Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Jan 24, 2025 at 12:17 PM
    #3481
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yes, get your oil changes at a documented Toyota dealer and only run Mobile 1 0w 20 and the factory filter. This does not surprise me at all. You must have everything documented at the dealers are connected to one another and can see service history.
  2. Jan 24, 2025 at 12:22 PM
    #3482
    TRDoffroadPRO
    that is bad advice unless guy has little to no equity in it. I would definitely be listing it for sale or trading it in once I got it back.
  3. Jan 24, 2025 at 12:22 PM
    #3483
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    You cannot be forced to do service at the dealer. Total BS. As long as you have receipts & records, should not be an issue.
    AZBaldy, szabo101, 22whatwedo and 5 others like this.
  4. Jan 24, 2025 at 12:26 PM
    #3484
    AZBoatHauler
    So.Arizona
    I’d argue it’s bad advice no matter what unless you don’t need a decent credit score for the next 7 years.
  5. Jan 24, 2025 at 12:27 PM
    #3485
    TRDoffroadPRO
    True there is consumer protection that it shouldn't matter where you get your oil changed. However, in this case the dealer or TUSA said that was the issue.
  6. Jan 24, 2025 at 12:27 PM
    #3486
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Exactly. People love to add terms to a warranty. Just because you see a crappy dealer taking advantage of a guy doesn't mean the terms of the warranty have changed. Notice how the dealer can't point to anything specific the other shop supposedly did wrong. Like wrong filter, filter housing not correctly installed, no o-ring, etc.
    Nothing.
    Just "you did the last oil change somewhere else so we're voiding the warranty. You can pay for the new short block yourself if you want your truck."
    mayan and AZBoatHauler like this.
  7. Jan 24, 2025 at 12:28 PM
    Terndrerrr
    Music City
    6UR-FE
    This is
    • directly related
    • on topic
    • interesting
    and you're still gonna complain? :boink:
    Tunrod likes this.
  8. Jan 24, 2025 at 12:30 PM
    #3488
    AZBoatHauler
    So.Arizona
    Honestly I’d just file a lawsuit and let the dealer explain to Toyota what they did. Of course that does take some skills/knowledge but if they want to play, let’s play. My guess is Toyota would quickly agree to warranty the engine and pay the costs of the lawsuit.
    mayan and Terndrerrr[QUOTED] like this.
  9. Jan 24, 2025 at 12:31 PM
    #3489
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    There is always a back story that is not being shared. 3 sides to every internet story.-
    testerdahl likes this.
  10. Jan 24, 2025 at 12:32 PM
    #3490
    TRDoffroadPRO
    I have a 10 year 150k mile warranty via Assurant Platinum. I can guarantee you until that warranty is finished that I will only get oil changes and service at Toyota dealers. Some charge less than others and there is no set rate each dealer charges. I get my oil changed and tires rotated for 70-85 bucks at one dealer. The dealer I bought it from charges 100 bucks, but I will be getting that done at Toyota dealers.
    myfirsttundra1 likes this.
  11. Jan 24, 2025 at 12:35 PM
    #3491
    D_Money
    D_Money New Member
    23 Pro MGM
    My thoughts exactly…time will tell. No issues on my Pro yet…2/23 build date. I have babied it, done oil & all other recalls, just under 12k miles. I have an 03 Highlander with around 230k miles that I still use to offset miles on the Tundra, plus l can be tough on the Highlander, leave it places & not worry about it.
  12. Jan 24, 2025 at 12:40 PM
    #3492
    Terndrerrr
    Music City
    6UR-FE
    This is very different from my how I buy a Toyota: buy the vehicle and never return to the dealer ever again for any reason whatsoever. Factory warranty runs out having never been used.
    mayan, AZBaldy, szabo101 and 8 others like this.
  13. Jan 24, 2025 at 12:48 PM
    #3493
    TRDoffroadPRO
    Wow, gee you do not own a 3rd gen with launch issues. I have never changed the oil on my STI at the dealer. I have always done it myself. Of course, it is ten years old this year and only has 24k miles. I run Motul in it due to the stability of the oil for sitting long periods of time. I change it 2x a year and it is based upon time not mileage.
    Toyota has gotten more like the other manufactures regarding its customers, I do not or would not want to give them any reason to deny a valid claim. Lawsuits take years, warranty work takes a month or two.
  14. Jan 24, 2025 at 1:30 PM
    #3494
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    This story has a couple of issues. I can ALMOST guarantee that we are only getting half the story. The tech MAY have only drained 2 quarts of oil out of it for all we know. That being said the customer should not be on the hook. Should be Toyota or Take 5 paying for this
    AZBaldy, Raven67, FrankG and 2 others like this.
  15. Jan 24, 2025 at 1:48 PM
    #3495
    Terndrerrr
    Music City
    6UR-FE
    This is one of those things that the dealer could easily point to in order to show that Take 5 actually did something wrong. Again, if the oil level was wrong, if the wrong filter had been used, if the filter was cross-threaded, if the O-rings weren't in the right spot, etc, this would clearly show what Take 5 did wrong. But there is nothing from the dealer other than "it's Take 5's fault" without pointing to any reason why. That's ridiculous. Thus, it stands to reason that Take 5 did a proper oil change, and they even used an OEM filter.
    Toyota should 100% be on the hook for replacing this engine, and it should be a long block, not a short block. The customer is getting screwed twice: once by the dealer for shifting the blame with zero proof, and once by Toyota because engines are still failing outside the recall period.
    Breathing Borla likes this.
  16. Jan 24, 2025 at 1:48 PM
    #3496
    Breathing Borla
    Northern Illinois
    that was not advice, wasn't meant to be at all.
