  1. Jan 18, 2025 at 5:56 AM
    Front no. Rear yes, but it was part of the rear bearing replacement l
  2. Jan 18, 2025 at 9:13 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Gave mine a nice wash yesterday followed up by 3 cans of fluid film to freshen her up. No rust on my watch.
  3. Jan 18, 2025 at 10:15 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Replaced the battery. Not sure how old it was but it was slow cranking on these colder days. Also just ordered new spark plugs and and a PCV valve from Toyota, not sure when they were last replaced last.PXL_20250117_185942875.jpg
  4. Jan 18, 2025 at 10:37 AM
    mcmilla.project
    mcmilla.project New Member
    2005 Toyota Tundra
    Did lots of stuff in this video. Basically, a new front end.
    Upper Control Arms - OE
    Upper Ball Joints - OE
    Lower Control Arms -OE
    Lower Ball Joints - OEM
    Front Socks - Bilstein 24-185387
    Outer Tie Rods - OE
    https://www.youtube.com/watch?v=pgAqF9w4XFU
  5. Jan 18, 2025 at 10:53 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    A Mod party used to something COMPLETELY different
    https://en.m.wikipedia.org/wiki/Mod_(subculture)
  6. Jan 18, 2025 at 12:14 PM
    Me too. Foam cannon and rinse, then PB Blaster the rear axle and brake bits
  7. Jan 18, 2025 at 1:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Jan 18, 2025 at 2:17 PM
    Welcome to the club!
    Tundra2[QUOTED] and FrenchToasty like this.
  9. Jan 18, 2025 at 2:56 PM
  10. Jan 18, 2025 at 3:34 PM
    whodatschrome
    lots of dents
    A few of my buddies do the same thing, but whenever they actually want something accomplished, they just drop their bikes off at my shop and leave.
  11. Jan 18, 2025 at 3:40 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I always hit the target, but i might wanna stay an extra day to clean things up. At panhandlemonium i wasted the cleanup day driving through palo duro state park.
  12. Jan 18, 2025 at 4:45 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome! Now go get the sticker
  13. Jan 18, 2025 at 5:33 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yoinked the chrome bumper strip that I painted previously. Needs refinishing as it was starting to chip a lot.
    Adjusted the drum brakes.
    Checked the LBJ for play. Zilch.
    bmf4069, shifty`, G_unit3000 and 3 others like this.
  14. Jan 18, 2025 at 5:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Link?
    G_unit3000[QUOTED] likes this.
  15. Jan 18, 2025 at 6:32 PM
    bfunke
    bfunke Tundra Curmudgeon
  16. Jan 18, 2025 at 6:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    bmf4069[QUOTED] likes this.
  17. Jan 18, 2025 at 6:51 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @bmf4069 bruh, I know I haven’t been around much, but I didn’t know you completely gave up on us, like this. It was your fucking calling bro. I feel like I don’t even know you anymore. Where is your 1st gen pride son? Geezus. :facepalm:
    shifty` likes this.
  18. Jan 18, 2025 at 6:54 PM
    whodatschrome
    lots of dents
    I wonder if the “magic” behind that kit is just a small inline resistor? At least that what it is for The KTM twin cylinder motorcycles. I remove the SAS (secondary air system) from my ktm 990 Adventure and simply soldered in a 10¢ 2.2k ohm resistor, rather than buying a more expensive premade kit. Then again i wasn’t really doing it to save money, i just wanted less “bulk” hanging off the main wire harness, so the resistor was installed inside the main harness’s loom.
    NUDRAT and G_unit3000 like this.
  19. Jan 18, 2025 at 7:04 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    So, I was driving earlier today and started hearing a screeching of some kind, sounding like belt or bearing. Initially, it would come and go, kinda, but didn’t sound horrible and my power steering was still working, so I figured it was safe to drive the 3 miles home to check it out. Parked and let it cool for a 1/2 hour or so, but when I restarted the truck, it screamed like a banshee. Took a look and saw the belt wasn’t running, so quickly shut her down. Before I get into pulling the belt and checking pulleys/bearings, anyone wanna tell me somethin I don’t know or take guesses what the problem is? Evidently, one of the accessory’s has seized up itself, or has a seized bearing. Not sure which
    Edit for tags
    @shifty` @The Black Mamba @FrenchToasty @des2mtn
  20. Jan 18, 2025 at 7:11 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Question: is there any reason I shouldn’t pull the accessory belt off and drive the truck? Other than the obvious lack of power steering issue?
    Edit for tags
    Anybody else’s help is also welcome. I know there are many knowledgeable folks on this forum and can’t go tagging everyone that can turn a wrench
  21. Jan 18, 2025 at 7:17 PM
    And lack of alternator
  22. Jan 18, 2025 at 7:22 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Right:facepalm:
    I’m gonna be the bigger man and not delete that post.:tinfoilhat:
  23. Jan 18, 2025 at 7:24 PM
    Something is stuck bad on your accessories, it shouldn’t be hard to figure it out. It’s probably your idler or tension pulley
  24. Jan 18, 2025 at 7:34 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    That would be best case scenario. I’m gonna push on the tensioner pulley and turn the crank and see what doesn’t move, I guess.
  25. Jan 18, 2025 at 7:34 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Tensioner pulley is a 14 mm right?
  26. Jan 18, 2025 at 7:40 PM
    Just pull the belt completely and start turning things by hand
  27. Jan 18, 2025 at 7:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I’m down to host one over The weekend at my warehouse in LA. I got 4 parking spaces
  28. Jan 18, 2025 at 7:56 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    To pull the belt, you’ve gotta put a 14 mm socket in the tensioner. Yes it’s a 14. AND it was the tensioner pulley bearing that seized. Looks like I can just pop the bearing out of the pulley. I’ll have to inspect my belt as well, but I think I caught it in time.
  29. Jan 18, 2025 at 9:19 PM
    Glad you got it figured out! I’m glad @FrenchToasty beat me to it.
    I linked instructions for a DIY bypass that costs all of like $10 in the megathread if you want to review what’s in one of those kits.
  30. Jan 19, 2025 at 6:00 AM
    The tensioner is kind of a pain to replace. To remove it, you have to unbolt and slide out the alternator and power steering pump. Plus the timing belt covers.
    Just pointing that out in case you've got any other parts due in that area.
