Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Jan 28, 2025 at 12:17 PM
    #1591
    centex
    centex New Member
    Stage 2 kit en route. Estimated ETA 1.31.
  2. Jan 28, 2025 at 2:16 PM
    #1592
    TurboKits
    TurboKits New Member
    Yes sir, here are some pics right before it was boxed up this morning :)
    AZTundra, TOYOTARIG, Gaston and 6 others like this.
  3. Jan 28, 2025 at 2:23 PM
    #1593
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    so pretty.
    TurboKits[QUOTED] likes this.
  4. Jan 28, 2025 at 2:45 PM
    #1594
    centex
    centex New Member
    Epic. Doing some logging at the moment. Will have a couple sent to you tonight.
    Jego and TurboKits[QUOTED] like this.
  5. Jan 28, 2025 at 2:49 PM
    #1595
    TurboKits
    Perfect!
  6. Jan 30, 2025 at 11:57 AM
    #1596
    TurboKits
  7. Jan 30, 2025 at 12:02 PM
    #1597
    centex
    centex New Member
    Come on fedex!
    Jego and TurboKits like this.
  8. Jan 30, 2025 at 1:58 PM
    #1598
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Nice, looks great! I hope my videos can help too, hopefully soon. :ballchain: (I had to use my christmas vacations for my kid's project and still on it)
    Quick question. Let's say I have stage 2 installed. It is possible to tune it in a way that it can be used with or without the water/meth. by just turning the water/meth on or off without the need of further adjustments and/or restrictions? Or the tune must be different for one way or the other, meaning that the water/meth must be On or off all the time depending on the tune?
    Mdl and TurboKits[QUOTED] like this.
  9. Jan 30, 2025 at 1:59 PM
    #1599
    TurboKits
    Yes and no, you could tune it without the water meth and then just run more rich with it on, but ideally, you would tune for the fuel mixture you would be running.
    Mdl and Jego[QUOTED] like this.
  10. Jan 30, 2025 at 2:05 PM
    #1600
    centex
    centex New Member
    Are you asking if you have to load a different tune to spray meth?
  11. Jan 30, 2025 at 2:09 PM
    #1601
    TurboKits
    Good point, I should have elaborated... You do not need to switch tuned to run meth. You could tune with it it and then turn meth on, on the same tune. It would run slightly more rich, most likely scrubbing some power, but no, you would not have to switch maps. What you wouldn't want to do is tune / use the meth to be on the razors edge of performance and then run without it...
    Jego, Silver17 and Mdl like this.
  12. Jan 30, 2025 at 2:13 PM
    #1602
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    Yes as Jesse stated. Iogged both with and without W/M, 500cc full flow. I have PE setup that if I run out or have a situation it is still rich enough in low boost, 7psi, to give some protection. If I run out I can always throw in some water to reduce IAT's.
    Yes this ideal. I have 2 separate tunes. But if I don't have my laptop just gotta stay out of boost, wot!
  13. Jan 30, 2025 at 2:21 PM
    #1603
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If I were going right to stage 2 I’d personally skip the meth when tuning it so as to not be dependent on it, and simplifying the system altogether. I would think the intercooler deems it unnecessary. It’s a nice cooling effect and added safety net, but evidently in a very rare case it could also wreak havoc as we have now unfortunately seen. I also like to skip extra electrical aftermarket components and connections wherever possible, but again that’s probably just me.
    Jbehredt, e30cabrio, ZPhilip and 3 others like this.
  14. Jan 30, 2025 at 2:37 PM
    #1604
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I would run without W/M as you pointed out. I'm not injecting the amount needed for my estimated HP. Just enough to lower IAT's and lower PE about .7 as I'm only at 30% methanol and I could inject plain water to lower IAT's also if needed.
  15. Jan 30, 2025 at 3:06 PM
    #1605
    bflooks
    Metrowest MA
    Thanks for the slap on my sun burned ass. It's too soon and really stings. :)
    I have decided I will be keeping the tank empty and I'll be killing power to the AEM controller. I'm holding off on completely removing the system until after the PTSD from all of this fades a bit. Then I'll reassess. That said, the power switch to the system like everyone has spoken about, plus the solenoid, and people should be able to avoid whatever the hell happened that one regretful morning not long ago...
    Jbehredt, e30cabrio, Jego and 2 others like this.
