285/75R18 vs 285/70R18 - Thoughts for TRD Pro
Discussion in 'Wheels & Tires' started by overl4nd, Jan 26, 2024.
  1. Feb 5, 2024 at 3:39 PM
    Breathing Borla
    Northern Illinois
    holy shit, those nittos are 63.6 lbs, lol
    pursuit2550 likes this.
  2. Feb 6, 2024 at 10:24 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Me too I wanted 18" rims the second I bough my truck.... I swapped to 18" TRD pro rims at 240 miles on the truck. 20" rims are terrible on a truck unless you can get at least a 35" tire on them to smooth out the ride. I keep it to stock tires sizes and 18" rims are where its at....sooo much better ride when you hit bumps and pot holes.
  3. Feb 6, 2024 at 5:46 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    It’s true. Sidewall isn’t just for off-roading.
    Tundrastruck91 likes this.
  4. Feb 6, 2024 at 6:24 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    One of the reason I dont go higher or wider than what I got. I run BFG KO2 275/70-18(33") and they are 60lbs I believe.
  5. Feb 6, 2024 at 6:28 PM
    pursuit2550
    Do a search on the previous gen. It will give you an idea of going from OEM size to a 33" or 35". When you get into the sizes mentioned, they are usually E-rated tires. Very heavy compared to OEM. Not only not good for MPG but not easy on the suspension parts either.
    Breathing Borla likes this.
  6. Mar 3, 2024 at 9:34 AM
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    Looks sweet, no rub?
    I’m going BFD’s 18x9 +20 and thinking Cooper Discoverer AT3 XLT’s 275/70/18.
    TundrX[QUOTED] likes this.
  7. Mar 3, 2024 at 11:19 AM
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Thanks! If I’m in full articulation going faster and hitting a bump, I might. Everything is good. Here are some photos reversing on an incline.
    Front liner
    Body mount side
  8. Nov 24, 2024 at 7:53 AM
    johnejo
    johnejo New Member
    Southwest New Mexico
    2021 Tundra Double Cab SR5 2WD; 2024 Tundra Crewmax SR5 4x4
    Hi, everyone. I just bought a ‘24 SR5 Crewmax 4x4, non TRD or Pro. It came with 265/70/18’s, but I’m looking at getting a taller tire simply because I want a more accurate speedometer. I hate not having an accurate speedometer. I’m thinking of 285/70/18’s, which should get the speedometer almost dead on without any trimming or modifications, which means I’ll be getting a more accurate MPG, though it would be “lower” than what I’m supposedly getting now. Any thoughts on that.
  9. Nov 24, 2024 at 8:09 AM
    Breathing Borla
    Northern Illinois
    isn’t that the stock size?
  10. Nov 24, 2024 at 11:39 AM
    johnejo
    johnejo New Member
    Which one? The stock size for that truck was 265/70/18.
    Apparently Toyota sets the speedometers 1-3 MPH faster than what it’s actually doing. I found that out with my ‘21 Tundra. I actually got a device to calibrate the speedometer of the ‘21 because of that very issue, especially when I realized I was going through my warranty miles much faster than I actually was doing (these are service trucks on the highway a lot).
  11. Nov 24, 2024 at 11:46 AM
    Breathing Borla
    Northern Illinois
    I’ve never heard that before about Toyota speed being1-3 faster:monocle:
  12. Nov 24, 2024 at 4:13 PM
    johnejo
    johnejo New Member
    Yea. Use a GPS app on your phone and see what it brings up. Even check those radar signs as well. I learned Toyota was not calibrating speedometers on their trucks based on the different tire sizes they came with but instead had one setting for all of them, which is why they are designed so even dealers cannot adjust them. I later read that they make them faster on purpose, something to do with selling them in other countries. How much of that is true or not, I don’t know, but I know from first hand experience the speedometers in their trucks are not accurate and shows speeds higher than they are actually going, which increases MPG and quickly exhausts warranty’s based on miles driven.
  13. Nov 25, 2024 at 6:58 AM
    teab
    Ty
    Denver
    Wow!!! I had to log back into my account to address this level of stupidity all the tires that come stock are nearly all the exact same diameter (sure if you're going 200mph there's a difference there)...
    18's compared between Pro and SR5 18's
    SR5 18's and Platinum/TRD OR/1795
    SR5 18's and Capstone
    SR5 18's and SR 18's..
    Now to go back in the shadows...
    GPS and speed signs are exactly the same as my Speedo so I have no F-ing idea what you are talking about.
  14. Nov 25, 2024 at 4:59 PM
    Tyrus001
    Tyrus001 New Member
    Ty
    2021 Crewmax
    I’m in the same boat. 285/70 Toyo or 285/75 Coopers. Practically same weight. 2021 Crewmax w/ 2” in front. 1” rear
  15. Nov 26, 2024 at 7:22 PM
    johnejo
    johnejo New Member
    Well, that’s fine. I just know of my personal experience with both a 2021 and a 2024, both of which came with stock tires, looking at radar signs and GPS apps, as well as my own personal interactions with Toyota. Have a good day!
    AZBoatHauler likes this.
  16. Jan 22, 2025 at 6:22 PM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    285/75r18
    BFG KO3
    2” spacer lift
    upgraded from 285/65r18 KO2
  17. Jan 22, 2025 at 6:33 PM
    AZBoatHauler
    So.Arizona
    Not a Pro but 2” of lift up front and an extended shackle in back.
    285/70 18
    285/75 18
  18. Jan 22, 2025 at 6:46 PM
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Suspension air bags for better towing.
    So I have the advantage of having a 2021 Tundra TRD Pro Double Cab, and my brother has a 2023 Tundra TRD Off Road Limited 4x4. So we are able to compare the 2.5 and the 3rd gen trucks pretty closely. We both have 285/70/18 Nitto Ridge Grappler's on our trucks. I average around 15 city and about 17-17.5 highway (flat). He gets around 15-15.5 city and 19-20 highway (flat).
    The big difference is I have a 4.30 rear end and he has that weak 3.31 rear end, so turning those heavier tires is harder on his truck than mine. In fact, he only recently put his tires on after about a year of ownership, and he says he notices the turbos run a lot more than they did before hence his MPG dropping 2 mpg. The great news about this size on both trucks no rub, look great, give the truck a nice 1 inch lift brand new due to the size increase (diameter). So far on my Ridge Grappler's I have 63,158 miles as of today, and I am hoping to make it to 4th of July tire sales. I am hoping with President Trump going back to drilling oil, the price of these tires will come down a bit by July. Hell, I paid $281 a tire in June 2021. Now those effing bastards are $422.00 a tire thanks to Bidenflation.
  19. Jan 22, 2025 at 7:26 PM
    Breathing Borla
    Northern Illinois
    Weak 3.31 rear end?
    you can’t just look at the rear end numbers only like that and draw that conclusion based on rear end gearing , there is transmission ratios that need to be factored in
