Lightbar power source underhood for hybrid
Discussion in '3rd Gen Tundras (2022+)' started by lapoolboy, Jan 27, 2025.
  1. Jan 28, 2025 at 3:13 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    If you don't mind waiting, my printer crapped the bed and I just finalized replacement parts but they are coming from China. Chinese New Year is tomorrow, I doubt I'll get the parts for a month.
  2. Jan 28, 2025 at 5:18 PM
    Rockpig
    08 Limited
    Sent you a DM.
  3. Jan 28, 2025 at 8:31 PM
    Mudbath Pro
    Mudbath Pro New Member
    2025 Tundra TRD Pro
    Looks awesome! Can you post the dimensions on it? May try to fab something up.
  4. Jan 29, 2025 at 6:39 AM
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
  5. Jan 29, 2025 at 7:41 AM
    AZBoatHauler
    So.Arizona
    $1000 for some wire and lugs??? WTF is going on in the world…
  6. Jan 29, 2025 at 7:50 AM
    lapoolboy
    lapoolboy [OP] New Member
    Yep, plus you have to drill four big-ass holes in the body of the truck. No thanks.
  7. Jan 29, 2025 at 9:26 AM
    tahoetund
    tahoetund New Member
    2024 Platinum iForce Max, Lunar
    What do you think caused the post to come loose? Now im worried. Was on a previous wiring thread with you, i tried the post but because it was always hot I decided on the pictured approach instead. You think toyota would ever try and blame me for this pass side fuse setup? Top wire is raptor lights (includes existing bottom fuse), bottom is going light bar (unused fuse). Both only turn on with ignition
  8. Jan 29, 2025 at 10:07 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I used the lug on my Diode Dynamics lightbar on both my current 2024 1794 Limited Edition as well as my previous 2023 1794 with no issues.
    I can see the benefit of running it off the battery but I had no qualms using the lug.
    tahoetund and eddiefromcali like this.
  9. Jan 29, 2025 at 6:21 PM
    Rockpig
    08 Limited
    I tapped into an underhood fuse, one that was not being used for anything according to the schematic. I made sure that only one fuse was installed and it was for what I was powering only, no need to install the second fuse since there was nothing stock being powered. https://www.tundras.com/threads/1794-le-mod-diary.150206/
  10. Jan 30, 2025 at 7:13 AM
    lapoolboy
    After careful consideration and research, I've decided I am going to mount the original included lightbar relay under the rear seat in the battery box. This way, I can connect 12V+ power and ground from the relay directly to the battery with short leads. I can run the three switch wires from the relay under the door sill trim to the dash switch. Then I'll just need to run one 12V+ off the relay through the firewall and out to the lightbar. I will ground the lightbar to the body under the hood.
    Is my logic sound? I'm just trying to avoid running a bunch of wires through the firewall. If I mount the relay under the hood, I'd have to run five wires through the firewall (three for the switch and two for the battery connections). My plan only requires the one wire.
    Only downside I can think of is I may hear the relay clicking when I turn the light on/off.
  11. Jan 30, 2025 at 7:46 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Makes sense...I think you're overthinking it for a simple light bar install.
  12. Jan 30, 2025 at 7:49 AM
    lapoolboy
    Yea, I tend to overthink things but I'm a "do it once and correctly" kind of guy.
  13. Jan 30, 2025 at 7:49 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Not sure. I'm not sure if the light bar had anything to do with it. They didn't go into detail, but spent months trying to figure out why my truck wouldn't run. Long story short Toyota Canada was trying to blame it on the bars, but again, luckily I had them disconnected between the first time the first time it failed and the next time it failed.
    I think if Toyota can make any link from what the issue is to that, they'll try.
  14. Feb 15, 2025 at 7:49 PM
    Mudbath Pro
    2025 Tundra TRD Pro
    Well, went ahead and wired up a Garmin PowerSwitch to the fuse box post today. No issues currently, but have only wired up some ditch lights so far.
  15. Feb 21, 2025 at 10:56 AM
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    2023 Silver tundra Limited TRD OR, Crew max, 5.5ft
    MX4 Tonno, Go Rhino E-boards, Method 705, BFG AT 285/75/17, Rigid amber fog lights
    Are the add a fuse taps directional? I see you have them led off in opposite directions, thought they had a hot side and then wire lead side so current goes through the fuse?
  16. Feb 26, 2025 at 2:07 PM
    a71rambler
    Kitsap County, WA
    A bunch...
    Still working well? Where did you mount your PowerSwitch?
  17. Feb 27, 2025 at 7:57 PM
    Mudbath Pro
    2025 Tundra TRD Pro
    Working fine. Still waiting for my diode dynamics ditch lights to arrive, so just have the rock lights currently. I have it mounted to the plastic fender liner near the fuse box. I’ll post a pic this weekend if I remember.
  18. Feb 27, 2025 at 8:55 PM
    BayAreaTruckin
    BayAreaTruckin New Member
    San Francisco, CA
    I have installed it. Great kit - very high quality and well thought out. Currently making a mount to attach a power switch, ecoflow alternator charger, fuse, and bus bar to the front of it.
  19. Mar 2, 2025 at 7:18 PM
    Mudbath Pro
    2025 Tundra TRD Pro
    I still need to clean up some wiring, but added some ditch lights today. I have the garmin powered from the post and grounded at the factory ground point right there and added a bus bar grounded to the body at an unused bolt hole. I only plan on adding lights to this garmin, so hopefully no issues. Gonna try and run a trigger next weekend from the ignition fuse.
  20. Mar 8, 2025 at 8:41 PM
    #50
    Mudbath Pro
    2025 Tundra TRD Pro
    Added a trigger wire from the 5amp ignition fuse to the garmin today. So far, no issues running power of the fuse box lug
  21. Apr 14, 2025 at 8:58 PM
    #51
    HillbillyMedic
    HillbillyMedic New Member
    2025 Lunar Rock Tundra Hybrid Limited TRD OF
    Lomax Pro Heritage Grille Rave OF - Raptor Lights DD SS18 White Driving Bar (Grille) DD SS8 Amber Fogs DD SS18 Amber Stealth Bar (Stealth)
    Any chance you’d share the STL?
  22. Apr 19, 2025 at 5:20 PM
    #52
    Rockpig
    08 Limited
    I'll see if I can find the file, my printer crapped the bed a few weeks after printing that, the replacement they sent never worked either so I'm waiting on my 3rd machine. At the time I had pretty crappy internet and it was quicker to store the file using a thumb drive than transfering to via wifi to the machine. Now that you're asking I hope I didn't send that thumbdrive back with the machine, I haven't seen it in months. I'll look for it and if I find it I'll share it with you.
  23. Apr 19, 2025 at 5:27 PM
    #53
    HillbillyMedic
    I really appreciate it.
    Rockpig[QUOTED] likes this.
  24. Apr 22, 2025 at 9:06 PM
    #54
    HillbillyMedic
    I ended up getting a roll of 2-12 AWG marine grade wire, and some longer 7 AWG battery cables. Looks clean enough, just need to tie up the slack.IMG_0143.jpg IMG_0144.jpg IMG_0138.jpg IMG_0142.jpg