  16. Jan 30, 2025 at 3:11 PM
    #1606
    bflooks
    Metrowest MA
    @Jego please hurry up. i'd like to remember to follow your install but that'll be a tall ask for an 80y/o dementia patient. :pccoffee:
    e30cabrio and Jego like this.
  17. Jan 30, 2025 at 3:37 PM
    #1607
    Silver17
    Eastern PA
    Sorry man! No intent to rub it in, it really rots and you don’t deserve it. As you said, if your scenario prevents others from having the same issue then at least that. If you’re feeling like disabling it for the time being is the right answer it may be the best choice for others as well if the now known risk, no matter how small, isn’t worth the reward when also using an intercooler was all I was suggesting.
  18. Jan 30, 2025 at 5:22 PM
    #1608
    bflooks
    Metrowest MA
    It's all good. I was just messing with you. Situation sucks, everyone can read about it, everyone can make their own decisions.
  19. Jan 30, 2025 at 6:33 PM
    #1609
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Yes
    Thanks for the clarification!
    Thanks for the info! I like the idea of tuning it so as to not be dependent on it as @Silver17 mentioned and keeping it to give some protection as @Mdl mentioned. Of course I am counting with @TurboKits support to achieve this :).
  20. Jan 30, 2025 at 6:34 PM
    #1610
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    :rofl:Will do! :)
    Mdl likes this.
  21. Jan 30, 2025 at 6:50 PM
    #1611
    bflooks
    Metrowest MA
    I still laugh at how simple it is. I know it's simple, but in the truck, it seems like magic because it fits. Lol
    TurboKits[QUOTED] and Jego like this.
  22. Jan 31, 2025 at 2:52 AM
    #1612
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Today is the day!:bananadance:
    bflooks[OP] likes this.
  23. Jan 31, 2025 at 4:38 AM
    #1613
    centex
    centex New Member
    Allegedly.
    Jego, AZTundra, ZappBrannigan and 2 others like this.
  24. Jan 31, 2025 at 7:58 AM
    #1614
    centex
    centex New Member
  25. Jan 31, 2025 at 8:34 AM
    #1615
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    :yay:
    HulkSmurf14 likes this.
  26. Jan 31, 2025 at 9:03 AM
    #1616
    bflooks
    Metrowest MA
    That looks so much easier to muscle around than one giant box! Congrats on having the product in-hand. Looking forward to watching your install.
    Jego likes this.
  27. Feb 2, 2025 at 3:18 PM
    #1617
    centex
    centex New Member
    Unboxed everything today and first thing I’ll say is that if FedEx manages to damage anything in these boxes, they did it on purpose. I unpacked 2 55gal trash bags worth of packing peanuts not counting the various other wrapping methods.
    On that note, be very diligent when going through the peanuts. Lots of little parts that are easily missed. As I was scooping the boxes out I found the meth solenoid and nozzles hiding in a box that I had rummaged through multiple times.
    There’s a lot to go through and now I gotta start planning things out.
    IMG_3688.jpg IMG_3689.jpg IMG_3690.jpg IMG_3691.jpg IMG_3692.jpg IMG_3693.jpg
    @TurboKits the kids said thank you for the stickers and gum!
  28. Feb 2, 2025 at 5:16 PM
    #1618
    TurboKits
    Love it!!!
    e30cabrio likes this.
  29. Feb 3, 2025 at 4:43 PM
    #1619
    bflooks
    Metrowest MA
    Yaaaawn.
    Does anyone have anything cool to share? Progress? Updates? Anything? :)
    I'm stuck in purgatory waiting on, well, literally everything, so I'm thoroughly bored.
    I saw the Stage 2 install instructions and I'll say this: they are thorough, but don't hesitate to ask him for help! It's a full day ( maybe two if you've never done it), but know it does all fit! Unless you have an aftermarket cooler, then you'll need to get creative or just mirror what they did for mine.
    Also, not that it matters, but if you care, wrap your tubing in painters tape or plastic wrap until it's all finish installed. Or, ceramic coat it now before you start handling it a lot. I did mine after and while it's sealed, it could def use a good polishing before the 2025 cruise night season.
    I'll be over here kicking rocks waiting for progress.
  30. Feb 3, 2025 at 5:03 PM
    #1620
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Jbehredt, MTRock, TurboKits and 4 others like this.
