  1. Jan 23, 2025 at 7:21 AM
    That amp isn't working? What's the goal?
  2. Jan 23, 2025 at 7:35 AM
    Elam.Pingleton
    Elam.Pingleton 1st Gen 04 2WD V-8 DC
    Elam
    Nashville Area
    2004 Tundra DC Limited
    The amp doesn’t work. The goal is to have a radio that works.
  3. Jan 23, 2025 at 7:35 AM
    Install a new amp there?
  4. Jan 23, 2025 at 7:52 AM
    Elam.Pingleton
    Elam
    Nashville Area
    Don’t really see the need to spend money on an amp. I’m cool with a radio and speakers. My radio has a decent built in amp
    The Black Mamba likes this.
  5. Jan 23, 2025 at 7:56 AM
    Depending on how they went about adding that amp, replacing it with a working one may be your path of least resistance.
  6. Jan 23, 2025 at 7:59 AM
    Elam.Pingleton
    Elam
    Nashville Area
    That is true. This went to a weekend project now.
  7. Jan 23, 2025 at 8:23 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Anyone have a photo of an access cab rear door with the interior panel removed?
    My rear doors are doing the things where the top latch won't click. I've cleaned and degreased in there but I want to attach a supplemental spring to ensure proper function. Too cold outside to remove one of my door panels right now.
  8. Jan 23, 2025 at 9:06 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Electric Window and Door Lock Conversion | Toyota Tundra Forum
    3RD AND 4TH pic down
    FiatRunner[QUOTED] likes this.
  9. Jan 23, 2025 at 9:07 AM
    FiatRunner
    Jack
  10. Jan 23, 2025 at 10:06 AM
    More shots with speaker out if needed: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1788#post-3420265
    And in case you ever wanted to shove a 6x9 out back, here's some measurements on that one: https://www.tundras.com/threads/100-series-convert.135252/page-2#post-3434487
  11. Jan 23, 2025 at 10:13 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I do. Next time the panels are off.
  12. Jan 23, 2025 at 1:24 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That's a really nice amp, hopefully you can get it to work. Dumb question but have you checked if the amp has a fuse?
  13. Jan 23, 2025 at 2:25 PM
    I'm actually very curious, I know some other Toyota models (Tacoma, 4Runner?) use a 6x9 or similar in some years, and I had my suspicions after seeing one on an auction site (SGW), it looks like it would bolt right into our AC doors.
  14. Jan 23, 2025 at 2:43 PM
    Check the 30A fuses to make sure neither popped - this may be a simple solution.
    Likewise, check the power cable coming off the battery. It should have an inline fuse too. It might have popped ... it happens.
    Either may be a quick and easily solution to get working again with little to no work.
    If not, everything you need to make yourself whole is right there. Given the specs on your amp, 4 channels, 88w per channel, there are a shitload of great options, and you clearly have a beefy power and ground there, so 99% of the hard work is already done for you, and this is an awesome opportunity to upgrade to a 5-channel amp and add a small sub!
    I see the previous owner ran their own speaker wiring, so you'd want to look if you see similar speaker wire at the factory amp on the back wall, driver's side. If not, or there is no amp, I'd pop off my passenger side kick panel and look for those wires going into the door grommet, it'll be blatantly obvious.
    I personally love JL Audio but I can't possibly expect anyone to pay that pricepoint. If you want something in the ballpark of power that adds sub option with all the crossover flexibility (take a clear pic of current crossover settings, all the dials and switches before uninstall):
    I didn't run the numbers on those to check dimensions, just basic specs. I can't vouch for the Kenwood, but everything else up there will do you right and will be good quality.
    Here's the thing: They've already run the RCA cables. They're run power and ground. They've run speaker leads. That gives you two options:
    1. Do a hell of a lot of unwiring to reverse all that stuff, then install whatever you need to get whole again (minus the amp), including pulling out all that power/ground wherever it may go.
    2. Mark your wires and photo of the amp settings, pop off the negative battery cable, uninstall the amp, install existing wires to new amp, and you're in business.
  15. Jan 23, 2025 at 2:50 PM
    The radiator outlet sticking out of the box looks promising.
  16. Jan 23, 2025 at 2:54 PM
    It’s gotta breathe you know. ;)
  17. Jan 23, 2025 at 3:01 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  18. Jan 23, 2025 at 3:03 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I bought this heavy piece of steel on the way home today
  19. Jan 23, 2025 at 3:49 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Anyone know what the two transmission lines running to the bottom of the radiator are called? Or a pn?
  20. Jan 23, 2025 at 4:27 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    ‘Grandmas’ bday present. Lol. Got some inch thick ribeyes for tomorrow.
    bfunke, bmf4069, JasonC. and 5 others like this.
  21. Jan 23, 2025 at 5:35 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Warn recommends periodically washing you synthetic winch rope. I never knew that. Did that this evening. The dirt that came out, even after 3 rises, was nasty. Rope build date is 11/22.
    https://www.warn.com/how-do-you-mai...e=1&gbraid=0AAAAAqQLGAPl_LoYmUBSG_hsMJjvzpOnH
    Synthetic rope does require a bit more care than steel. One of the things you can do to promote long synthetic rope life is to wash the line. To do this, simply unspool the rope, get a bucket of water with a mild detergent, such as dish washing liquid, and dunk sections of the rope. Push the rope together in the water freeing up any grit, then move onto a new section. Then respool the rope onto the drum under tension to ensuring an even spooling.
  22. Jan 23, 2025 at 6:12 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    wind it with kinetic rope, so once you’re unstuck you can slingshot over the next obstacle.
  23. Jan 23, 2025 at 6:25 PM
    #Wizardlevel
  24. Jan 23, 2025 at 6:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Snorkel
  25. Jan 23, 2025 at 6:57 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    time!
    2.5 beer job.
    Had to take a 30 min break to air up the golf cart tires and go check the mail.
    gonna pick up some paint tomorrow, what color should i paint the ‘hubcaps’?
    if this was a mod party half of the screws would have gotten dropped through the deck and this easily would have been a 2.5 case job.
    Dammit this thing kinda sucks. Been cranked full blast for 30 mins & its barely over 200*. Gonna have to remove one (or 2) of the burner tents.
    bmf4069, FrenchToasty, BroHon and 2 others like this.
  26. Jan 23, 2025 at 7:00 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I posted last week my radiator box was pretty ragged from rock auto too. Will see how it goes. Did you get all new hoses too? I’m looking for the rubber hoses that come out of the hard transmission lines that feed into the radiator before I change mine out. I know they will crack when I remove them.
  27. Jan 23, 2025 at 7:15 PM
    Gold. Always gold. Gramma's worth it.
  28. Jan 23, 2025 at 7:27 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  29. Jan 23, 2025 at 7:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    bmf4069, KNABORES, BroHon and 2 others like this.
  30. Jan 23, 2025 at 7:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
