Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Jan 18, 2025 at 3:07 PM
    #631
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Haha well I will say I wasn’t ready for it to be so aggressive. I was coming out of the turn with some throttle and with the roads a little wet she started to come around.
    Mdl and bflooks[QUOTED] like this.
  2. Jan 18, 2025 at 3:25 PM
    #632
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's what I've been saying. You need to get used to the preload and how it will respond to your throttle input.
    blenton and Abell207[QUOTED] like this.
  3. Jan 18, 2025 at 3:37 PM
    #633
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Yes it definitely changes the way you need to drive when coming out of a turn. I’ve never had a rwd vehicle with a lsd. Only on awd and fwd.
    Mdl[QUOTED] likes this.
  4. Jan 18, 2025 at 4:09 PM
    #634
    blenton
    blenton New Member
    I’m excited to see the difference between the Speedmaster and the auburn. Wonder how much more aggressive the Speedmaster will be. My ‘21 is still stock open and it’s driving me bonkers driving around in the snow and ice doing the one wheel peel at every stop sign. Doesn’t help that the bed is completely empty. Might as well toss a grip pro in that one so I can compare all three setups!
    Mdl likes this.
  5. Jan 18, 2025 at 4:12 PM
    #635
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I’ll be able to test that out Monday when we get some snow here. Been a weird winter for us in Maine.
  6. Jan 18, 2025 at 6:34 PM
    #636
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Full spool should be fun lol
    Mdl likes this.
  7. Jan 19, 2025 at 12:03 AM
    #637
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Lots of fun full spooling it!
    reywcms likes this.
  8. Jan 23, 2025 at 10:21 AM
    #638
    blenton
    blenton New Member
    Bearings finally showed up yesterday. We were able to setup the factory gears with the new Speedmaster. Owing to reusing the factory gears, we were able to reuse the factory shims all around! So machining tolerances on the Speedmaster look to be pretty good (same with the Auburn it replaced). We marked the pattern, for which my buddy was kind enough to give me a little education.
    Compared to what you would find in a manual, the pattern looked a little narrow to me, so I asked him about it. He noted that because the gears are used gears, they are going to mark differently than a new set. The wear is concentrated more on the middle of the tooth (an indication that he set them up correctly 140k miles ago as well!) and actually forms a little bit of a scallop or rut on the teeth - a virtually microscopic rut that you can see with your marking compound but can't feel with your fingernail or hands. This leads to a smaller wear pattern when setting up the gears again.
    The important part is WHERE the pattern in marking - middle of the tooth is perfect, depth wise (or laterally oriented with the axle shafts, if that makes sense). Due to the way the gears mesh and basically roll - being hypoid gears and not straight cut gears - the pattern will roll off the outside edge of the tooth, but shouldn't mark too far inside the tooth (toward the center of the carrier). I checked the marking on the pinion gear and it had polished itself on the center of the teeth, but you could see unpolished material on the other edges of the tooth, indicating a good centering and alignment with the ring.
    Hopefully that's helpful if you need to setup your gears after initial break-in as the pattern can change a little bit from what you'd see with brand new gears.
    Oh, and he harped about Maintenance! Maintenance! Maintenance! He was truly impressed with the condition of the gears and differential case, attributing it 100% to me changing the oil often. So pat on the back for me :)
    Mdl, reywcms, Abell207 and 1 other person like this.
  9. Jan 23, 2025 at 6:55 PM
    #639
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Shout out to Bob at New England Gear Polishing. They did an awesome job with a day turn around. I had a few credits on Amazon so went ahead and picked up another rear set and had them sent to NEGP. Will send out my used gears that are whining at 60mph to get them polished. Will get em swapped out soon.
  10. Jan 25, 2025 at 3:24 PM
    #640
    blenton
    blenton New Member
    First drive with the Speedmaster: I love it. It feels just like a stock open diff when cruising around making slow turns. Get on it a little and you can feel it looking for traction. Very few miles so far and I haven’t really gotten on it yet, but I notice the difference already.
    The Aurburn behaved the same way on power, but slow speed turns were a little clunky and felt like you had a brake dragging just a little bit. The Auburn was great, with a few minor compromises. The Speedmaster feels much smoother. Im excited to see how it behaves in various situations.
  11. Feb 7, 2025 at 1:25 PM
    #641
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Finally called Outlaw Off-road in Nashville. I asked for an install quote for my ‘21 SR5 with me supplying front and rear gears and master kits as well as the Speedmaster limited slip. They said they’d send me an email and I’ll need to confirm the p/n’s of what I bought to make sure I got the right stuff, and they’ll reply with the labor quote.
    I also asked if they knew anyone locally who would polish the gears. They said with their install, it’s not needed, since they break them in with 3 or 4 drives. Included in the install is me bringing it back after 500 miles for them to check lashing and swap gear oil.
    Waiting on that email…
    reywcms, FrenchToasty and AZTundra like this.
  12. Feb 7, 2025 at 5:33 PM
    #642
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Do they have to pull both diffs out to check the lashing?
