Gun Pics..whatcha got?
Discussion in 'Guns & Hunting' started by R0CKETMAN, May 22, 2017.
  1. Oct 6, 2024 at 8:19 PM
    #4921
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    My Block 2 FSP is finished minus an optic, will be either a Comp M4 or Eotech. Upper receiver is Colt cage code, Colt BCG, PRI military latch gasbuster, Colt 14.5 Socom profile barrel, Surefire 4 prong, Daniel Defense RIS FSP, and KAC 600 meter buis. The lower is a "Property of US Government M4A1" PSA, B5 Sopmod stock, with Schmid lpk, CQD rear sling mount, and Geissele SSAtrigger. GWOT!!
  2. Oct 6, 2024 at 8:35 PM
    #4922
    Rngr188
    Chad
    Harrison AR
    Found a Aimpoint comp m2 for my Colt 6920 2013 config Block 1 with 14.5 Socom profile barrel. GWOT!!
    Ely010606, Prostar 190 and JMGmanAZ like this.
  3. Oct 6, 2024 at 8:36 PM
    #4923
    Rngr188
    Chad
    Harrison AR
    Need an ACOG on this Colt m16a4 that I found a KAC RAS for. GWOT!!
  4. Oct 8, 2024 at 8:19 AM
    #4924
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    I just picked up this Springfield XDm 10mm. Any recommendations on chest holster? The Kenai seems like an obvious choice.
  5. Oct 8, 2024 at 6:22 PM
    #4925
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  6. Oct 8, 2024 at 8:17 PM
    #4926
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I've got a few Crossbreed Chest Rigs. Well made, good retention, and comfortable, stable design :thumbsup:
    https://www.crossbreedholsters.com/product/chest-rig/
    Hotwire[QUOTED] likes this.
  7. Oct 11, 2024 at 2:59 PM
    #4927
    Hotwire
    Hotwire New Member
    Montana
  8. Nov 2, 2024 at 4:52 PM
    #4928
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    just sharing a pic I did for a buddy
  9. Nov 2, 2024 at 5:02 PM
    #4929
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    mostly finished builds. 10.5 Noveske, bcm, Geissele with aimpoint pro. 16 bcm, Geissele, trijicon credo 3-9x40
  10. Nov 5, 2024 at 1:38 PM
    #4930
    Rngr188
    Chad
    Harrison AR
    My Mk18 pistol build. The upper and barrel are Colt clone correct, lower is a PSA with Schmid Tool lpk and Geissele SSA. Knight's sights and Eotech Exps3-0.
  11. Nov 5, 2024 at 1:41 PM
    #4931
    Rngr188
    Chad
    Harrison AR
    KAC gives me warm and fuzzy feelings
    ToyoMafia[QUOTED] likes this.
  12. Nov 5, 2024 at 2:38 PM
    #4932
    ToyoMafia
    Magic carpet.
    Same
    Rngr188[QUOTED] likes this.
  13. Nov 9, 2024 at 2:59 PM
    #4933
    Rngr188
    Chad
    Harrison AR
    Was contemplating what optic for my Block II FSP, decided on an ACOG TA31RCO-M4CP
    AZ Red Nek and Ely010606 like this.
  14. Nov 16, 2024 at 3:04 PM
    #4934
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Got some rounds down range today with the new (to me) Super Redhawk Alaskan 44Mag.
    50 rounds at 5 yard w/240gr JHP. Not as much kick as I ecpected:
    First round of polishing was a success, several more to go:
    My other Redhawk 44Mag:
  15. Nov 16, 2024 at 7:19 PM
    #4935
    Tripleconpanna
    Love the leather :thumbsup:
    Ely010606 and 1lowlife like this.
  16. Nov 16, 2024 at 7:28 PM
    #4936
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  17. Nov 25, 2024 at 3:27 PM
    #4937
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Picked up my latest pistol today. This is going to be a base for a build I'm planning out:
    Also picked up the foam for my DW ECO case. 4th one these guys have done for me; they've done several for work "stuff"...as always, fits like a glove:
    Explorer, ToyoMafia, B.Ross and 5 others like this.
  18. Jan 10, 2025 at 1:59 PM
    #4938
    Rngr188
    Chad
    Harrison AR
    I had a G45 and bought a 19x a couple weeks ago, decided to switch slides and see how they look. I think the black G45 frame with the coyote 19x slide looks pretty good.
  19. Jan 10, 2025 at 2:03 PM
    #4939
    Rngr188
    Chad
    Harrison AR
    Since carry handles are back in style I decided to do an A2 upper from Throughbred Armament, Colt 14.5 gov profile barrel, non-F marked rifle height FSB, and 2-position buffer tube with a CAR stock.
    Ely010606, danno266 and JMGmanAZ like this.
