General Supercharger Thread
  1. Jan 27, 2025 at 2:01 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Don't "need" it ever really, but I WANT! IT!.
    lol
    I hate not having it in my driveway.
  2. Jan 27, 2025 at 2:04 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Leave it, unless you really like that AAA tow truck and driver
  3. Jan 27, 2025 at 2:05 PM
    e30cabrio
    Different drivers, I liked the first one better. New guy wasn't as nice.
    lol
  4. Jan 27, 2025 at 5:03 PM
    e30cabrio
    Got it back, running poorly, has codes, sent Sniv a log.
    HulkSmurf14 likes this.
  5. Jan 27, 2025 at 6:03 PM
    centex
    centex New Member
    Need to leave it there until it’s running right for a week at the shop.
  6. Jan 27, 2025 at 6:06 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Update: New oem gas cap and purge valve did not solve the P0441 code. I think it’s the (new to me) junkyard ECU that’s the issue so just gonna roll with it (and swap in another ecu later), if there was a leak/actual issue there would be other codes.
  7. Jan 27, 2025 at 6:12 PM
    blenton
    blenton New Member
    Where did you get the trash panda? I thought they frequented Ford garages more than yours...?
  8. Jan 27, 2025 at 6:18 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Good hard working family people for sure. If I need a day trash panda I go down to my local Napa parking lot and honk near the dumpster and they’ll get in the back (honk once for SAE twice for Metric).
  9. Jan 27, 2025 at 6:20 PM
    blenton
    blenton New Member
    Thanks for the pro tip! If my horn doesn't work, can I just make trash panda noises? Are they similar to fox noises??
  10. Jan 27, 2025 at 6:33 PM
    centex
    centex New Member
    I laughed way too hard at this.
  11. Jan 27, 2025 at 7:14 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    man thaya rocket racoon. hes gonna faster than the speed of light soon
    blenton[QUOTED] likes this.
  12. Jan 27, 2025 at 7:16 PM
    NatesNightMare
    Pinetop Az
    sub 40? lol come up the mountain and put it to the test in the teens :rofl:
  13. Jan 28, 2025 at 6:36 AM
    e30cabrio
    I like these temps, I'm from N.Y. over 20 it's fine for me. It's summer I hate.
    It is going back, I am demanding a loaner I can bring the old motor home in & pick up the BMW motor Friday if it is not done by then & leaving it until it is 100%. I paid full market for the job & they exceeded the promised delivery by over a week & it's not done at week 6 (promised under 3 weeks to complete)
    Also, from Sniv:
    There's something majorly fucked somewhere. I don't know what that shop did, but it's like the harness or something got obliterated during the install. Bank 1 isn't reading any AFR whatsoever, codes for Bank 1 O2 sensor, random misfires, 1 and 3 misfire, MAF off, bank 2 O2 sensor, throttle pedal position voltage, it just goes on and on.
    There is a root cause somewhere, I'm not sure what it is, but somewhere something is causing all of this. Replacing the O2 sensors, the throttle pedal, whatever is not going to fix it. It's not a coincidence half the systems are throwing faults. Either the ECM or the harness is messed up, or something isn't grounded or receiving power correctly. You said you have the old ECM, I would try putting that in and see if it fixes everything. If that doesn't do it I'd start checking continuity between the ECM and the MAF for example and see if you can find what's wrong. I'd also search all the grounds and battery connections and see if anything is off.
    Wynnded, M3Tundra-JK, Mdl and 3 others like this.
  14. Jan 28, 2025 at 7:07 AM
    e30cabrio
    Just drove it, good news, I have throttle,(43 degrees out) it drops down gears as it should, feels better. Maybe it needs drive cycles to get past the mess? I sent Sniv a short new log. Also, good news, the 1mm smaller pulley jumps to higher boost fast, I have not gone more than 1/2 pedal & have seen 9.6lbs.
  15. Jan 28, 2025 at 7:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Woot woot!! Steady she goes!!
    e30cabrio likes this.
