2020 Transmission Drain and Fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by mech_engineer09, May 10, 2021.
  1. Jan 11, 2025 at 5:06 PM
    #151
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Doesn't matter
    Spyker[QUOTED] likes this.
  2. Jan 11, 2025 at 7:25 PM
    #152
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    If my understanding is correct, the ATF temp for fluid level checking is lower than the opening temp threshold for the cooler. You pin it open so you’re flowing the lukewarm fluid through the system because that is the right temp for the fluid thermal expansion to be where Toyota determined the proper level.
    Big dumb round numbers:
    Fluid temp for level checking is 110°
    Thermostat opens at 170°
    You need to check at the ~110°. But the thermostat has to be open to check level correctly. Pinning it open is the only way to do all of this.
    Temp or thermostat means nothing for a fluid drain or fill. Just checking.
  3. Jan 11, 2025 at 8:04 PM
    #153
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Rock & roll, thanks
  4. Jan 12, 2025 at 10:21 AM
    #154
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Wouldn't make a difference, either way when the truck is off all the fluid is drained back into the pan whether it's pinned or not, it's only when the truck is running that if the thermostat is not pinned the fluid won't flow to the the cooler until the temp reaches around 180.
    Spyker[QUOTED] and nobodyintexas like this.
  5. Jan 12, 2025 at 4:20 PM
    #155
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    PXL_20250112_210124555.jpg Got started on my AT cooler install . I realized after the pic that I had the spacer installed wrong but it's correct now :)
  6. Apr 6, 2025 at 6:43 PM
    #156
    Apohl17
    Apohl17 New Member
    AJ
    Did a drain and fill in my 2020 today. Super smooth. Thanks for the good info. Did not need to jump my OBD2 port.
    BrandonL812, Joe333x and BR73 like this.
  7. Apr 8, 2025 at 2:23 PM
    #157
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Did a drain and fill on my 2016 today. I replaced both the drain and the check plug, the 5mm allen hex stripped and removed it with vice grips and used my Fusion app for fluid temp.
  8. Aug 18, 2025 at 10:38 AM
    #158
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    did a drain & fill on my 2017 over the weekend using this excellent thread as well as this one. used a launch creader to monitor temp. super easy ... if you're on the fence about doing it yourself, go for it! thanks everyone who contributed to these threads :thumbsup:
    ATV25 and BR73 like this.
  9. Aug 18, 2025 at 11:55 AM
    #159
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Got all the parts/tools and fluids. Now I gotta find time.
    Thanks to all who contributed to this thread. My last Tundra I paid the dealer to do it. Now that I have the Veepeek and OBD Fusion app, this should be a no brainer.
    ATV25, BR73 and sonofdad like this.
  10. Aug 19, 2025 at 9:09 AM
    #160
    Chad D.
    Chad D. New Member
    Western Oregon
    Worth noting, be sure your Allen wrench is fully seated in the drain plug. It’s a fairly deep hole and I thought I was all the way in when it juuuusstt started to strip out. Cleaned hole with pick and a bit of spit on it before slamming ‘er home the second time.
    Only suckas pay for trans fluid drain and fill! Way too easy and cheap.
    ATV25, sonofdad, BR73 and 1 other person like this.
