General Supercharger Thread
  1. Jan 15, 2025 at 7:00 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I recorded a rolling pull to check my boost pressure and AFR. RuhRoh, it was around 12.5 for a lot of it. Not sure if it’s todays cold 27 degree temps and low DA paired with not adjusting the tune after the SPD midpipes, the new o2 sensor I put in maybe reading differently than the old sensor, or the fact that I’m reading the passenger side bank now. I remember checking it after getting the midpipes on though in about 60 degree weather and it was still in the 10s on the passenger side bank. That was prior to changing out the failed o2 sensor though, haven’t really changed anything else. Guess I’ll have to log. What’s the minimum registered AFR on the stock O2s again? I have to look into how to hook up my AEM wideband for logging again. I had found a solution in the past but never took the time to do it.
  2. Jan 15, 2025 at 7:06 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Mine did the same thing the other day. Tried to get a dragy run when it was 35* and afr was in the 12s. Did another and it was in the 11's. Tune was spot on a couple weeks ago when it was 50* out
  3. Jan 15, 2025 at 7:12 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Does your wideband reading match what the stock 02s show on the SG3? The stockers go down to 11.9 on my SG2.
    Wynnded, Mdl and Silver17[QUOTED] like this.
  4. Jan 15, 2025 at 7:12 PM
    Silver17
    Eastern PA
    Interesting, good to know. Maybe I’ll let it be and check again on a warmer day rather than F with it right away. Immediately my mind goes to the worst possible explanations like a clogged fuel pump sock or a failing pump. Lol
    Saltyhero13 likes this.
  5. Jan 15, 2025 at 7:13 PM
    Silver17
    Eastern PA
    I’ll have to check this. I wasn’t monitoring the stock o2s with my SG at same time.
  6. Jan 16, 2025 at 3:14 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    It’s funny because that’s where I have mine tuned at is 12-12.5 AFR. Been like that for 2 years now, lean is mean.
    Saltyhero13, Mdl and snivilous[OP] like this.
  7. Jan 16, 2025 at 5:03 AM
    ssmokedz
    Shelton CT
    My afrs are in the high 10's low 11's on a normal day and I have been seeing it touch low 12's at high rpm since it has been cold. My boost is about 1 psi higher than what I normally see as well. On my scan gauge 3 the AF sensors read down to 11.8.
  8. Jan 16, 2025 at 6:41 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Worth it for the solenoids alone if they're all good.
    Tripleconpanna likes this.
  9. Jan 16, 2025 at 7:23 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    So NatSpeed in VA closed down....
  10. Jan 16, 2025 at 8:21 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    That's the location I went to to get my supercharger installed. I think that location has been closed for 6+ months now. Not sure why.
  11. Jan 16, 2025 at 12:20 PM
    Saltyhero13
    Same same. They did my initial install and upgrades.
    Probably not enough business to keep them running. IMO it was too close to their original Wilmington location; more affluent customers in the north of VA anyway.
    I'll be surprised if Wilmington stayed open at this point.
  12. Jan 16, 2025 at 2:10 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    :woot:thanks @snivilous pulley showed up today.
  13. Jan 16, 2025 at 2:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    That is the sweet spot for making nice power!
    I've adjusted my PE to shoot for low/mid 11's up to about 5 psi then at least mid 10's up to whatever she'll do. Its hard to do but im pretty close with it in PE/rpm's.
    You may never have an issue but it doesn't leave much room if there is a fueling error. Granted our reaction to a lean out while in boost is slow but I'd take whatever I can get. I have an older AEM that blinks red/green when I hit 12 afr and is in my field of view. Just let's me back off if something is off.
  14. Jan 16, 2025 at 2:22 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I did some data logging and rewrites with @snivilous the other day. I was originally at mid to high 9, 10 at shift. Toby went leaning it out and it was getting better. On the last rewrite, the temp had dropped and I was hitting mid to high 11s. I richened it out and now I am high 10 to low 11. I ain't messing with it till summer rolls around and check it then. S. Fla temp is always hot year round with only a few weeks of 60*-50*. I will say on my last trip to Pensacola it was high 30s and it pulled like a freight train. Didn't even bother to look at the AFR at the time because I was so impressed with how it was pulling.
    Silver17, e30cabrio, Abell207 and 2 others like this.
  15. Jan 16, 2025 at 4:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :bananadance:
  16. Jan 16, 2025 at 4:27 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
  17. Jan 16, 2025 at 4:36 PM
    blenton
    blenton New Member
    Dangit. I need to find something to order on Sniv's site so I can get some sweet stickers... I'm jealous. The rootbeer candy, though, that's for the birds. I like to be able to feel my tongue instead of wondering if it turned in to a piece of mince meat after eating a piece of candy.o_O
    Tripleconpanna and snivilous[OP] like this.
  18. Jan 16, 2025 at 4:45 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    yea only reason I got the pulley was cause I wanted the stickers lmao, but really it's a nice piece and looking forward to installing it. Meanwhile will continue to patiently wait for that sweet, sweet billet throttle body so I can ditch my ported one.
  19. Jan 16, 2025 at 5:35 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Send me your address and I'll send a care package :rofl: I agree the root beer candy is kind of meh, I'll be honest I usually buy packs of the air heads and then throw whatever random stuff is in our candy bin in to supplement it :D
    I actually got an update from the machine shop a day or two ago on that front
    Hopefully RevB seals correctly and all the other upgrades work :fingerscrossed: at a minimum the sex appeal is a lot higher since I shaved 30+% of weight from the first prototype!
  20. Jan 16, 2025 at 5:38 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm in for the TB at the time, I almost ordered a 2.1 for the 'fridge magnets.
    snivilous[OP] likes this.
  21. Jan 16, 2025 at 5:42 PM
    snivilous
    SW UT
    Someday I'll get shirts so there's an actual merch bundle. I was also thinking I should get some updated stickers that say 2025 on them with a different design. Would be cool to have different designs representing each year in business, plus would increase the amount of merch thrown in with each order :D
  22. Jan 16, 2025 at 5:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks awesome!
  23. Jan 16, 2025 at 5:58 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    Agreed
  24. Jan 16, 2025 at 5:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looking Sweeet!
    snivilous[QUOTED][OP] and Ryuu like this.
  25. Jan 16, 2025 at 6:22 PM
    centex
    centex New Member
    Can people with Nagasaki whistlers join in this thread?
    Mdl likes this.
  26. Jan 16, 2025 at 7:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm still down to do some testing/data logging and compare to the GM 95mm TB.
  27. Jan 16, 2025 at 7:43 PM
    snivilous
    SW UT
    One of these will probably make its way to you. Maybe I'll send the other one to someone else once it has run its course on my truck too. I want to get a good amount of hours on it with different setups before I call it good to sell.
  28. Jan 16, 2025 at 9:55 PM
    blenton
    blenton New Member
  29. Jan 17, 2025 at 5:40 AM
    e30cabrio
    I volunteer!
    snivilous[QUOTED][OP] likes this.
  30. Jan 17, 2025 at 6:31 AM
    nags
    nags New Member
    Been having an issue lately where my idle seems a tad high and then will surge here and there to about 1200rpm. Doing this with and without the AC running. Had the shop that did the install take a look and they checked for vacuum leaks and anything else and they're not finding any issues. Told me to reach out to the tuner to check logs. Currently waiting to hear back from him. Tempted to just buy my own HP device and move over to Sniv.
