  1. Jan 10, 2025 at 9:11 PM
    R4T
    R4T New Member
    Tuan
    These are 35x12.5x17 with wheels that are a zero offset.
    It's currently sitting higher than I want but it has been settling. They are getting softer as I break them in though!
    It's funny you mentioned that, haha. I bought this from him when he got the single cab. I want to make some aftermarket parts for the 2nd gen Tundras. I feel like there isn't a ton for them.
  2. Jan 10, 2025 at 9:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  3. Jan 11, 2025 at 5:07 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Nothing too much however I did start it in the driveway, after I got home from my heart valve surgery. I can't drive for a few weeks, but I got a thrill out of sitting in it while it was running. Sucks being old fellas.
  4. Jan 11, 2025 at 9:11 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Holy smokes man. Sending healing vibes your way.
    Getting old sure ain't for pussies.
  5. Jan 12, 2025 at 6:51 AM
    rphass17
    rphass17 New Member
    Can you feel/hear when you need to replace your front needle bearing? Also what side?
  6. Jan 12, 2025 at 6:53 AM
    koditten
    Kirk
    Midland of the Mitten
    You can definitely hear it when it's bad. It's aow pitch growler that is present at low speeds.
    joseph_womack and Mdl like this.
  7. Jan 12, 2025 at 8:25 AM
    rphass17
    rphass17 New Member
    I was just driving on the highway this morning in 4wd high. Which I have done before but under acceleration I could hear a deep hum and feel vibration in the steering wheel. Sounded like front driver.
    koditten[QUOTED] likes this.
  8. Jan 12, 2025 at 12:30 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    Morimoto headlights.
    chugs, dondino, Medicineman and 11 others like this.
  9. Jan 12, 2025 at 6:01 PM
    koditten
    Kirk
    The sound goes away when you are in 4wd. I don't think you have a bearing issue.
    Mdl and OldGuy03 like this.
  10. Jan 13, 2025 at 7:22 AM
    rphass17
    rphass17 New Member
    Sorry the sound is only present in 4wd hi at highway speeds. I can feel it between 70-75 under acceleration only. I will just check everything over soon, it doesn't sound or feel like an immediate issue.
  11. Jan 13, 2025 at 10:35 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    It might be the fact that you’re in 4wd hi at 70…
    Also yes I know the manual doesn’t say what’s the limit on speed; what size tires are you running and are they mud tires
    dondino likes this.
  12. Jan 13, 2025 at 10:38 AM
    joseph_womack
    Joe
    Louisiana
    Here’s the tire mount; it’s just a center threaded tube with 3 small rebar pieces that fit into mounting surface of the spare; then on the outside is a plate to sandwich the wheel and then the threaded key holds it all together
    and then there’s also a pic of the tent and awning open
  13. Jan 13, 2025 at 12:47 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Simple, I like that.
    joseph_womack[QUOTED] likes this.
  14. Jan 13, 2025 at 2:10 PM
    mr4bs
    mr4bs New Member
    Alex
    Oregon
    Drove about an hour and a half round trip today for what I think might be a record for a deal for myself. Picked up this great condition tonneau cover (real truck UC4076) for $100 cash. On my way back seemed like my MPG’s went up (17.6). What do you guys think?
  15. Jan 13, 2025 at 3:12 PM
    joseph_womack
    Joe
    Louisiana
    Yeah bed covers can help with mpg, makes the truck more aerodynamic
    But also calculate your mpg by hand when you fill up, the digital reading isn’t accurate
    (miles driven / gallons filled = mpg)
  16. Jan 13, 2025 at 3:16 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I always hand calculate and my milage is always better on the trip cpu compared to my calculations. Gotta be a marketing thing so they can claim I'm getting 14.6 when I'm really getting 13.5
    mr4bs and joseph_womack[QUOTED] like this.
