Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Jan 28, 2025 at 5:28 PM
    #91
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You and Chip throw in that shift kit yet?
  2. Jan 28, 2025 at 5:53 PM
    #92
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    You're lucky if they fit under all 17s
    I would say anything less than -15 offset is going to be close to rubbing the caliper.
    I did grind on a set of 13WEs once to try to fit a 15" wheel on a friends Tundra back when he was broke and didnt have good tires or money and i had an extra set of 15s with good tires laying around. Back fit, front hit the caliper so i started grinding like i used to do on Camaro rear calipers when running 15s. I soon found out where the cross over tube is for the outboard pistons..... And then had to buy my buddy a new caliper and ditch the 15" wheels up front idea. The 14WA is definitely larger, i think the OEM rotor for 13WE and 13WL is 319mm and the 14WA use a 338mm rotor. Not only is the rotor almost exactly an inch bigger, the caliper is bigger, longer, and sits up higher away from the spindle. I doubt you can make it fit with 16s even with grinding.
    Besides, who runs 16s these days anyway?
  3. Jan 28, 2025 at 6:01 PM
    #93
    Everyone with factory 16” wheels such as the starfish, the chubby 5s and anyone who bought new wheels 20+ years ago for their first gen before larger wheels were a thing. Oh, and me.
    edit: also Iron man’s and Trail teams.
    bmf4069[OP], FiatRunner and des2mtn like this.
  4. Jan 28, 2025 at 6:32 PM
    #94
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Dubs were all the rage in 2005
    Dubs or twankies = 20" wheels or larger, for those of y'all that live under a rock. :D:thumbsup:
    noahrexion likes this.
  5. Jan 28, 2025 at 8:38 PM
    #95
    bmf4069 [OP] Michelob Ultra coinesour
    I run 16s. FACTORY 16s at that!
  6. Jan 28, 2025 at 10:05 PM
    #96
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    But do you plan to forever?
    Just saying... My five KMC Enduro 16x8 0 offset wheels, wrapped in Cooper AT3XLT 295/75R16's will be coming off once I'm ready to install the Kendas. and 17's. Hopefully by this summer. I might keep em as a backup set, if I have room. But once the 17's and 35's go on, the next mod planned is 14WA. So. They'll be up for sale for sure once the big brake mod happens. BTW all 5 tires have certs and less than 15k miles on em.
    Food for thought of any Texans are thinking about bigger tires this summer or fall...
    @Sirfive @JakeJake @The Black Mamba @Mohoman @txagg
    txagg likes this.
  7. Jan 29, 2025 at 4:05 AM
    #97
    Nope. @KNABORES is holding a set of the 17" split 5 spoke wheels for me until we can meet. I'll probably just do some 255/80/17s on them.
    PNW15 and KNABORES like this.
  8. Jan 29, 2025 at 4:17 AM
    #98
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Really gonna stick with 33's?
    If I had a friend like Jake within walking distance, I'd be greasin em to tub my Tundra for 35's or 37's. :D
    Maybe bring em a bottle of rye, case of Shiner, and some thick steaks next time.
    Trail Teams FTW. I wish I had swapped em from my Taco to the Tundra when I traded it.
    I miss Pearl the 99 XC.
    I don't miss Misti the 03 DC, but I do miss Benni, in the passenger seat.
  9. Jan 29, 2025 at 4:55 AM
    #99
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    trailer fenders and some time is all it takes.
  10. Jan 29, 2025 at 4:57 AM
    #100
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You forgot the most important parts: cutting tools and a welder.
  11. Jan 29, 2025 at 4:58 AM
    #101
    FishNinja
    Lee
    06DC2wd
    yea but @JakeJake already has all of that; so it's a given
  12. Jan 29, 2025 at 5:16 AM
    #102
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It was a given he had what you said too lol
    Or something comparable. Besides I thought you meant all I need. I've never welded
  13. Jan 29, 2025 at 5:27 AM
    #103
    FishNinja
    Lee
    06DC2wd
    it's like gluing wood together. But with hot molten metal.
  14. Jan 29, 2025 at 5:34 AM
    #104
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Pshhh! I roll my own fenders :thumbsup:
    I don't think I'd ever put a tire that big on an IFS rig. Might as well go to the 40"+ club, and at that point you're into 1 ton axle/ atlas t case/ full tube chassis territory.
