Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Jan 3, 2025 at 12:40 PM
    #541
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    They're already priced pretty reasonably. See attached.
    Terndrerrr, blenton and Mdl like this.
  2. Jan 3, 2025 at 12:52 PM
    #542
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I re-read my email. He states they do used gears with good results that were from an incorrect depth setup. They did a bunch of gears from recalled 2014 Ford GT's that were noisy. As we know nothing is 100% but still a decent option.
  3. Jan 3, 2025 at 2:47 PM
    #543
    bflooks
    bflooks New Member
    Metrowest MA
    So, aside from machining investment, it's my understanding from my previous link that most OEM lap their gears before install, which is why you can be just run them. Aside from that, what I've learned from essentially everything aftermarket is that better is never perfect, and this includes the decades of regearing across every type of platform. Noise happens when focused on performance, with a lesser focus on who can/will/cares about gear whine. Find perfection if you can, but based on my research over the years, there no guaranteed way to get silence. Some are fortunate, some aren't, some may simply never know (or care)
    Silver17[OP], Mdl and carn_dogg like this.
  4. Jan 3, 2025 at 3:31 PM
    #544
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    A lot of oem companies have major $$ invested in their tooling and some shot peen as it is done pretty quickly. I was pretty close in my 2nd setup and maybe could of knocked off another thou or 2. Some gears just require more time than someone is willing to do. For what I paid I wasn't expecting perfection. But the whine I got is right at where the majority of my driving is. The first time was at 55mph reduced pinion depth by another .006 and was good for 500 miles. Maybe I burned a spot the resonates at the frequency of 57mph? Ill get it sorted out and recheck preload.
    Silver17[OP] likes this.
  5. Jan 3, 2025 at 3:47 PM
    #545
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Northeast
    2017 TRD 4x4 Harrop SC
    I just give you kudos for tackling it yourself. Even with the polishing I kind of knew going into it that going 5.29s of any brand carries some risk of making the rear noisier. I’m hoping the polishing helps reduce the likelihood of extra noise.
    Terndrerrr, bflooks and Mdl[QUOTED] like this.
  6. Jan 3, 2025 at 4:39 PM
    #546
    blenton
    blenton New Member
    True. I just get suckered by a good deal - you know, I'd be LOSING money if I DIDN'T buy it... Like those stoopid Milwaukee sales guys that know how to get me keep buying stuff.
    Silver17[OP] and Mdl like this.
  7. Jan 3, 2025 at 4:45 PM
    #547
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Guess the old addage of better to be a little deep than shallow is out the door. Why Ken wants to be balls on.:D
  8. Jan 3, 2025 at 7:19 PM
    #548
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Mdl and FrenchToasty like this.
  9. Jan 3, 2025 at 7:24 PM
    #549
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's a lot closer to me than CT. He did mention another company but didn't remember. Thanks!
  10. Jan 3, 2025 at 7:25 PM
    #550
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If that’s not enough to get you to pound down their door with fists of cash…
  11. Jan 3, 2025 at 11:34 PM
    #551
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Was looking at Revolution and they have a complete package for like $1800. I'm assuming they charge extra for the super polishing.
  12. Jan 4, 2025 at 12:30 AM
    #552
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Supposed to be about $100 each set.
    Dave8699[QUOTED] likes this.
  13. Jan 4, 2025 at 4:44 AM
    #553
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    talk to @memario1214 at hotshot offroad
    memario1214 and Dave8699[QUOTED] like this.
  14. Jan 4, 2025 at 5:49 AM
    #554
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    What pullers were you guys using to pull the used bearings off to reuse them?
  15. Jan 4, 2025 at 6:12 AM
    #555
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sunex 57BS5 1/2 -9 inch
    OTC 1130 1/2-9 inch
    Vevor carrier and pinion bearing puller
    I used the sunex but you have to be careful as you can damage the bearing cage.
    The otc is a top quality splitter.
    The vevor seems good for not damaging the cage.
  16. Jan 4, 2025 at 6:53 AM
    #556
    Abell207
    Abell207 New Member
    Anthony
    Maine
  17. Jan 4, 2025 at 6:55 AM
    #557
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Or can I just use the sunex one for all of it?
  18. Jan 4, 2025 at 7:22 AM
    #558
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just listed 3 options for the bearings. The sunex can do the carrier bearings. You just have to get creative creating the needed space to press the carrier out. Do it after you remove the ring. Don't want to damage it. The otc and sunex need to be tightened up after it starts moving. There is little purchase on the bearing and check that the bearing spins freely after the first few presses.
    I didn't have a strong enough power torque driver to use the vevor one. It looked Ike it would fit the carrier bearings.
    Abell207[QUOTED] likes this.
  19. Jan 4, 2025 at 7:29 AM
    #559
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  20. Jan 4, 2025 at 1:00 PM
    #560
    Dave8699
    Dave8699 Trackrat
    NJ
    Is it worth buying a spare carrier and have it regeard? I found a local one for pretty cheap just not sure what to look for and see if it would work for my truck.
  21. Jan 4, 2025 at 1:37 PM
    #561
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If it's a good deal. They demand top dollar in certain areas. Looks to be an 2009 and you'll most likely replace bearings and seals.
    **Yes 2019
  22. Jan 4, 2025 at 1:56 PM
    #562
    Dave8699
    Dave8699 Trackrat
    NJ
    Guy says it's a 2019 Like the stickers says 19-04-09. Ethier way if i do mine i was going to have it fully rebuilt.
    Mdl[QUOTED] likes this.
  23. Jan 4, 2025 at 2:16 PM
    #563
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Don't pay attention to my date reading...:rolleyes:
  24. Jan 4, 2025 at 2:46 PM
    #564
    Dave8699
    Dave8699 Trackrat
    NJ
    How could I tell if it's a 10.5?
  25. Jan 4, 2025 at 4:31 PM
    #565
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe group 33 is 10.5. The number under the scan code is the same iteration of the numbers above. Does he have the Vin code to see if its 4.10 or 4.30.
  26. Jan 5, 2025 at 5:15 PM
    #566
    helidave
    flagstaff
    2015 DC 4x4
    Happy to report no issues with axle splines fitting into the powertrax today. Slid right in, no hammering necessary.
  27. Jan 6, 2025 at 1:54 PM
    #567
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Finally got the front diff pulled for gear install. What a pain...
    reywcms likes this.
  28. Jan 6, 2025 at 3:05 PM
    #568
    helidave
    flagstaff
    2015 DC 4x4
    definitely easier with a helper. still had a hell of a time getting one of my cv's to pop free from the diff
    Mdl[QUOTED], Mater and FrenchToasty like this.
  29. Jan 7, 2025 at 10:58 PM
    #569
    blenton
    blenton New Member
    What seems to be the consensus on gear oil viscosity for the Speedmaster? Anything 140 weight just seems way too thick for winter climates.
    @Mdl
    @carn_dogg
    I might be scheduling an install soon, along with some 4.88's...
  30. Jan 8, 2025 at 12:31 AM
    #570
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I did the break in with 80/90 conventional and now have 85/140. The first person to do it broke his in with 140w but has been running 80/90 and he stated it locks up.
    From what I gather is the preload relies on the friction from the thicker viscosity to hook up quicker. Same thing with powertrax and people running synthetic with friction modifiers. It lessens the lock up but it still happens. From my conversation with a tech at speedmaster their lsd's were made for the racing/offroad crowd, where quick lock ups were need needed. It has been operating very well and is pretty predictable how it responds throttle input.
    blenton[QUOTED] and reywcms like this.
