonminer, Dec 30, 2024.
  1. Jan 24, 2025 at 2:21 PM
    #181
    Moonminer
    Moonminer [OP] New Member
    Illinois
    2000 tundra, SR5, access cab, V8 4.7 2wd
    How can you test if the crankshaft position sensor is bad?
  2. Jan 29, 2025 at 5:54 PM
    #182
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    PNW15, Jack McCarthy and shifty` like this.
  3. Jan 30, 2025 at 8:34 AM
    #183
    Moonminer
    Illinois
    Well problem fixed! It was a faulty camshaft sensor and a faulty camshaft sensor. Still idles a bit high, but I’ll take it. It idles at around 1200 rpm.
    w666, The Black Mamba, wauto and 3 others like this.
  4. Jan 30, 2025 at 8:45 AM
    #184
    Thanks for checking back in to report your findings! Glad it seems sorted. The idle may relearn with some time and engine cycles.
    Moonminer[OP], wauto and BroHon like this.
  5. Jan 30, 2025 at 8:54 AM
    #185
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Awesome
    Keep us posted on the idle and if you get it to relax.
    My truck has an idle around 900rpm, which is still too high.
    Moonminer[OP] likes this.
  6. Jan 30, 2025 at 11:50 AM
    #186
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    good lord glad you figured it out. Been following this thread rooting for ya'll to get it well done!
    Moonminer[OP], PNW15 and BroHon like this.
  7. Jan 30, 2025 at 12:40 PM
    #187
    Moonminer
    Illinois
    Thank you all for your help! I mean I was about to blow this truck up. I don’t like to use my being deaf and being obsessive compulsive and dyslexic as an excuse but without your guy’s help my son and I would have just walked away. Yeah the idle sits at about 1100rpm which I hope will die down after a bit. But it used to idol at 600 or 700 rpm. But AGAIN THANK YOU SO VERY MUCH
    dbittle, BroHon and KNABORES like this.
  8. Jan 30, 2025 at 12:51 PM
    #188
    Don’t be a stranger.
    Moonminer[OP] and NickB_01TRD like this.
  9. Jan 30, 2025 at 1:29 PM
    #189
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I don't think I speak for just myself here, but It's great to see you overcome the issues you were up against (a lot of us have had some real difficult ones as well).
    Hopefully your initiation is over, and you (or your son) can just enjoy driving it now. Welcome to the group, and like @KNABORES said, stick around :thumbsup:
  10. Jan 31, 2025 at 1:04 PM
    #190
    Moonminer
    Illinois
    Okay this is a stupid question but how did this happen? Is there a way I can unscrew something to zero in the ignition to the panel trim hole? Did I accidentally move something and it lowered the ignition key? All the bolt holes line up and screw in easy?
  11. Jan 31, 2025 at 1:15 PM
    #191
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Perhaps the missing black plastic trim ring is the final piece of the puzzle that's keeping the lock cylinder from being centered in the trim panel?
    BubbaW, BroHon, des2mtn and 1 other person like this.
  12. Jan 31, 2025 at 1:38 PM
    #192
    I thought for sure you were gonna ask how the light turned purple
  13. Jan 31, 2025 at 2:02 PM
    #193
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Lighten that load on the key ring and get a bonus 5 more years out of that ignition switch! ;)
  14. Jan 31, 2025 at 2:06 PM
    #194
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    wauto and PNW15 like this.
  15. Jan 31, 2025 at 2:12 PM
    #195
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I've culled my (work) ring so many times in 30 years.... I'm not even joking:rofl: here is my 30 year extras ring, effin ridiculous.
    bmf4069 and whodatschrome like this.
  16. Jan 31, 2025 at 2:15 PM
    #196
    The Black Mamba
    DFW
    Imma keep it stock
  17. Jan 31, 2025 at 2:21 PM
    #197
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    My work isn't that smart, or cool. :rolleyes:
  18. Jan 31, 2025 at 2:27 PM
    #198
    The Black Mamba
    DFW
    Imma keep it stock
    Aren't you a sparky? Atleast @bmf4069 gets a 2nd gen
    bmf4069 and BroHon[QUOTED] like this.
  19. Jan 31, 2025 at 2:35 PM
    #199
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  20. Jan 31, 2025 at 4:23 PM
    #200
    I'm in a 2021 dodge ram now. :(
  21. Jan 31, 2025 at 6:56 PM
    #201
    Moonminer
    Illinois
    Even with the ring it still isn’t centered? And the key ring isn’t all that busy, it’s a truck key, a house key, and old key rings from when my boys were little!
  22. Feb 3, 2025 at 11:38 AM
    #202
    Moonminer
    Illinois
    OKAY LAST QUESTION.
    From the rear diff to the center support bearing what angle should that be?
    then from center support bearing to the trans, what angle should that be?
  23. Feb 3, 2025 at 2:07 PM
    #203
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I could measure mine with my angle finder (It is a 2000) but it's 4x4.
    Didn't you say yours was lifted too?
    What are you trying to investigate/determine with the angle measurement?
  24. Feb 3, 2025 at 3:23 PM
    #204
    Moonminer
    Illinois
    My son says he is getting a vibration at the center support bearing. I looked and it seems the rubber is cracked and loose. It’s not lifted I think with the new rough country shocks in front and rear it might have lifted it a 1.5 or 2? Just want to know the angle the drive shaft should be before I put a new center bearing on it.
  25. Feb 3, 2025 at 5:08 PM
    #205
    Rear shocks don't provide lift.
  26. Feb 3, 2025 at 6:30 PM
    #206
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    If it was me I wouldn't sweat the actual angle one bit. You haven't modified anything so the angle will be what it will be.
    If the drive shaft center support bearing is cracked and loose it needs to be replaced regardless. "Spicer" is the brand you want.
  27. Feb 3, 2025 at 10:07 PM
    #207
    Moonminer
    Illinois
    So I won’t need a center support bearing drop kit?
    I am aware the rear shocks don’t provide lift the leaf springs do.
  28. Feb 4, 2025 at 3:12 AM
    #208
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Pictures would help.
    I just measured my center of axle to wheel arch, about 22.5 inches. I have some stupid stout bastard leaf packs. I have no carrier bearing drop kit, and everything is fine. Keep in mind my rig is 4x4, but i think the carrier bearing mount is in the same place. Several members have 2wd rigs that are lifted a little bit, I don't think any are using a drop on the carrier bearing.
    @The Black Mamba
    You don't have a drop on your center bearing do you Mamba?
  29. Feb 4, 2025 at 3:13 AM
    #209
    The Black Mamba
    DFW
    Imma keep it stock
    No sir
    Moonminer[OP] and BroHon[QUOTED] like this.
  30. Feb 4, 2025 at 3:16 AM
    #210
    This makes me think about my 35-45mph or so vibration I’ve got now. Never noticed it before my new leaf packs, which gave me about an inch of lift in the rear. Oddly though. I notice it when towing too, so don’t think it’s rear ride height related.
    shifty` and BroHon like this.
