  1. Jan 9, 2025 at 6:27 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thank you sir!
    RobertD[QUOTED] likes this.
  2. Jan 9, 2025 at 6:50 PM
    Florida AF
    Logan
    North Florida
    Hooked her up and put her to work! Didnt like the weight and the sand, but did the job and did it well.
  3. Jan 9, 2025 at 8:18 PM
    Reaper1911
    Reaper1911 New Member
    2024 White Tundra Limited Off-Road
    -TRD pro reaper bumper panels/fender flares -Catalytic converter cover -Bak revolver x4s tonneau cover
    Very good, I called Wolfbox to get a couple questions answered during my install, they told me they don't currently make a bracket for my 3rd gen. I'll check the website here and there. Thanks for the update.
  4. Jan 9, 2025 at 9:22 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I did the same thing. I gave them a call and they told me the bracket doesn't exist for my truck yet but I went ahead and ordered one anyway and it worked. :thumbsup:
  5. Jan 10, 2025 at 5:43 AM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    Does this replace the original mirror ? Does it plug into the factory mirror plug
  6. Jan 10, 2025 at 6:03 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    A word of caution, the patch game is a slippery ass slope...
    Damn that's a tight fit. I bought a similar compressor for my SAS truck, but I carry the single cylinder version in the Tundra. I modified mine with a pressure on/off switch so it turns on if pressure in the line drops below 30PSI and turns off when it hits 110PSI. Where did you mount your switches at?
  7. Jan 10, 2025 at 6:07 AM
    TacomaTRD4x402
    Southern California
    Yes, it will replace the factory mirror by either strapping over it with supplied straps or if you decide too buy the OEM bracket from WolfBox(sold separately), it will completely replace it all together. Either way, you would lose functionality of your Toyota Homelink if that is your concern. It does not use the factory mirror plug so you would need to tuck that away.
    HulkSmurf14 likes this.
  8. Jan 10, 2025 at 6:11 AM
    TacomaTRD4x402
    Southern California
    Nice!
    :101010:
    OHwendTrd and 250000yota[QUOTED] like this.
  9. Jan 10, 2025 at 6:13 AM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Not worried about the factory mirror just want to keep it as clean looking
    as possible dont want a bunch pf wires and plugs if i can eliminate the factory stuff
  10. Jan 10, 2025 at 6:19 AM
    TacomaTRD4x402
    Southern California
    Oh yeah for sure, I don't really like the look of all those wires either. Check out my post yesterday..
    https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-3303#post-3814323
    Hope I linked that correctly but yeah you'll definitely have at least 1-3 wires coming down from your headliner to plug into the top of the mirror. I say 1-3 because 2 of them are optional(rear cam and GPS) .
  11. Jan 10, 2025 at 7:11 AM
    BlueRibbon4x4
    Geno
    at?[/QUOTE]
    It’s definitely tight, but not crazy. The mount sits low enough to fit the unit to clear the hood, while giving enough space to get your hands in there to mount the compressor. My main switch is in the center console behind the shifter. The pressure switch (70-100psi) is mounted in-line after the compressor, and is wired to the switch. So the pressure switch cuts off power when I hit the shutoff valve behind the pressure gauge under thehood.
    The circuit breaker is above the battery.
  12. Jan 10, 2025 at 7:20 AM
    250000yota
    Russ
    Berthoud, CO
    [/QUOTE]
    Very cool, just like I did on my compressor. I've got a very old Superflow MV-90, basically the single cylinder version of your compressor. I can't mount there on my truck, I have a S&B intake. Plus I do like the portability of the compressor being carried instead of mounted, but it looks very clean. I did just pick up the @RainMan_PNW switch mount for behind my shifter, I'll be mounting my FRAC and light switches there soon. Regardless, they're great compressors.
  13. Jan 10, 2025 at 7:27 AM
    koditten
    Kirk
    Midland of the Mitten
    Very nice.
    BlueRibbon4x4 likes this.