  20. Jan 10, 2025 at 3:32 PM
    #4940
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Someone came over and they wanted to buy my Grendel, so I started another one.
    I needed to coordinate all the parts that have accumulated over the years and putting together another was a good excuse. I organized everything and all matching parts are in separate bags and I put together another lower. The handle is not the one that will stay there, an Ergo will go there when they get more in stock.IMG_6524.jpg
    it has ambi safety selector, and ambi mag release on it now.
    Ely010606 and JMGmanAZ like this.
  21. Jan 10, 2025 at 4:19 PM
    #4941
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    I am so disappointed....that there isn't a MEGA like button and only a little like button....I love it, and would not add ANYTHING else to it.
    Rakkasan and Rngr188[QUOTED] like this.
  22. Jan 10, 2025 at 6:17 PM
    #4942
    Tripleconpanna
    Hey, I've never run an RMR... would you mind trying to capture a view through your optic illustrating what the sight picture looks like w/your suppressor height sights and RMR 'co-witnessing'??
    I'm guessing you lose a small portion of the viewing window...
    Do you get a true co-witness w/the RMR??
    Last question... do you find there's 'conflict' w/the RMR and iron sights in the viewing window?
  23. Jan 10, 2025 at 6:47 PM
    #4943
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Coyote? I thought that color was called 'baby poop'..
    I sold my 19X after buying my G45.
    The 19x wouldn't take my old G17 mags and I hated the color after a few weeks..
    Black guns matter...
    78f39c3c-f3be-4154-a4bc-d585f7a25a40_6a8e3d1f960ed7e8437dd2407d1eaa1a01f9a6f0.pngb45ed654-1c2f-43d8-903c-a710959ad45b_f22cdbea444038238b3dd1b4e904035344d16777.png
    52d91a93-c87e-432d-b84d-4ce8dcd11ebf_b26d6b600b2368414b5308fff0f8be009b634176.png74caa4b5-c077-401a-8612-af4028ed0fda_a2ee409f3d8f7b010f8dd3b67f835e830c673024.jpg
  24. Jan 17, 2025 at 5:50 AM
    #4944
    1lowlife
    DADA
    2014 MGM DC SR5
  25. Jan 22, 2025 at 5:27 AM
    #4945
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Nothing special.
    This was an SS 223 wylde upper purchased on a whim 5 years ago from an online vendor who I won't be buying from again.
    BCA SS 223 wylde barrel on an Aero upper, carbine length. Had to pester them into taking it back to machine the feed ramps to fix feed issues. When I finally got it back I noticed once I was able to run a full mag uninterrupted by malfunctions it was wildly over gassed. Had to go to an H2 just to keep the buffer tips from getting chewed up and the firing pin retainers from getting mangled. Never shot particularly well.
    I figured why replace the gas block on a mediocre barrel, so Finally went to a Ballistic advantage SS premium 223 wylde mid length. Spikes ST2 behind it. Very soft shooter that zeroed easily at 25 touching holes. Cycles 55 gr 223 without a hiccup with a just over 4 oz buffer but still have to experiment with different factory loads. Can't wait to shoot groups at 100 and ring steel at 2 in a couple weeks. I regret not trying a mid length gassed 16 inched before now.
    Vortex Sparc AR with a Vortex 3x behind it but will probably get a scope now that it's sorted out and I put a couple thousand rounds through it like this. Probably should have just swiped left 5 yrs ago but I spent the cash and then spent more cash to make it a shooter. Now the mutt is fully mine.
    AZBaldy and JMGmanAZ like this.
  26. Jan 22, 2025 at 6:11 AM
    #4946
    Black@Blue19
    Ken
    SE Texas
    I just read up on this. The first thing that comes to mind is it would not be good for any type of protection carry gun for no other reason than I would not shoot this around people because I would be worried of pass through.
  27. Jan 22, 2025 at 6:21 AM
    #4947
    eharri3
    eharri3 New Member
    In general that's a real roll of the dice to pick up a carry gun that runs off a brand new concept. I'd have to see a few years of field testing to even consider it. Not sure who's gonna pick up one of these and a holster then run 500 rnds through it and consider it good to go. Let's see what the youtubers get out of it.
  28. Jan 22, 2025 at 7:13 AM
    #4948
    Did a little color matching on the AR10 and then added the bipod after some "mods".
    Ely010606, B.Ross, JMGmanAZ and 2 others like this.
  29. Jan 22, 2025 at 7:23 AM
    #4949
    Thinking about having the 19x or G17 slide milled out for an optic.
    Black@Blue19 and JMGmanAZ like this.
  30. Jan 22, 2025 at 8:09 AM
    #4950
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    If you do will the pistol still fit in your holsters?
    I say do it..
    If you do will that cause any fitment issues with your holsters?
