Shaky at 55 mph
Discussion in '1st Gen Tundras (2000-2006)' started by ehshea5, Sep 15, 2020.
  1. Sep 15, 2020 at 6:56 PM
    ehshea5
    ehshea5 [OP] New Member
    Eric
    03 Black Limited
    Looking for help! Truck gets shaky at 55 mph but goes away once I get over 60. Had tires balanced and alignment done but no change. Any ideas?
    theblurry1 likes this.
  2. Sep 15, 2020 at 7:03 PM
    Welcome from NY.
    Did you try road forced balancing?
    What tires are you running?
    Jack McCarthy, abcinv and ehshea5[OP] like this.
  3. Sep 15, 2020 at 7:06 PM
    ehshea5
    Eric
    03 Black Limited
    No road force balance, running AT 265/70 on 17's. Had the same issue with a 2001 4 runner that never got taken care of.....
  4. Sep 15, 2020 at 7:11 PM
    What brand?
    There are plenty of threads about BF Goodrich having these issues.
    ehshea5[OP] likes this.
  5. Sep 15, 2020 at 7:14 PM
    ehshea5
    Eric
    03 Black Limited
    Hankook Dynapro AT2
  6. Sep 15, 2020 at 7:26 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Universal joint or center carrier bearing?
  7. Sep 15, 2020 at 7:42 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Might be what SouthWestGA said, my truck had a vibration around 55mph, changed out the carrier bearing and all was good. I say all was good because I bought a dorman carrier bearing :facepalm: and it started to squeal around 1,000 miles later. Buy the Spicer CB if you decide to go that route.
  8. Sep 15, 2020 at 7:59 PM
    X3, that was my next thought.
  9. Sep 16, 2020 at 5:23 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Steering rack bushings, LCA bushings, warped rotors, out of balance tires, etc.
    Just a check list.
  10. Sep 16, 2020 at 6:34 AM
    It's gonna be the tires 80% of the time. Some equipment, or rather the tech using it, doesn't do a great job of balancing the tires. Worn suspension or steering components may exaggerate the vibration, but rarely cause it. Good luck. and +2 on the road force balancing.
  11. Sep 16, 2020 at 6:44 AM
    Most common source of vibration on vehicles comes from things which are spinning. Two big things that spin are the wheels & tires and the driveline.
    If you know without a doubt it's not the wheels & tires, you should inspect the driveline. Visually look at the drive shaft, u-joints, carrier bearings. I suspect it'll be the carrier bearing is worn out, but I'm not a betting man.
  12. Sep 16, 2020 at 7:00 AM
    55mph vibration is classic for an unbalanced wheel. Also, I've had 2 sets of Hankook Dynapro AT2's. I like the tire, but the first set failed on me at 55k miles. I thought that was a good run for a tire, but an odd fail. I'm assuming the belts in the tread area began to separate. Not sure if it was from a road hazard, or just began delaminating inside. I noticed it while trying to rotate the tires to get rid of the vibrations I was experiencing at 55mph, which were getting severe.
    Note the giant hump in the outer third of the tread. Decent tread left for 55k though! inspired me to buy another set. Should have gotten some Wildpeaks...
    My dad with his knee pads for the win!
  13. Sep 16, 2020 at 11:44 AM
    Fred
    Hand Protectors
    Meant to say out of round tires earlier.
    These ‘off road’ tires are the worst offenders.
    Lots to check before narrowing it down to tires. Our trucks age has the front ends worn out and tired.
  14. Sep 16, 2020 at 2:45 PM
    ehshea5
    Eric
    03 Black Limited
    I appreciate the help. I am going to start with getting the tires balanced at a different shop. The tires are brand new and hopefully the crew that put them on did a crappy job. It has a new alignment done by a decent tech and he checked the front end stuff for wear.
  15. Sep 16, 2020 at 3:40 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Had a similar issue when I put new set of BFG AT on my truck. Road Force Balance took care of it.
    ehshea5[OP] and abcinv like this.
  16. Sep 16, 2020 at 4:02 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Same here
    Two balances didn't correct it but one Road Force balance did
    I'm on K02's BTW
  17. Sep 16, 2020 at 5:47 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Start with least expensive and work your way up.
    #1 - road force balance
  18. Sep 16, 2020 at 7:03 PM
    ehshea5
    Eric
    03 Black Limited
    I keep seeing the road force balance as a recommendation so I will try that asap and post the results.
    bmf4069 and Hightide like this.
  19. Sep 16, 2020 at 7:08 PM
    :thumbsup:
  20. Sep 17, 2020 at 6:16 AM
    Fred
    Hand Protectors
    Observe your steering rack bushings. Crawl under while someone above turns the wheels. Looks for play at the 3 bushing points across the rack.
    Hope your cam bolts aren’t seized so that you can get a proper alignment. This happened to my truck which led to front end rebuild with New LCA bushings and cam bolts.
    Just throwing some stuff out there for you.
  21. Sep 19, 2020 at 6:19 PM
    ehshea5
    Eric
    03 Black Limited
    Road force balance did the trick! Appreciate all the input you guys are great!
  22. Sep 19, 2020 at 6:41 PM
  23. Sep 19, 2020 at 7:05 PM
    ehshea5
    Eric
    03 Black Limited
  24. Jan 25, 2025 at 4:30 PM
    R-ROD
    R-ROD New Member
    R-ROD
    2017 Tundra Black Flex v8
    I know post is old. I had the same issues with shaking around 55mph on my older Tacoma and now on my TUNDRA.
    Started happening around 80k miles on each truck as I actually use my truck for a truck and off-road here and there like a maniac!
    After doing the easier stuff myself 1st, u joints, carrier bearing, alignment, rotation, balance, etc. didn’t resolve the annoying vibrations at 55mph.
    The fix for me was replacing the lower control arm bushings and ball joint.
    A lot easier and faster when doing these fixes in my back yard then paying a shop 300% more!
    Easier to replace the arm with the bushings installed. More cost affective.
    I did replace the bolts also because the old bolts were hurting.
    You will also have to get aligned afterwards.
    Later I have the time to rebuild the old arms if I wish.IMG_6308.jpg IMG_6308.jpg
    Although I’ve had no issues so far 50k later. Hope this helps!
  25. Jan 25, 2025 at 4:34 PM
    Welcome to 1st gen!
  26. Jan 25, 2025 at 4:34 PM
    R-ROD
    R-ROD New Member
    R-ROD
    Right on!
    G_unit3000 likes this.
  27. Jan 25, 2025 at 4:45 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  28. Jan 25, 2025 at 4:59 PM
    I was trying to find a good meme generator for @FirstGenVol, I wanted the franks red hot; but it was going to be aisin fipg; I put that shit on everything!!!
  29. Jan 25, 2025 at 5:05 PM
    Higher caster numbers after the alignment also helps as well. You should check your last alignment numbers against this one.
  30. Feb 2, 2025 at 5:14 PM
    R-ROD
    R-ROD New Member
    R-ROD
    Hey Y’all! FYI: my shaky at 55mph went away with balancing of all tires!
    My alignment is good.
    My u joints and carrier bearing seemed ok but I did replace as a precaution because I bought truck used about 6 months ago and not sure what has/hasn't been done.
    One of the positive things I’ve learned with buying a used vehicle is I get to experience current and future issues that’s for sure.
    Glad it wasn’t front end bushings that’s for sure. Until next time. Thank you all for your support!
