Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Jan 8, 2025 at 2:50 AM
    #571
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I will be installing my speedmaster using the Lucas 85w-140 and I live in a cold climate.
    Mdl likes this.
  2. Jan 8, 2025 at 10:33 AM
    #572
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are you just doing the lsd or gears/lsd? It shouldn't have an issue but may have a slight mpg loss.
  3. Jan 8, 2025 at 10:40 AM
    #573
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I’m just doing the LSD at this time. Not sure if I want to install the 5.29 gears.
    Mdl[QUOTED] likes this.
  4. Jan 8, 2025 at 3:57 PM
    #574
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Did you guys have to replace the oil seal and o-ring on the hub for the rear?
  5. Jan 8, 2025 at 4:13 PM
    #575
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I'm putting new orings on mine. not sure its 100% necessary, but toyota says theyre non-reusable and theyre cheap.
  6. Jan 8, 2025 at 4:14 PM
    #576
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I have them coming tomorrow anywho but it would be nice not having to remove everything to change those out.
  7. Jan 8, 2025 at 4:42 PM
    #577
    helidave
    flagstaff
    2015 DC 4x4
    Are you not pulling the axles out?
  8. Jan 8, 2025 at 4:43 PM
    #578
    You don’t have to pull them all the way out
  9. Jan 8, 2025 at 4:47 PM
    #579
    helidave
    flagstaff
    2015 DC 4x4
    interesting. It didnt seem like there was enough slack in the brake line to leave it attached
    Mdl and FrenchToasty like this.
  10. Jan 8, 2025 at 4:49 PM
    #580
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Yeah you only need to pull them out a little bit to get that 3rd member out.
    FrenchToasty and helidave like this.
  11. Jan 8, 2025 at 4:56 PM
    #581
    helidave
    flagstaff
    2015 DC 4x4
    Probably not worth the effort just to change those orings then, as long as they're in decent shape
    Abell207 and FrenchToasty like this.
  12. Jan 8, 2025 at 4:57 PM
    #582
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I agree. And worst case I’ll replace them when I see a leak.
    Mdl and helidave like this.
  13. Jan 8, 2025 at 5:20 PM
    #583
    blenton
    blenton New Member
    We didn’t replace them when we did my Auburn 7 or so years ago. No leaks. But it would be cheap insurance if you decide to.
  14. Jan 8, 2025 at 5:21 PM
    #584
    blenton
    blenton New Member
    Heard back from Speedmaster concerning gear oil. Here is their response:
    Mdl, Abell207, Silver17[OP] and 2 others like this.
  15. Jan 8, 2025 at 5:34 PM
    #585
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s good to know for those with the speedmaster, especially since I’ve read some say the 5.29s are more likely to make noise with the thicker oil. I think the speedmaster and powertrax are very similar units. I know there was speculation they had different number of gears, powertrax 3 and speedmaster 6 but as it turns out they both have 6.
    Mdl, Abell207, helidave and 1 other person like this.
  16. Jan 8, 2025 at 5:46 PM
    #586
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Well damn.. already have the 85w-140.
  17. Jan 8, 2025 at 5:50 PM
    #587
    blenton
    blenton New Member
    I doubt you will have an issue running it in warmer climates. Maybe get some extra grippiness from it. But I guess you will have to run it and see, then tell us how awesome the Speedmaster is :)
    Saltyhero13 likes this.
  18. Jan 8, 2025 at 6:13 PM
    #588
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    “I don’t pull out” - @Fotnot, probably
    hagrid, Saltyhero13, DZ_ and 5 others like this.
  19. Jan 9, 2025 at 3:20 PM
    #589
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is interesting they stated 3 different gear oil weights on different emails with the same guy. Good he kept digging into it!
    But like with the powertrax using a lighter oil will just reduce the response and be better for those in cold climates. @Lemuel1 has running it with 80/90 and reported no issues.
  20. Jan 9, 2025 at 3:21 PM
    #590
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The speedmaster has been doing great. I think you will really like it! I'm running 85/140 in it.
  21. Jan 9, 2025 at 3:26 PM
    #591
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got the front gears installed and running with no issues. Got 40 miles on them in 4wd. I did it like zuk and put the pinion shim behind the bearing and not the race. Came out perfect and easier swapping shims.
    Ecgs bushing installed so the needle bearing removal tool from @VWTim is available whoever needs it.
  22. Jan 9, 2025 at 3:29 PM
    #592
    Awesome!
    Zuk is a super awesome person, and he has a super cool shop cat! I should regear other things before he retires!
    Mdl[QUOTED] and helidave like this.
  23. Jan 9, 2025 at 3:33 PM
    #593
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He is! We talked for almost an hour on gears/toyotas' and doing different setups. Even asked to keep him updated on how it all works out. It was nice to have someone you could contact as he's seen it all.
  24. Jan 9, 2025 at 3:37 PM
    #594
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can notch the hard line so you can pull it out. Take the e brake cable support bolt out and you have about 10 inches to pull out. No need to take rotors off. Clean up where the o ring sits for a good seal. I've reused mine twice so far, no issues. I did this when I replaced my rear axle bearings.
  25. Jan 9, 2025 at 3:37 PM
    #595
    It also says something when he’s not even doing your gears, he just wants to help! It sounds like you have a clue about gears, so that probably made it easier for him to explain everything. I have zero clues, that’s why I made the trek to see him.
    Silver17[OP], Mdl[QUOTED] and des2mtn like this.
  26. Jan 9, 2025 at 4:02 PM
    #596
    Abell207
    Abell207 New Member
    Anthony
    Maine
    That’ll be so nice if I can leave all that alone and zip out the 4 bolts per side for the hubs.
    Mdl[QUOTED] and FrenchToasty like this.
  27. Jan 9, 2025 at 4:25 PM
    #597
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Here is an excerpt from the DIY re-gear sticky in performance threads. One thing is don't let it rotate as it can mess up the brake line. I used long zip ties through the axle bolt hole to the notched brake line support. I left enough slack to get 10 inches so they clear the carrier.
  28. Jan 9, 2025 at 4:30 PM
    #598
    blenton
    blenton New Member
    Funny thing - the box itself clearly started straight 140. But as you suspect, I’m sure it will work with various weights to varying degrees of lockup. I was trying really hard to convince myself that straight 140 would play nice with sub freezing temps..
    We notched the bracket the same way. Works great. Glad you got a pic of it and posted about it.
    Abell207 likes this.
  29. Jan 9, 2025 at 4:36 PM
    #599
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What was interesting is zuk was saying to run 80/90 as there shouldn't be an issue as it is like the powertrax except with a preload.
    I got that pic from a write up back in 2012 on tundratalk when I needed to do my rear axle bearing. I try to download tech write ups as it save time over the factory how to's...
    That guy Joe at speedmaster was probably getting a bunch of emails and calls on the lsd. I put 500 miles on it with 80/90 and it was fine.
    Abell207 and blenton[QUOTED] like this.
  30. Jan 9, 2025 at 5:16 PM
    #600
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    you wanna install mine lol