  13. Feb 8, 2025 at 4:41 AM
    #643
    Terndrerrr
    Music City
    6UR-FE
    I’ll have to ask once I hear back from them
  14. Feb 8, 2025 at 12:55 PM
    #644
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Same question came up as soon as I read that.
    My money says they’ll grab the pinion and wiggle it.
  15. Feb 8, 2025 at 2:15 PM
    #645
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are you getting loud clunks from diff not whine? No backlash can cause whine and excessive youll hear the clunk. To an extent you can grab the yoke but if it's clunking it should be pulled. Bearings and gears inspected and backlash checked with a dial micrometer.
    reywcms likes this.
  16. Feb 8, 2025 at 2:18 PM
    #646
    ZPhilip
    Philip
    West Chester, PA
    I’m not getting any noise, I haven’t put in the gears yet. I was initially asking @Terndrerrr about his installers process.
  17. Feb 11, 2025 at 1:24 PM
    #647
    Terndrerrr
    Music City
    6UR-FE
    Got my estimate from Outlaw Nashville.
    Seems high to me. Gonna shop around.
    This is to install front and rear Motive gears with the Yukon install kits and speedmaster limited slip in the rear—all customer supplied.
  18. Feb 11, 2025 at 1:37 PM
    #648
    bflooks
    bflooks New Member
    Metrowest MA
    That's just labor? I paid right around $2k even for labor up here in MA. I supplied the gears and install kits.
  19. Feb 11, 2025 at 2:00 PM
    #649
    Terndrerrr
    Music City
    6UR-FE
    Yep. That line “total fees” is other unspecified stuff, probably mostly gear oil :notsure:
    The discount is for the free 500-mile gear inspection and refill of gear oil.
  20. Feb 11, 2025 at 4:15 PM
    #650
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Do they pull the rear diff to inspect gears?
  21. Feb 11, 2025 at 4:29 PM
    #651
    ZPhilip
    Philip
    West Chester, PA
    Does seem high for just labor and misc parts. But maybe not if they are quoting pulling the diffs out again to check everything over.
    Mdl likes this.
  22. Feb 11, 2025 at 8:02 PM
    #652
    Terndrerrr
    Music City
    6UR-FE
    The labor quote is for 18 hours of labor @ $149/hr.
    And they said the 500-mile check up includes:
    • drain of differentials
    • remeasure of backlash
    • refill of differentials
    That doesn’t really specify if they pull the rear diff, though.
    Also included in the quote was another approve or decline job for an 8” readylift (lol) @ $5700 plus tax and a cab mount relocation @ $1100. :laugh:
  23. Feb 12, 2025 at 6:45 AM
    #653
    enve46
    enve46 New Member
    Andrew
    Give True Blue Truck in Murfreesboro a call. They did gears on my AEV PXL and were great to deal with. Im waiting on a quote for gears on my new to me LSK long travel tundra. Im in Franklin area and called around to all the local diff/transmission shops, every one of them suggested True Blue so that's where I went. Owner drives a heavily modified Lexus GX
  24. Feb 19, 2025 at 7:29 AM
    #654
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    My gear install keeps getting pushed back, hopefully will be dropping off the weekend of 2/29. I was worried about my polished gears sitting around getting rusty. I had them stored in a cold detached garage so was hoping the humidity was low enough it wouldn’t matter. I pulled them out and checked and they’re still looking shiny luckily. I coated them with some gun oil for the time being. I’m guessing if it were summer time it could have been a problem. Waiting is hard!
    Mdl likes this.
  25. Feb 19, 2025 at 8:07 AM
    #655
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    2028?!? JK, hopefully it doesn't keep getting pushed back
    Silver17[QUOTED][OP] and bflooks like this.
  26. Feb 19, 2025 at 8:11 AM
    #656
    bflooks
    bflooks New Member
    Metrowest MA
    That's funny! I get it, life and all, priorities, peer pressure, etc. etc. etc. Still funny. :)
    Silver17[OP] likes this.
  27. Feb 19, 2025 at 8:38 AM
    #657
    Silver17
    Eastern PA
    Everyone talking about their mad 5.29 power in other threads just has me excited.
  28. Mar 4, 2025 at 9:45 AM
    #658
    Terndrerrr
    Music City
    6UR-FE
    Got another quote from a shop in the Nashville area. This one is $3500 after tax.
    That’s just labor and gear oil.
    This seems nuts to me.
    Mdl likes this.
  29. Mar 4, 2025 at 10:27 AM
    #659
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Man...a nice work shop would be sweet!
  30. Mar 4, 2025 at 11:11 AM
    #660
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    Has anyone gone through the process of swapping both front and rear diff assemblies with new ones from ECGS with gears and/or lockers already installed?
    Installers near me are either extremely expensive, have no clue what they are doing, or a mixture of both lol
    The ECGS 9" front clam shell diff for $2500 with new seals, bearings, gears of whatever ratio wanted, and an E-locker seems like a pretty good deal to me.
    Not sure how much a rear end would be I couldn't imagine it being much more with just a Grip Pro and gears.
