  1. Jan 5, 2025 at 11:52 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Copper or brass.
  2. Jan 5, 2025 at 11:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've got 3 Taco 007 circulators on my heating system that have been running for about 8 years. They're flanged so you can replace the whole assembly with a couple gaskets or the motor cartridge can be replaced.
  3. Jan 5, 2025 at 11:57 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  4. Jan 5, 2025 at 12:23 PM
    Tundra family
    Tundra family New Member
    Thats awesome, saves up to 16k gallons and uses less power than a 25w bulb. I think those numbers along with "and youll have hot water without waiting 5 minutes" would make an easy sell. Gonna talk to Grandma this evening. Thanks for this info
    j-utah and TaquitoBandito like this.
  5. Jan 5, 2025 at 12:39 PM
    IMG_7494.jpgAll this hot water heater talk got me in a mood…..
    I haven’t flushed our tank in maybe 4-5 years, not terrible since our water is just that
  6. Jan 5, 2025 at 12:44 PM
    NWPirate
    Zach
    WA
    I think ill go with a Taco continuous duty pump like @ColoradoTJ posted.
    When I solder in the unions top and bottom, how does a guy spin all the nipples on without spinning off the other side?
    In the electrical world we have a 3 piece rigid coupling for this scenario
  7. Jan 5, 2025 at 12:50 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Installed new gutters on rental before house getting painted..lol
  8. Jan 5, 2025 at 12:51 PM
    I will go take a picture of how ours is installed.
  9. Jan 5, 2025 at 12:59 PM
  10. Jan 5, 2025 at 1:15 PM
    NWPirate
    Zach
    WA
    I was thinking the same thing but opposite with mine, pex on both sides of the pump.. :monocle:
    That way I can get everything in place and then crimp the rings.
    What do you think? @ZPhilip @Festerw
    TaquitoBandito and Florida AF like this.
  11. Jan 5, 2025 at 1:16 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    My eye has been effing twitching watching all these people call their water heaters HOT water heaters.:annoyed::frusty:
  12. Jan 5, 2025 at 1:16 PM
    NWPirate
    Zach
    WA
    Also FWIW, my whole house is Pex B except for this pump section
    TaquitoBandito and OldGuy03 like this.
  13. Jan 5, 2025 at 1:19 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd skip the pex and just use unions on both sides of the pump.
  14. Jan 5, 2025 at 1:22 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    My kitchen is this same color. Are you getting ride of the sunshine yellow?
  15. Jan 5, 2025 at 2:25 PM
    ZPhilip
    Philip
    West Chester, PA
    Please skip the Pex B as it causes a restriction compared to your copper there. I just don’t like Pex B.
    This is a picture of my water meter, not a recirculation pump. This is how I would install it with unions on each side. Looks like you already have valves on either side of the pipe also so you don’t have to drain down whole house when swapping.
  16. Jan 5, 2025 at 4:02 PM
    saybng
    Gary
    Ventura CA
    Yes we are..previous owners had house painted 6 years ago..a little too bright for my taste.
  17. Jan 5, 2025 at 4:18 PM
    Azblue
    The Dirty T ( ^_^)_且
    Sorry, but you are wrong, I'll explain. Say you have it set to 120, it heats up to 120 and then shuts off. Now some time passes and the water drops to 110, the unit fires up to bring it back to 120, but the water is already at 110 which I think most people would consider hot water. Thus, it is a hot water heater.
    KNABORES, Trooper2, OldGuy03 and 3 others like this.
  18. Jan 5, 2025 at 4:41 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    You're in AZ....110° is not hot.
    Also, hot water is considered giving you, at a minimum, 1st degree burns. Which in my wife's scale if temperature, is not hot enough to bathe in and considered "pee-warm" water
  19. Jan 5, 2025 at 5:12 PM
    NWPirate
    Zach
    WA
    :fistbump:
    OldGuy03 and TaquitoBandito like this.
  20. Jan 5, 2025 at 5:17 PM
    I take hot showers too :anonymous:
  21. Jan 5, 2025 at 5:22 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    I like the dust shroud
  22. Jan 6, 2025 at 11:13 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    My thoughts exactly!
    j-utah likes this.
  23. Jan 6, 2025 at 11:56 AM
    Tundra family
    The cold water tap in my trailer comes out at about 130° for most of the year. we're the folks who run water waiting for it to cool off :rofl:
  24. Jan 6, 2025 at 10:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Interesting
    My Taco inline circulator has been running for 18 years without an issue (goes and knocks on wood)
    We use both at work - don’t have significant issues with either, but those are also usually much bigger units.
    Does your pump run continuously? Looks like it’s plugged directly into the wall?
    I use a clip on aquastat that clips to the outside of the copper pipe to control my recirculating. When the line drops below the preset temperature, it will circulate until it comes back up to temp - significantly reduced cycle time on the pump but also doesn’t leave me hanging during “off times” (as opposed to using a timer).
    I also have all of my hot water lines insulated with 1/2” foam to help offset heat loss in that loop.
  25. Jan 6, 2025 at 10:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I would sweat the new one in. It is using the pipe to support it. Pex isn’t going to give it that support and may allow it to vibrate due to the rotation of the motor.
  26. Jan 6, 2025 at 10:27 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Ugh
    I forget you’re a sparky sometimes
  27. Jan 6, 2025 at 10:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    What these two said.
    No PEX
    The hardline supports the pump and provides straight line of smooth pipe to reduce flow restriction and possible cavitation.
    Unions are a watertight pipe version of your 3-piece couplings. Use sweat ones - don’t bother with threaded nipples here… it’s just more leak points. And always use two wrenches when tightening them - one to backup the “male” side and one to tighten the nut.
  28. Jan 7, 2025 at 5:33 AM
    NWPirate
    Zach
    WA
    This one is plugged in but has a timer on it
    :laugh:
    Yeah, I've convinced myself to sweat the connections.
    I can hear up the old solder to pull those pipes, right?
    I'm sure I'll have more questions :D
    TaquitoBandito likes this.
  29. Jan 7, 2025 at 5:55 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I have been working on our range hood past 2 weekends. Have some trim pieces and may redo the top 2 pieces to flow a little better, but all in all this is what the Mrs. Wanted.....
    IMG_0095.jpg IMG_0093.jpg IMG_0102.jpg IMG_0115.jpg IMG_0119.jpg IMG_0121.jpg
  30. Jan 7, 2025 at 6:36 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    We've done a lot around the house in the past few months, but I'm terrible at pictures.
    Installed an invisible fence for the pup.
    New garage doors(Costco program)
    Repainted the front door
    Started to add stone around the back side of the house since that faces north and gets zero sun. Just turns into a muddy mess with a hose bib there too.
    Blew out the irrigation system before winter
    Had an electrician come out and run another outlet outside for the hot tub. I'm not too happy about it. First, he didn't install a new breaker, just used one that was already there and open. Then no GFCI outlet outside. The hot tube is a 110v and I have it on a GFCI plug, but I still think he should have put an outlet or GFCI breaker in. Then I'm having an issue with that outlet as once the heater for the hot tub kicks on, it trips the GFCI cord. It never did that on the other outlet or when we had it running with an extension cord. He said he will come back out and take a look, but I'm starting to doubt that.
    Florida AF, j-utah and TaquitoBandito like this.
