Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Jan 24, 2025 at 2:16 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It hurts, how much truth is in that statement, sir.
  2. Jan 24, 2025 at 2:18 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Truss this MFer and make an extra kit for me
  3. Jan 24, 2025 at 2:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This goes great with the Creature Commandos theme I got going on today
  4. Jan 24, 2025 at 2:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Smart. Wish I had done that
    The Black Mamba likes this.
  5. Jan 24, 2025 at 2:32 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Just looked at my spare axle for a while. A 3rd member shave would only get you 1" of extra clearance at most.
  6. Jan 24, 2025 at 2:33 PM
    What can you shave on the axle that creates clearance?
  7. Jan 24, 2025 at 2:35 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I’d say that’s more of a manscaping on the tubes
  8. Jan 24, 2025 at 2:37 PM
    whodatschrome
    lots of dents
    which is the difference in ground clearance between 33” and 35” tires
  9. Jan 24, 2025 at 2:37 PM
    whodatschrome
    lots of dents
    shaved pumpkin housing on a Currie high pinion 9” front axle. It’s inexpensive to do, but the labor is fairly involved. IMG_1645.jpg IMG_1646.jpg
    JakeJake and The Black Mamba like this.
  10. Jan 24, 2025 at 2:40 PM
    JakeJake
    2000 Tundra AC 4X4
  11. Jan 24, 2025 at 3:29 PM
    That doesn’t fuck up the oil splashing?
  12. Jan 24, 2025 at 5:36 PM
    whodatschrome
    lots of dents
    Shaving down the pumpkin has been a long time mod. I haven't ever heard of any oiling issues. Yes, there is a little bit less oil in the axle, but the oil level will still come up to the same height on the ring gear (as it did before a high clearance shave).
    The Black Mamba and JakeJake like this.
  13. Jan 25, 2025 at 5:56 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I'll see if I can get some pictures, but I am wary of ECGS. I know half a dozen people who have had negligent failures of diffs from them. Granted, that has to be 5+ years ago, but I still worry. My brother, and at least 3 of those failures, were caused by failing to locktite the ring gear bolts. My brothers diff failed so catastrophically that it actually damaged the axle housing. The saving grace was that ECGS stood by their warranty, replaced the built diff, and sent him a new housing. My brothers was a '00 Tacoma Elocker that he regeared to 4.56.
  14. Jan 25, 2025 at 6:18 AM
    JakeJake
    2000 Tundra AC 4X4
    @bmf4069 I'd be shocked if we didn't have a few options locally for quality gear work. You'd save money on freight cost at the very least. I'll ask around my network and see who's who.
  15. Jan 25, 2025 at 6:35 AM
    Often times the speed shops or off road shops will do them. I’m very leery of most off road shops as they tend to cater to the looks vs function crowd. Speed shops on the other hand wanna go fast and know they will break shit, so they try to break proof things.
  16. Jan 25, 2025 at 8:25 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    This will be fun to watch!
    Dumb questions:
    You say fuck the rear axle seals and rear brakes...
    A disc conversion kit would net you the same Sequoia rear brakes? Or am I missing something..
    Are the axle seals different on a Sequoia?
  17. Jan 25, 2025 at 8:39 AM
    des2mtn
    SW
    Tonto cover
    Wheel bearing is a little bit different on the Sequoia, it's an assembly with the bearing in the case unlike the Tundra, where you have to press the bearing in the case. Still kind of a bitch to do since you'll still need a press, but I think it'll be a little easier to get everything where you need it to be. The annoying inner axle seals will still be the same.
    Sequoia axle shaft/ wheel bearing:
    Tundra axle shaft/ wheel bearing:
    The Sequoia parking brake will be weaker than the Tundras, but it might be much easier to tie into the stock parking brake system. The parking brake in the SOS rear conversion kit is very lack-luster and took a lot of customization for me to get right. I had to switch the calipers where they were in front of the axle to get a better parking brake.
  18. Jan 25, 2025 at 8:48 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Thanks for that explanation! Perfect!
  19. Jan 25, 2025 at 11:00 AM
    bmf4069 [OP] Michelob Ultra coinesour
    The SOS kit des mentioned is close to 2k. I'm betting we can come in cheaper than that. Plus, I don't think anybody has done this before. I could be wrong though.
    And yeah, I've done my axle seals 3 times and they still leak. Me and @Sirfive did them perfect last time so it's possible I have a fucked up axle. We adjusted the brakes perfect too and they're still shit. I hate drum brakes.
  20. Jan 27, 2025 at 9:21 AM
    #50
    That sounds good to me. I have no idea who does diff work in town. Also, it's roughly $1400 for f/r LSDs. Plus labor to build and your labor. I may just be regearing for now.
    The Black Mamba and KNABORES like this.
  21. Jan 27, 2025 at 9:22 AM
    #51
  22. Jan 27, 2025 at 7:33 PM
    #52
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Stop. :smack:
    Wait and do it all at once when your money is right ... :smash:
    Also gives you more time to wait for the next big sale. Always only buy big ticket items on sale, unless you absolutely need it now or you'll die.
    Buy once, cry once.
  23. Jan 27, 2025 at 8:39 PM
    #53
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    This. And just have @JakeJake weld your current diff. lol 1/2" plate cut to fit inbetween the spider gears and viola!
  24. Jan 27, 2025 at 8:51 PM
    #54
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    For real, not like he needs the tundra to daily drive when he's got a motorcycle and the Vic. :D
    The Black Mamba and bmf4069[OP] like this.
  25. Jan 27, 2025 at 8:53 PM
    #55
    JakeJake
    2000 Tundra AC 4X4
    This reminds me I do have a spare rear diff, I should weld that bitch.
  26. Jan 27, 2025 at 11:00 PM
    #56
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Y'all going to tub Beau's truck for some dirty 5's too? :D
    Y'all get the front 4.10's from the Sequoia too or just the rear?
  27. Jan 28, 2025 at 6:34 AM
    #57
    FishNinja
    Lee
    06DC2wd
    I've welded a total of 4 diffs for varies drift projects. The plate inbetween the gears is ideal. The bigger the better. It's like a fail safe. So even if the welds on the spider gears crack, that hunk of steel welded in place should keep everything from moving.
    the best thing about welded diffs is that they're 100% predictable.
    455h0le_dachshund likes this.
  28. Jan 28, 2025 at 6:37 AM
    #58
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  29. Jan 28, 2025 at 6:38 AM
    #59
    FishNinja
    Lee
    06DC2wd
    LMAO that looks like my first welded diff.
    ahhhhh the memories
    bmf4069[OP] likes this.
  30. Jan 28, 2025 at 6:39 AM
    #60
    That qualifies as
    Sirfive[QUOTED] and bmf4069[OP] like this.
