  1. Jan 14, 2025 at 5:49 PM
    Both brands can be bought with stainless heat exchangers.
  2. Jan 14, 2025 at 7:29 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    At the price I’m seeing in the Navien units - Holy crap on installing two of them! :eek2:
    I see that the Rinnai RXP can be bought with a recirc integrated - definitely been some upgrades to the designs in the 18 years since we installed ours.
  3. Jan 14, 2025 at 7:31 PM
    Yeah, I was stoked there wasn’t an extra caddy or tank. But I may ask about upgrades there. Maybe it’s something to add later.
    TaquitoBandito likes this.
  4. Jan 14, 2025 at 7:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve been thinking about relocating mine from my basement to my garage. Luckily I can handle the piping myself.
  5. Jan 14, 2025 at 8:40 PM
    TaquitoBandito
    Joel (AKA Bif)
    I don't know man. I've been friends with you for a while and I'm not sure you've got the skill set for this project...
    :monocle:
    astrength22, shifty`, Fotnot and 2 others like this.
  6. Jan 14, 2025 at 9:30 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    On the photo with the pipes showing, the flush/drain valves are there. I cropped the photo and drew a couple of arrows. I need to do the flush process.
    I found an older photo that shows the access to the flush ports better.
  7. Jan 15, 2025 at 4:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Excellent
    It was just hiding
    the first time I installed my WH, I had no idea those valves existed. After the first time I had to flush it, I reconfigured the entire piping setup to add those into the system.
  8. Jan 15, 2025 at 8:41 AM
    WAtundra4x4
    Den
    Wet side WA
    Hahaha. I knew about the flush on the tank water heaters…did I ever do it? Nope. I did not know about the flush method for tankless till it came up on this thread. Something to do on a warm day. I need to make a flush system first.
    OldGuy03 likes this.
  9. Jan 15, 2025 at 10:32 AM
    Outbound
    Aaron
    Northern Alberta
    I built and mounted a mini climbing wall for little AK's room.
  10. Jan 15, 2025 at 10:43 AM
    NWPirate
    Zach
    WA
    Awesome idea building it inside :thumbsup:
    I built this play structure a few years ago for my kiddos.
  11. Jan 15, 2025 at 11:13 AM
    Outbound
    Aaron
    Northern Alberta
    That looks great!
    Our yard isn't quite big enough for something like that but I'd like to build a bigger climbing wall outside for her this spring.
  12. Jan 15, 2025 at 11:34 AM
    NWPirate
    Zach
    WA
    :hattip:
    Nice touch on the burn too, looks good
  13. Jan 15, 2025 at 11:44 AM
    Outbound
    Aaron
    Northern Alberta
    The burn is my new favorite finish. Looks way nicer than a stain imho. I did a shelf last month as well that turned out really well and The Woman has requested any future wood projects to have it.
  14. Jan 15, 2025 at 1:26 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Master bedroom reno. Scraped popcorn ceiling. Pulled vanity due to a leak so new vanity. Pulling carpet for wood flooring. Wipe down and retexture ceiling and walls tomorrow. Pulling wallpaper took two days. Don’t ever wallpaper people!
  15. Jan 15, 2025 at 4:55 PM
    TaquitoBandito
    Joel (AKA Bif)
    Wallpaper sucks ass. When I did ours I figured out it was easier just to pull it off and then scrape the left over glue. It was hell.
  16. Jan 16, 2025 at 3:56 PM
    NWPirate
    Zach
    WA
    Riddle me this..
    50gal Electric water heater, drained/flushed and changed anode rod. 4500w upper and lower elements.
    Filled back up, purged air and checked amp draw for shits and gigs. Both t-stats were made up, only the top element fired off. Looking at the wiring diagram, only one element can run at a time!
    1. When does this switch operate?
    2. What's the point of having two elements if they both can't heat at the same time??
    :confused:
    *Edit- now the lower element is switched on.. maybe the elements switch with every cycle?
  17. Jan 16, 2025 at 4:18 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I found this when I googled it. Seems, reasonable with the main benefit being half the current draw while the drawback would be longer cycle times.
    "Storage water heaters having equal to or more than 30 US Gallon / 100 litres (different storage for different countries) needs more energy input to heat up the large amount of water. Plenty of times you may also go for more than One heating element so that content of the tank could be heated up more efficiently.
    Although there could be more than 2 elements and maximum 6 For commercial water heating range but there are some models which could be customised for more no of elements as well, however right now I am only considering dual element model for the case of simplicity.
    Now this configuration can have simultaneous operation and non simultaneous as well.
    • In Simultaneous models, both lower and upper elements would get on at the same time, however they may get switched off at different times. Since hot water is lighter than the dense cold water, so it would automatically rise to the top of the water heater always. So the lower element in this case would always be working more as the top element will cut off faster. This mode is faster in water heating as compared to non simultaneous one.
    • In Non Simultaneous models, its the upper model that gets kicked in first, and having heated the entire top content of the water heater it switches off and then it triggers the lower element to start. In this case wear and tear of both the elements is more or less same."
  18. Jan 16, 2025 at 4:52 PM
    NWPirate
    Zach
    WA
    Makes sense, I guess. Dang engineers outsmarted me again! :D
    :fistbump:
  19. Jan 16, 2025 at 4:56 PM
    NWPirate
    Zach
    WA
    PSA:
    Change your anode rods :anonymous:
  20. Jan 16, 2025 at 6:01 PM
    Yep. Did that this summer
  21. Jan 16, 2025 at 7:06 PM
    Blue By U
    Blue By U New Member
    Been awhile since I posted any progress on the new shop. If I get everything sorted and moved in by summer, I'll be amazed. 50yrs of accumulation. The project starts on page 441.
  22. Jan 16, 2025 at 8:21 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    :drool:
  23. Jan 17, 2025 at 4:37 AM
    Florida AF
    Logan
    North Florida
    wow.... I just replaced my whole unit last year and am hoping to go tankless in a few years... but that is absolutely crazy and a great reminder!
    Beautiful!
  24. Jan 17, 2025 at 7:23 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    How old was that?
  25. Jan 17, 2025 at 7:52 AM
    NWPirate
    Zach
    WA
    8 years, and we don't have that hard of water here.
    I've looked for it before but I didn't think it had one.
    Had to dig out 2" of foam to find the plug.. now i know!
  26. Jan 17, 2025 at 8:02 AM
    Florida AF
    Logan
    North Florida
    In my experience, digging the foam out is the second worst part. Followed by breaking that sum bitch free from the water heater. The new model I have, I asked about that and swapping out the bottom drain to a more open one and they informed me that it immediately voids the warranty. So I will wait a couple more years before checking on it
  27. Jan 17, 2025 at 8:23 AM
    NWPirate
    Zach
    WA
    No joke man, I tried a breaker bar but it took my 1/2" impact to bust it loose.
    Mine has a brass drain valve, I guess a lot of the new ones are plastic.
    Figures..
  28. Jan 17, 2025 at 8:32 AM
    Kung
    KG, VA
    You think I should replace the anode rod on my 52-year-old water heater?
    It's been working fine for that amount of time....and given that, and given our water is perfect (0ppm for anything except some minor sediment), I'm wondering if replacing it is worth it.
  29. Jan 17, 2025 at 8:32 AM
    Outbound
    Aaron
    Northern Alberta
    PSA: Get a tankless heater.
  30. Jan 17, 2025 at 8:38 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Considering the age, i wouldn't even talk about it, touch it, hell....i wouldn't even fart in the same room as it. leave her be and let her finish off her days serving you peace
