General Supercharger Thread
  1. Jan 20, 2025 at 12:33 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I think there were a few rebuilt injector options that look stock (same tan color) vs the trd green ones. My precision 750s are black I believe and have an obvious wiring harness. I would doubt that’s the case with these SC asking for tunes though, likely lazy techs doing the install.
    Now you got to wonder if the fuel pump was replaced too haha.
    koditten likes this.
  2. Jan 20, 2025 at 6:39 AM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    Magnuson 1900’s in both of these instances.
    I know the base Harrop kit comes with no injector.
  3. Jan 20, 2025 at 6:44 AM
    TurboKits
    TurboKits New Member
    Whoa, interest peeked... Please let us know as well!
    :benchpress:
    HulkSmurf14 likes this.
  4. Jan 20, 2025 at 11:17 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Just dropped off my 21 for Magnusson 2650 install.
  5. Jan 20, 2025 at 11:42 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Good luck wiping the smile off your face for a month! It's going to feel like your first girlfriend made you feel!
  6. Jan 20, 2025 at 1:12 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    So those with the DW FPR what setting do you have it on and is it contributing to any issues on your build?
  7. Jan 20, 2025 at 1:13 PM
    Saltyhero13
    Those with the AFR oscillation are you all running LTH?
    What are the fixes?
    Raise idle?
    Move O2 loc?
  8. Jan 20, 2025 at 1:22 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nope no issues set at stock psi
  9. Jan 20, 2025 at 1:24 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    What are you seeing as oscillating afr? Afr will normally bounce back and forth within a range of course at idle, normal driving. During wot should hit the commanded afr etc
    e30cabrio, Saltyhero13 and Wynnded like this.
  10. Jan 20, 2025 at 1:31 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have mine set to the stock pressure currently, or as close as I can get it with the gauge. I still have a couple odd things that I'm wanting to try to find the time to dig into, but nothing that I can definitively say are caused by the DW FPR. The odd things are buzzy fuel lines on a warm start that go away after about 30 seconds, which may be that they're loose somewhere I can't see without taking off my cat shields. The other thing is I started having the occasional longer warm crank, but it's as of yet not needed a second crank to start. It's always starting on the first try. I just haven't had the time to really dig into the issues to find the root causes. They may not even be related, just coincidental.
  11. Jan 20, 2025 at 1:46 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It will be there a month tomorrow, but the body work is done & the motor is finally out.
  12. Jan 20, 2025 at 1:58 PM
    Saltyhero13
    It is just a general question to understand what is normal operation and what are indicators of potential problems.
  13. Jan 20, 2025 at 2:01 PM
    Saltyhero13
  14. Jan 20, 2025 at 3:36 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Not much to update, no issues since I got my belt alignment sorted. Truck has been running great.
  15. Jan 20, 2025 at 3:51 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    My AFR oscillates when idling in Park, running ARH long tubes, not sure of a fix but also not sure it's a problem other than an irritant...maybe fouling the plugs? Like I mentioned before, I had LTH before the supercharger and didn't experience this, it started acting this way after tuning for injectors with the SC installation.
    Saltyhero13[QUOTED] and Mdl like this.
  16. Jan 20, 2025 at 4:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Lth, referenced for 43-55psi under boost. Afr at idle 13-14.6. Primary O2's about 12 inches from manifold, wideband about 20 inches.
  17. Jan 20, 2025 at 4:59 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I found one of the logs showing the AFR swings, only happens when in Park, Idling, under 160*, my sensors are in the collectors pointed at the collector...which is not ideal from what I've seen. Fuel pressure is boost-referenced at 43.5PSI base (MPVI2.2 in pic). This log was also taken when I had the vacuum leaks that I recently fixed...I really need to get a fresh one.
  18. Jan 20, 2025 at 5:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Is anyone else logging both Narrow Band O2 sensors, and are you seeing similar? Long Tubes or not.
  19. Jan 20, 2025 at 5:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'll dig one up.
    **Nevermind me! It's just a jagged signal! No oscillation so disregard...
    Wynnded and HulkSmurf14 like this.
  20. Jan 20, 2025 at 6:14 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    My last log they did the squiggles like that for a few seconds, and the rest of the log they matched each other pretty closely. FWIW, the wideband oscillated in little waves that followed the EQ#2 squiggles
    Wynnded likes this.
  21. Jan 20, 2025 at 6:33 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Mines setup like this too and get the oscillation at warm idle. Cold idle is perfect AFR so the engine can obviously idle “correctly”. I believe my front 02s are at the collectors, back 02s past the cats and the AFR gauge on one of the primaries.
    I may experiment with switching the 02s to the primaries so they are closer since there is no “distance” tune adjustment available to us.
    Looking at HP tuners again there is a separation of idle vs non-idle closed loop, so we could push the closed loop idle parameters so that you are never in closed loop at idle, while theoretically using closed loop for all other situations. For example making the LTFT airflow min idle way higher than possible during idle I would assume could accomplish this. Or make the min idle values very high.
  22. Jan 21, 2025 at 5:32 AM
    TurboKits
    Space out the Park Idle and the Gear Idle targets so they fall into different cells within the MAF voltage scale, then adjust the voltage to bring the trims in line. Most likely its fighting trims learned in gear - vs - in park, so it's constantly learning up and or down at the same spot. I know it doesn't make sense, as in gear it should be under a different load, but I have seen this on a few trucks and spaced out the P idle and the D idle and had success.
    Wynnded, reywcms, Mdl and 4 others like this.
  23. Jan 21, 2025 at 6:09 AM
    nags
    nags New Member
    My poor GX motor
    Wynnded, Saltyhero13, reywcms and 2 others like this.
  24. Jan 21, 2025 at 6:18 AM
    HulkSmurf14
    2014 Tundra Limited
    Happy things coming though, right?!
  25. Jan 21, 2025 at 6:22 AM
    nags
    nags New Member
    Hopefully no more oil leaks when we're done. On my second leak now. Shop owner, who I'm close with, wanted to just pull the motor and re-seal absolutely everything possible to avoid more in the future after fixing the current one.
    reywcms likes this.
  26. Jan 21, 2025 at 6:28 AM
    HulkSmurf14
    2014 Tundra Limited
    By far, the best way to ensure it's as tight as a frogs ass!
    M3Tundra-JK and nags like this.
  27. Jan 21, 2025 at 6:29 AM
    nags
    nags New Member
    Just how I like my asses.
    Between this and the brand new tranny... I'm hoping this is the end of it and this thing goes on forever.
    reywcms, e30cabrio, Mdl and 1 other person like this.
  28. Jan 21, 2025 at 7:55 AM
    e30cabrio
    Anyone know of a Geared Rotating Head add on for a standard engine stand that can keep up with a 3UR-FE ? Not looking forward to dealing with the motor in the normal fixture.
  29. Jan 21, 2025 at 7:57 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    My friend has one that came on a stand from HF and he had a Duramax on it and said it handled it fine
    e30cabrio[QUOTED] likes this.
  30. Jan 21, 2025 at 8:03 AM
    e30cabrio
    I have seen that on their stands but don't see the rotating part alone. I got the idea from I do cars tear down videos, he has a HF stand with it.