  17. Jan 13, 2025 at 3:19 PM
    mr4bs
    mr4bs New Member
    Alex
    Oregon
    I purchased it because I plan on using the truck for business and it will at least visually help prevent things from walking away too easily. I have seen some info debating both ways on whether or not tonneau covers help with MPG so I will definitely do a more scientific update (Hand calculation) when I burn a full tank.
  18. Jan 13, 2025 at 3:20 PM
    joseph_womack
    Joe
    Louisiana
    I think it’s just really the fact that it’s showing you your current mpg and not the mpg of the whole tank
    OldGuy03[QUOTED] likes this.
  19. Jan 13, 2025 at 3:22 PM
    joseph_womack
    Joe
    Louisiana
    It’d be interesting to see a team actually test it but on paper it’s removing the ability for air to get trapped or create drag in the bed so it practically has to help, but then there is also the added weight… I guess a similar result would come from just removing the tailgate
    mr4bs[QUOTED] likes this.
  20. Jan 13, 2025 at 4:32 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Nice score!!!
  21. Jan 13, 2025 at 4:38 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Toggling through settings I can see data for current, avg, and miles to empty.
  22. Jan 13, 2025 at 4:41 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Yesterday I drove up north about 30 miles to respond to FB ad for Leer 100XL cap for $500. It was not bad but doesn’t clear the cab of my reg cab. I had to look!! Anyways, turns out it was left by the guys wife’s ex-husband about 8 yrs ago and had been cluttering up the yard. Got onto the truck all covered in mud and slugs. Told the guy it just didn’t work. He says ‘look it, just take it we want it gone!’ So there. A FREE Leer 100XL canopy. Haha. Free has a price. I’m having a bitch of a time removing the key latch. Totally corroded and seized. Maybe tomorrow after the penetrating oil has got to it I can remove to replace. Also went by local wrecker and picked up intermittent wiper switch from a 2014 Tacoma, which took almost 2 minutes to switch out. So less than $100 and some gas money. Pretty good couple of days! LOL.
    Medicineman, 07 Tundie, mr4bs and 8 others like this.
  23. Jan 13, 2025 at 6:39 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Nice score! I think the topper looks good at just below cab height for what's it's worth.
  24. Jan 15, 2025 at 9:40 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Installed a tonneau cover over the weekend.
    SyneticUSA (lol made in China) retractable cover, manual, not powered. Retrax knockoff. Not cheap, but less than half the price of a Retrax. Seems solid. Good fit, no rattling. Time will tell. Fairly easy install, even doing it solo.
  25. Jan 15, 2025 at 4:03 PM
    koditten
    Kirk
    4 hrs to pull a starter.
    Why don't the vids tell you its easier to remove lower ball joint boltsto remove the axle?
    They want you to pull the upper ball joint nut and remove all the brake and wheel speed sensor wires. Job still sucks when you have a 4wd and transmission cooler lines to work around.
    Pick up the new starter tomorrow. Hopefully the install is much easier.
    Wynnded likes this.
  26. Jan 15, 2025 at 4:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes, it is so easy just pulling the lower knuckle bolts/axle bolt and swing it out of the way. I've never pulled the axle to do the starter. Even with long tubes I just pull the passenger manifold now.
  27. Jan 16, 2025 at 12:51 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Seems there's several ways to skin this cat. I just jacked up the passenger side of the engine :notsure:
    Zebruaj and koditten like this.
  28. Jan 16, 2025 at 2:20 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    It's difficult to imagine the scenario where you need 4wd, and yet still travel at 70-75 mph.
    Trident, The Dude and joseph_womack like this.
  29. Jan 16, 2025 at 3:00 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Anybody know the best deals for some 38/13.50R20 MT’s?
    Found the Maxxis Razr MT’s, same as what I have now, for 515.00 a tire with free shipping.
  30. Jan 16, 2025 at 3:05 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    walmart has the yokohama mt for 496, and the maxxis razr mt for 468
