Broken Toyota Emblem Tabs. Now what?
Discussion in '2.5 Gen Tundras (2014-2021)' started by dadtrucklife, Jan 25, 2025.
  1. Jan 25, 2025 at 11:25 AM
    dadtrucklife
    dadtrucklife [OP] New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    During the grill swap on my 2021 I broke 2 of the 4 tabs on the grill emblem (they are so frustratingly fragile!). What are you guys doing in such case? Slapping it back on, gluing it on, buying a new emblem (man are they expensive!)? My truck is so new that I am leaning towards new. Kicking myself for not being more careful but I didn’t realize how easily they break.
  2. Jan 25, 2025 at 1:14 PM
    I know that there was a configuration change with the emblem. Does yours have a Phillips head screw as well as the tabs?
  3. Jan 25, 2025 at 2:31 PM
    dadtrucklife
    yes my is a 2021 with the tabs and screw hole. It should hold enough with the screw but I’m just particular.
  4. Jan 25, 2025 at 2:33 PM
    You should be fine with the screw and the remaining tabs.
  5. Jan 25, 2025 at 3:18 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I used rare earth magnets but it isn't a permanent solution, less so in warm climates. Depending on your grille this wont work if the emblem can slide around.
  6. Jan 26, 2025 at 7:29 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    I think some of this would be a perfect solution. It remains flexible, so you could always cut through it if you need to remove the emblem in the future. It comes out super thick and somewhat tacky which makes it easy to hold a piece in place. I just used some to mount the camera on my front grille, and it's not going anywhere lol. I just put a few dabs on a latex glove and reached behind the grille to put it on the camera.
    dadtrucklife[OP] likes this.
  7. Jan 26, 2025 at 9:29 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Can you post a pic of it?
    How much area is on the back of the emblem that touches the grille?
    After having them painted, I used 3M molding tape to reattach my TOYOTA letters on my TRD Pro grille.
    The tape only 'catches/touches' on the inside edge of the letters, but it has held up for over eight years.
    Amazon.com: 3M Super-Strength Molding Tape, 1/2 in x 15 ft, High Strength Double-Sided Adhesive, Permanently Attaches Side Moldings, Trim and Emblems to Interior and Exterior of Vehicles (03614) : Automotive
  8. Jan 26, 2025 at 6:16 PM
    dadtrucklife
    You just reminded me about that 3M auto tape which has worked well for me in other situations. Appreciate the response!
    1lowlife[QUOTED] likes this.
  9. Jan 31, 2025 at 7:49 AM
    dadtrucklife
    I plan to repair the broken tabs but it will require some dry time. Do you know if I can temporarily drive around without the emblem? Will it throw codes?
  10. Jan 31, 2025 at 8:00 AM
    It's hard to tell honestly.
