Well need help again!
Discussion in '2.5 Gen Tundras (2014-2021)' started by tjacob95, Jan 30, 2025.
  1. Jan 30, 2025 at 10:35 AM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    Anyone mounted the anytime backup cam front camera to a limited grill? The cam does not fit my truck now im lost on how to fabricate a mount for it…please someone help
  2. Jan 30, 2025 at 10:45 AM
    AZBoatHauler
    So.Arizona
    What camera are you using?
    the first time I pulled the grille, drilled holes to line up with the mounting bracket and bolted it on.
    the second time I used a push-in round style camera and cut a hole in my faux TSS cover to mount it.
    you can zoom in on these pics for an idea of what I’m talking about.
    1lowlife likes this.
  3. Jan 30, 2025 at 10:49 AM
    tjacob95
    Mine didnt come with a mounting bracket its just a camera and a bolt imIMG_8736.jpg
  4. Jan 30, 2025 at 10:50 AM
    tjacob95
    Im trying to find a place to mount it but theres nowhere to drill into on my grillIMG_8737.jpg
  5. Jan 30, 2025 at 10:52 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Where did you get your camera from? It looks like the same kit I got from Trail Grid Pro. If I'm not mistaken, the camera is "clockable" in that you cut a certain wire in the harness to let it know its mounting orientation. With that being the case, could you mount it to the bottom of the emblem or something?
  6. Jan 30, 2025 at 10:54 AM
    AZBoatHauler
    So.Arizona
    I drilled and mounted to this but I had two small mounting holes to the side not one in the middle…
    Is there room in front of the brace? Obviously you’d need to drill from an angle…
  7. Jan 30, 2025 at 10:57 AM
    AZBoatHauler
    So.Arizona
    Around this blue dot?
    make sure the nut will fit.
  8. Jan 30, 2025 at 11:13 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    AZBoatHauler likes this.
  9. Jan 30, 2025 at 11:36 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  10. Jan 30, 2025 at 11:44 AM
    tjacob95
    Thats what i ended up doing mine does something wierd though when switching back from front camera to the nuetral position on the switch it always goes to the rear camera before switching off i dont understand why it does that does your do it? I ordered mine from caliraised led
    AZBoatHauler[QUOTED] likes this.
  11. Jan 30, 2025 at 12:00 PM
    AZBoatHauler
    So.Arizona
    Definitely sounds like a switch issue. They don’t have the best reputation around here.
  12. Jan 30, 2025 at 12:12 PM
    tjacob95
    U think i should order a new switch and wire it?
  13. Jan 30, 2025 at 12:20 PM
    AZBoatHauler
    So.Arizona
    Maybe check with them or other people here running that switch to see if it’s a known issue with their switch.
    I use my Alpine head unit as my camera control so I’ve never had a switch. I did have problems with a switch of theirs for an LED light bar. If the switch was warm it would stick when pressed… it was awesome having the switch stuck down keeping the light on as oncoming traffic flashed their lights.
  14. Jan 30, 2025 at 3:13 PM
    tjacob95
    Sounds amazing
  15. Jan 30, 2025 at 5:01 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