  16. Jan 28, 2025 at 7:26 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Doubtful, I'm more inclined to believe there is a wiring issue, like Sniv said, either the wiring was damaged during removal/installation or they forgot to ground something. Both cylinder heads have grounds to their respective inner fender and the block is ground to the chassis down below the AC compressor. There are also several grounds on the wiring harness.
    Mdl likes this.
  17. Jan 28, 2025 at 7:47 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I'm hopeful to see you get through this, but these issues do not self-heal. Sounds to e like you have an intermittent short to ground somewhere in the engine control harness. I can;t imagine it is all gone with no find or intervention...
    M3Tundra-JK likes this.
  18. Jan 28, 2025 at 7:54 AM
    e30cabrio
    I'm a dreamer, I dream.
    lol
  19. Jan 28, 2025 at 8:25 AM
    e30cabrio
    "Rebooted" several times, feels better each start, after clearing I have the permanent codes, then several more come back.
    I'm going to drive and get a log in a bit and decide what to do next. The passenger head ground is there, don't see one on the driver side. It's easy to add one.
  20. Jan 28, 2025 at 9:02 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Check the plugs that go from the engine wiring to the relay/fuse box behind the battery
  21. Jan 28, 2025 at 10:00 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is what I was thinking when he first got it back. A decent shop would of verified grounds and checked continuity on the harness plugs back to ecu. It's not difficult just takes a little bit of time.
  22. Jan 28, 2025 at 11:07 AM
    e30cabrio
    Didn't remember I never installed the new coils.
    Just swapped cyl 1 out seems like less misfire, I'll send Sniv a log.
    HulkSmurf14, reywcms and AZTundra like this.
  23. Jan 28, 2025 at 1:25 PM
    NatesNightMare
    Pinetop Az
    if you guys have an advanced autoparts near you id chexk them out. heard stores are closing and guys are getting parts for dirt cheap!
  24. Jan 28, 2025 at 1:30 PM
    e30cabrio
    Soooooo, I had to bring them a plug because they said one was stuck. I asked if they gapped it (I dropped it off, said it needs between .22-.24. They said no, you didn't say anything about that. I said I promise I did, that got Ok, you said it needed a smaller gap but not what it was.
    I just said which is it? They said 4, I pulled it, it was about .28, I made it .22, replaced another coil, and the truck feels much better. I need to get another log we'll see what happens.
    Little by little, maybe I'm getting past this.
  25. Jan 28, 2025 at 1:31 PM
    e30cabrio
    Mine was already picked clean when I heard, M3JK got 1400 in brakes for .000023 lol
  26. Jan 28, 2025 at 1:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I don't think .028 gap would cause misfires. Usually above .032 would cause misfires under load. When I tested plug gaps I went down to .021 and ran well went back to .026. I think the best performance is around .026-.028 gapping. If using the Lexus 8ar-fts coils should be good at .032-.034 if they gave som extra charge oomph.
  27. Jan 28, 2025 at 1:54 PM
    e30cabrio
    I thought I read with the Lexus coils 22-24 so I did as close to 22 as I could. It feels better now but I only drove a few blocks, work is crazy today.
    I need to get another log, I got rid of most of the codes but 0031 keeps coming back.
    Mdl likes this.
  28. Jan 28, 2025 at 2:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The greater the coil charge the more you can increase the gap without having a misfire. Smaller gaps help prevent blow out but sacrifice performance. We shouldn't worry about blow out as we're not pushing 25 psi, yet.:p
    Try following bank 1 O2 for any cut wires, inspect O2 plug for the p0031.
    Edit**since running the 8ar-fts coils @Jowett asked to try increasing the gap to see how it performs. I still need to try it.
  29. Jan 28, 2025 at 2:22 PM
    e30cabrio
  30. Jan 28, 2025 at 2:28 PM
    bflooks
    bflooks New Member
    Metrowest MA
    "That's a tight gap" is going to be my most favorite saying going forward.
    I know you guys are running some boost, but Jesse ended up leaving mine at 30/32 and it was running great up to 9psi. Even XAT recommended running DENSO/NGK factory gap (30/32) for their built long block. Were you all actually having blow out or just being proactive?