    I'll I said was I would be tempted to tell them to keep the MOFO, more of a joke in frustration.
    we all know that would be stupid, but also how most would feel at that point.
  17. Jan 24, 2025 at 1:52 PM
    #3497
    Breathing Borla
    Northern Illinois
    I wasn't complaining.
    cartage1 and Terndrerrr[QUOTED] like this.
  18. Jan 24, 2025 at 1:55 PM
    #3498
    Breathing Borla
    Northern Illinois
    and maybe a third time by Take5 when they deny they did anything wrong, which you know damn well they would, and maybe or maybe not rightfully so
    AZBoatHauler likes this.
  19. Jan 24, 2025 at 2:19 PM
    #3499
    katekebo
    katekebo [OP] New Member
    Without quotes, I'm going to address a few things discussed on the last two pages:
    - The case of the guy whose warranty has been denied. The dealer and Toyota would not deny warranty lightly given the sensitivity of the Tundra engine recall which has been all over the media. If they denied warranty they most likely have sufficient evidence to support the case. They would not expose themselves to more bad press and potential lawsuits without evidence. Do I trust the dealer? No. But I trust 90% of small, independent shops even less. There are some good independent shops, but most of them are just as bad as or worse than an average dealer. At least dealer has the manufacturer's pressure to fix things if they screw up. An independent shop will just tell you to take a hike and there is little you can do about it.
    - This is very interesting (see the highlighted part)
    Basically, Toyota is acknowledging that hybrid engines are failing, too, although they can get away without a recall because of the hybrid powertrain. But the this confirms that hybrids have the same problem.
    - Regarding the cost of short-block vs. long-block replacement for hybrids. Replacing the entire engine instead of having to pay the dealer to rebuild it is probably cheaper for Toyota. But the cost is not the only issue here. Building 100k engines is not trivial and splitting the workload between Toyota factory (building complete new engines) and dealers (for short block replacements) is a way to shorten the overall duration of the problem.
  20. Jan 24, 2025 at 3:17 PM
    #3500
    Raven67
    Kentucky
    I read somewhere, (I forgot where so don't wear me out) that Toyotas actual cost for these complete engines comes in at around $3000. I can believe this. I just wonder the difference in parts and more labor to do the short block replacement. They have it all down to a science when they have new engines rolling off the assembly line one every minute.
  21. Jan 24, 2025 at 3:36 PM
    #3501
    testerdahl
    testerdahl New Member
    Journalist
    I'd love to see the look on the repo dudes face. LOL
    Tundrastruck91 likes this.
  22. Jan 24, 2025 at 3:37 PM
    #3502
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Agree they must've found something odd for denial. Perhaps they found a low oil pressure event in downloaded ECU data and the owner kept it running. Also odd #5 rod bearing as most issues seem to be #1 or 4 crank bearing. Only Toyota knows.
  23. Jan 24, 2025 at 3:38 PM
    #3503
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    I do believe that it’s been established that there are in fact differences between hybrid and non hybrid long blocks. Might be part of the reason the short block had to be rebuilt since they don’t have the hybrids ready to go.
  24. Jan 24, 2025 at 3:41 PM
    #3504
    testerdahl
    Journalist
    Probably one of my posts or videos. That's the retail price, which I learned through a bunch of hate comments, is not the actual price. I don't think it is that far off though when adding in labor, transportation costs and time lost from the owner.
    One of my colleagues suggested the actual price of each engine would be just $5k. I LOL'd out loud at that idea. I just bought a 375 V8 for my '62 and it was $6,000. That's a real basic engine. I can't imagine a 2022 engine would be that cheap.
    AZBoatHauler and cartage1 like this.
  25. Jan 24, 2025 at 3:51 PM
    #3505
    Raven67
    Kentucky
    I was thinking of total COST to Toyota. It's cheap for them to manufacture these compared to what they cost consumers.
  26. Jan 24, 2025 at 3:54 PM
    #3506
    testerdahl
    Journalist
    I've thought about that as well. I did the math of $30k times 100,000 and that doesn't seem right either. In the end, I don't think we will ever know the actual true cost considering all the factors involved.
  27. Jan 24, 2025 at 4:05 PM
    #3507
    sudobash
    sudobash New Member
    Something interesting was just dropped by Toyota/Lexus.
    Special Service Campaign for the 2022-2024 Lexus LX 600 - 24LC04
    Retired...finally likes this.
  28. Jan 24, 2025 at 4:38 PM
    #3508
    Jaxyaks
    Jaxyaks New Member
    So Take 5 oil change did the oil change 1000 miles before the engine failed from lack of oil pressure...I think I would probably send the complaint/suit over to the Take 5 oil change place first. They are the last to touch the vehicle. I won't let any Take 5 car wash an and oil change touch my vehicles after one of them destroyed a transmission for me years ago. Luckily it was so obvious they had no choice than to pay a dealer to have a new one put in it.
    I had another one of those places put the wrong fluid into a rear differential once, again they bought me a new rear diff when it started causing issues.
    mrlittlejohn likes this.
  29. Jan 24, 2025 at 4:42 PM
    #3509
    Breathing Borla
    Northern Illinois
    They don’t have that around here, is take 5 like a super low end oil and lube type shop or something ?
    I wonder if they put the wrong viscosity in like something way too thick to get through this super tight tolerance motor by accident
  30. Jan 24, 2025 at 4:44 PM
    #3510
    Jaxyaks
    Jaxyaks New Member
    It is, like a Jiffy lube. I classify them all the same
    Terndrerrr likes this.