    Oh and trailering it to the trails, cuz im not about to waste my sticky meats on the asphalt.
  15. Jan 29, 2025 at 5:36 AM
    #105
    JakeJake
    2000 Tundra AC 4X4
  16. Jan 29, 2025 at 5:49 AM
    #106
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Well if any of y'all showed up to HF after Thanksgiving you'd have seen plenty of Toyotas doing it.
    :boink:
  17. Jan 29, 2025 at 11:33 AM
    #107
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You won't. But you should. :p
  18. Feb 1, 2025 at 4:46 PM
    #108
    Sequoia axle acquired. $340 and 45 minutes. Not too shabby.
    This axle is 1 1/2 inches wider than the tundra axle, so I may need some 3/4" spacers to get back to where I'm at now. Me and Jake chatted a little yesterday and I finally got back in line after a lot of stupid think. Me brain do dumb time to time. I kept thinking I would have to use the sequoia diff. No dumb dumb, we're gonna shove my diff in there. *facepalm*
    Anywho, the only problems we forsee are the e-brake cable and there's individual brake lines to each caliper all the way to the abs pump. What were thinking is taking the tee off my axle and putting it basically where it is on my axle, and using a single line to the wilwood manual valve.
    We looked at the sequoia BB/MC, but it looked funny. Lots of connectors on it. Unless someone says otherwise we're thinking about just cranking the valve open a little more to get more pressure in the rear. If we need it i can go grab it later.
    Demo will begin the Friday after next, with fab work to follow during the week. @memario1214 is getting me a price on some new, longer rear shocks and the rear prop valve. I love that guy.
  19. Feb 1, 2025 at 4:51 PM
    #109
    Azblue
    The Dirty T ( ^_^)_且
    Watching for the ensuing carnage and mangling that is assured to occur. :popcorn:
  20. Feb 1, 2025 at 4:53 PM
    #110
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont remember if the rear sequoia calipers were single piston or dual, but the tundras rear are dual 1” pistons on each side, and the sequoia piston(?s?) are 2”.
  21. Feb 1, 2025 at 5:36 PM
    #111
    JakeJake
    2000 Tundra AC 4X4
    Just getting a chance to dig into the technicals of some of this. Looks like the SOS sequoia master is the same unit that we saw today. the sensor ports are just plugged. They indicate that its not required for their disc kit, but it creates a firmer pedal.
    https://sosperformance.com/products...er-installation-kit-fits-rear-disc-conversion
    I'll dig more into this and the parking brake stuff over the next few days, and compile the information here for the next guy(s).
  22. Feb 1, 2025 at 5:55 PM
    #112
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I bet that bb/mc is for the electronic brake LSD.or what ever it's called..
    What you gonna do with you aluma shocks?
  23. Feb 1, 2025 at 6:31 PM
    #113
    Probably sell em. I'm getting the longer 5100s from @memario1214. I believe they're for a 1 ton ford. I don't really need em for weight, just more travel.
  24. Feb 1, 2025 at 6:32 PM
    #114
    If that's the case I can run up next weekend and grab that BB/MC.
  25. Feb 1, 2025 at 6:33 PM
    #115
    It had traction control, but no VSC. Kinda weird. 2 lines fed the ABS pump, the 4 lines to each individual piston.
  26. Feb 1, 2025 at 6:36 PM
    #116
    @JakeJake this may be the beer talking, but what if we grabbed the abs pump as well? Pull the brake lines too and just rerun the rear lines to be just like the sequoia?
    455h0le_dachshund likes this.
  27. Feb 1, 2025 at 6:37 PM
    #117
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    turn-brakes, like a tractor or dunebuggy.
    bmf4069[QUOTED][OP] likes this.
  28. Feb 1, 2025 at 6:42 PM
    #118
    JakeJake
    2000 Tundra AC 4X4
    They are definitely getting a whole lot more brake data on the tree's.
    We don't need the brake booster for that master.
    Didn't we JUST swap an OEM tundra booster into your truck, or am I dreaming? Or was it a Master cylinder?
  29. Feb 1, 2025 at 7:37 PM
    #119
    We nabbed a "new" booster off that tundra, and I have a spanking new master from RA just chillin. Pretty sure my MC is from that AC at H&H.
  30. Feb 1, 2025 at 7:37 PM
    #120
    You need to calm down sir.
    The Black Mamba likes this.
