  1. Jan 30, 2025 at 10:20 AM
    Blowing around town today on a hurricane
  2. Jan 30, 2025 at 10:28 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    If my harley engine isnt leaking, then it doesnt have any oil in it.
  3. Jan 30, 2025 at 10:42 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My old jeep cj7 came with a 60 amp alternator. I had a warn xd9000i winch on it that got used frequently for years and years. My old ford highboy also had a 60 amp alternator and a warn 8274 winch that would see frequent severe use.
  4. Jan 30, 2025 at 10:46 AM
    whodatschrome
    lots of dents
    Does your truck have ABS?
  5. Jan 30, 2025 at 10:46 AM
    That’s by design to insure you don’t have stale oil in there and that it’s always fresh.
  6. Jan 30, 2025 at 11:38 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Does anyone make driveshaft spacers? Like hub centric wheel spacers, but for the driveshaft. If i did a 3” lift i think i’d want an extra 1/2” based on slip-shaft wear. It might not be ‘timed’ right, but i might be able to add a belt pulley as a spacer, run one of those gm hybrid starter/alternators mounted to the axle as a small motor or ‘house’ battery charger. Would be cool to have a lever to a sort of rheostat to run it drive vs. load.
    thinking about getting a 250A js alt. Wish there was somwhere that would combine 2 alts on the same shaft.
    $1200.
    https://parts.gmc.com/product/gm-genuine-parts-starter-generator-24287484
  7. Jan 30, 2025 at 11:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Thanks! So the LOC to boost up the voltage isn't really needed?
  8. Jan 30, 2025 at 12:04 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Trail Gear has a 1" and 1.5" spacer for 2nd gen Tacomas that might work. This might only work on the 05-06 trucks though since the bolts have a 66x66mm spacing.
    https://www.polyperformance.com/trail-gear-longfield-toyota-driveline-spacer-05-15-tacoma-1
  9. Jan 30, 2025 at 12:08 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Whale oil beef hooked! I don't think ever ever seen a water cooled alt.
  10. Jan 30, 2025 at 1:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :laugh:
    battery powered chainsaw...
    Get one of these if you're not going to plug it in or use petrol.
  11. Jan 30, 2025 at 2:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    upload_2025-1-30_16-9-10.jpg @BroHon this truck is going to make somebody very happy. That could be you.
    Maybe I should tell Edward Jones I need to make a withdrawal. :D
    Who needs a house anyways?
    KNABORES, BroHon, Dakillacore and 4 others like this.
  12. Jan 30, 2025 at 2:21 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I used to do a bunch of woodworking and I milled a big white oak that fell down in Fort Worth. I ended up buying a 394xp husqvarna and putting a 36" bar on it. It has like 7 hp i think. That thing can eat. I welded up a holder and then would ride it down an extension ladder as guide rails. That was some of the hardest work I've ever done. I probably got about 100 or 150 boardfeet of quartersawn oak though. I have pictures, but they're buried in the cloud.
    BroHon, whodatschrome and JakeJake like this.
  13. Jan 30, 2025 at 2:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Man the hammer drill is where I like my battery power, same goes for my impact. But for my chainsaw it's plug in or gas.
    Dakillacore likes this.
  14. Jan 30, 2025 at 2:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My OT got cut this weekend. So if you get back between today and Saturday, let me know if you wanna do your leaf packs. I'm going to start wiring dad's radio and backup camera today.
    Maybe I'll have time to install my new kicker powered sub in Elvira.
  15. Jan 30, 2025 at 2:25 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Thanks, got one on the way too...
  16. Jan 30, 2025 at 2:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm pretty sure someone makes a carrier bearing spacer for our trucks. Should be compatible with tacomas too. Not sure if this would help you. If thought about buying one, but my DD equal length x pipe crosses right under thete. Not sure if have the space. Remember how much of a pita it was to change the bearing?
  17. Jan 30, 2025 at 3:09 PM
    bmf4069 Captain wtf
    Nah, you should be good.
  18. Jan 30, 2025 at 5:37 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Uhhh, that's a sweet truck, but not my style, and def not in my financial wheel house :eek: :rofl:
    whodatschrome and FrenchToasty like this.
  19. Jan 30, 2025 at 5:41 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That job was one of the easier ones I've done on my truck, what did you guys run into?
  20. Jan 30, 2025 at 5:45 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  21. Jan 30, 2025 at 5:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    KNABORES and FrenchToasty like this.
  22. Jan 30, 2025 at 5:58 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Because race truck. :rofl:
  23. Jan 30, 2025 at 5:59 PM
    MacFixes
    MacFixes New Member
    mac
    2000 Tundra Limited TRD
    what’s the absolute biggest setups you guys have seen someone run on a tundra?
  24. Jan 30, 2025 at 6:11 PM
    15 setups at least
  25. Jan 30, 2025 at 6:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Again, "setup" is pretty ambiguous and could mean a lot of things. You must be more specific...
    Dook55 likes this.
  26. Jan 30, 2025 at 6:17 PM
  27. Jan 30, 2025 at 6:17 PM
    No, I like the ambiguousity
    des2mtn, bmf4069 and whodatschrome like this.
  28. Jan 30, 2025 at 6:18 PM
    JakeJake
    2000 Tundra AC 4X4
    This one is 16 or 17 setups I think.
    Dakillacore, des2mtn, bmf4069 and 5 others like this.
  29. Jan 30, 2025 at 6:20 PM
    Next question is how many schrute bucks per setups
  30. Jan 30, 2025 at 6:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @shifty` I found your Tacoma. 4 banger manual. I want it, too. But I have an idea. You buy the sc'd LT tundra in Florida, I'll buy the turbo taco. Then we meet near the Ms. Sippi/Alabamer boarder and trade trucks.
    bmf4069, shifty` and FrenchToasty like this.