  14. Jan 10, 2025 at 7:43 AM
    BlueRibbon4x4
    Geno
    Very cool, just like I did on my compressor. I've got a very old Superflow MV-90, basically the single cylinder version of your compressor. I can't mount there on my truck, I have a S&B intake. Plus I do like the portability of the compressor being carried instead of mounted, but it looks very clean. I did just pick up the @RainMan_PNW switch mount for behind my shifter, I'll be mounting my FRAC and light switches there soon. Regardless, they're great compressors.[/QUOTE]
    Nice! I really like the S&B intake. It was my first choice, but the California smog buffoons say no.
    RobertD likes this.
  15. Jan 10, 2025 at 2:43 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Glad all you guys are ok..
  16. Jan 10, 2025 at 2:47 PM
    The 4th meal is the best.:devil:
  17. Jan 10, 2025 at 3:05 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Is that black box in the picture u linked the gps?
    What is the purpose of the gps for the mirror cam ?
  18. Jan 10, 2025 at 3:19 PM
    250000yota
    Russ
    Berthoud, CO
    Yea, not my girlfriends favorite. It's over on my side so that the kids don't read it lol. There's a few other good ones scattered in there.
  19. Jan 10, 2025 at 3:59 PM
    TacomaTRD4x402
    Southern California
    Yeah, the small black box in the top right corner is the GPS. It provides information on the mirror itself as well as the video playback. Provides GPS coordinates, speedometer, and compass all on the mirror. Each of those can be enabled or disabled in the settings. I'll snap a picture or maybe try to upload a quick video this evening.
    Pimpala1962[QUOTED] likes this.
  20. Jan 10, 2025 at 4:52 PM
    DrunkenChewbacca
    DrunkenChewbacca New Member
    Josh
    2020 Tundra TRD OR
    Idk if you ran it yet but I ran mine to the rear tailgate and the supplied 20 something feet didn't work. I purchased the 33ft wire.
  21. Jan 10, 2025 at 6:39 PM
    TacomaTRD4x402
    Southern California
    Here it is..
    https://youtu.be/CnMsQ2UPzbs?feature=shared
    @RainMan_PNW
    Nah, I didn't run it all the way, I think I prefer to keep it at the rear window, that way I'm be able to keep an eye on any load I might have.
    It seems like the wire that it comes with would be long enough. I got so much of it rolled up back there in the headliner. Do you have yours in place of the stock rear camera? Is it a perfect fit there?
  22. Jan 10, 2025 at 7:07 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Perfect i appreciate the help and info
  23. Jan 10, 2025 at 10:07 PM
    Dct89
    Dct89 New Member
    2016 Toyota Tundra SR5 Crew Max 4.6l
    Rear support air bags Level Kit 33" Tires and Method Wheels
    Today I installed:
    New Alpharex Nova headlights
    Wide steps for better footing grip
    Put my bed rack back on and installed my new fishing rod holders
    I couldn't be happier and there is so much more to come in the coming months!
  24. Jan 11, 2025 at 5:36 AM
    Tundra family
    Tundra family New Member
    Another flat tire this morning :( I just can't win.
    Wish they would hurry up and make some tweels for this thing already
    Id give ALL the money to never have a flat tire again
    Tripleconpanna and ZPhilip like this.
  25. Jan 11, 2025 at 6:32 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Completed and tested a custom upfitter switch panel, harness, and relay box. Ready to be installed this week!
    Backlights looks great. This is an upfitter switch from Ford trucks.
  26. Jan 11, 2025 at 6:43 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You could become a thousandaire if you sold those...I'd help contribute to your thousandaire-status! Looks amazing! We'll done!
    Jego, woods, French Avocado and 3 others like this.
  27. Jan 11, 2025 at 6:46 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    yup! That looks good! I’d be interested too
  28. Jan 11, 2025 at 8:06 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    New wheel installed. Love it.
  29. Jan 11, 2025 at 8:43 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Which one did you go with?
  30. Jan 11, 2025 at 9:16 AM
    Tundra family
    Don't forget the most important step... Ya gotta hawk tuah, and spit on that thang. :rofl:
