  1. Jan 4, 2025 at 6:20 PM
    koditten
    Kirk
    Midland of the Mitten
    Did you disconnect the sway bar dog bone? You will not be able to lower the a-arm enough to cet the assembly out if you don't.
    grant.ducckk and bulldog93 like this.
  2. Jan 4, 2025 at 6:22 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Yep. Sway bar disconnected but won’t budge. Going to quit tonight and go after it again tomorrow.
  3. Jan 4, 2025 at 6:33 PM
    Tundra family
    Tundra family New Member
    We call that a tactical retreat, just enough time to regroup and reload. LOL
  4. Jan 4, 2025 at 7:37 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    My experience has been that I had to loosen the lower control arm bolts to get the lower to move/drop to be able to get other things to free up.
    Mark you cam tab locations first just in case you dork up and rotate one of them. And they are 24mm. 15/16” will kind of work, but 24mm is the right fit.
  5. Jan 4, 2025 at 7:42 PM
    Dsptundra
    Austin TX Area
    Casey - did you need to drop your skids to loosen the lca bolts?
  6. Jan 4, 2025 at 7:44 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Did you use a impact?
  7. Jan 4, 2025 at 7:45 PM
    Dsptundra
    Austin TX Area
    Yes, 1/2” drive.
    easleycrawler[QUOTED] likes this.
  8. Jan 4, 2025 at 7:46 PM
    easleycrawler
    Travis
    Damn. No advice now. Good luck.
  9. Jan 4, 2025 at 8:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    No.
    Short socket on a long-handle 1/2” drive breaker bar, and then a 15/16” box wrench once I had them broke free (it had been ~80k miles since they were last touched).
  10. Jan 4, 2025 at 8:05 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I will say, my lower shock bolts were no issue at all though. Nut came off easy and then I used a punch (smaller diameter than the shank of the bolt so the threads don’t get fucked up) to pound it part-way out. Then loosened the LCA bolts and used a second smaller floor jack to move the LCA up/down until I could find the “sweet spot”
  11. Jan 4, 2025 at 9:41 PM
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    Finally got my Fox 2.5 coil overs Front and rear shocks with dsc, Icon Upper Control Arms, and Icon leaf springs installed.
  12. Jan 4, 2025 at 10:13 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Just saw this, if you don’t mind how much did the pro trim set you back?
  13. Jan 5, 2025 at 2:47 AM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Are you selling the black and red trim if so I’m interested.
  14. Jan 5, 2025 at 2:53 AM
    littlebus01
    Tobias
    21 trd off-road
    Let me know if you decide to sell black and red trim.
  15. Jan 5, 2025 at 5:01 AM
    BAM3
    BAM3 New Member
    Houston
    2016 MGM CrewMax Platinum
    Nitto RGs, KMC wheels, DD fog lights, '21 LED Headlights, Retrax, 3" RC Lift, Tech12Volt Processor/JBL amp, TRD Sways
    Ive got your truck except in MGM. I just added a ‘21 TRD Grill and front and rear TRD sway bars for Christmas. Where did you get your mirror caps? How was the quality? This is my next purchase.
    Thanks!
  16. Jan 5, 2025 at 7:03 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I just switched over from the brown to black.
    HulkSmurf14 and bulldog93 like this.
  17. Jan 5, 2025 at 7:06 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    I believe it was around $180 part number is 55064-0C011-C4. Only issue is the air vent is chrome so I had to buy the black trim from ebay.
    68 RS/SS[QUOTED] and HulkSmurf14 like this.
  18. Jan 5, 2025 at 7:28 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    How is it going, get them swapped out??
    ZPhilip and koditten like this.
  19. Jan 5, 2025 at 8:14 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did you have the impact on the nut side? As opposed to the bolt head.
  20. Jan 5, 2025 at 8:19 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Yeah, I'm pretty sure he still is. Season 13 wasn't the same w/o him. They are my go-to when I've had a few drinks and want to laugh...
    1794TX[QUOTED] likes this.
  21. Jan 5, 2025 at 10:13 AM
    Dsptundra
    Austin TX Area
    No, I think this was my issue. I'll be back at it in a few hours. Picked up a few more tools (love an excuse to buy more tools) including a bigger breaker bar and 1/2" drive ratchet. Watched a few more videos. Method I plan to use: Disconnect sway bar, disconnect lower ball joint bracket from spindle to swing out of the way a bit, remove upper bolts, remove lower shock bolt after loosening the lower control arm bolts. Use my jack as needed to move control arm up and down a bit to facilitate lower shock bolt removal.
  22. Jan 5, 2025 at 10:30 AM
    blenton
    blenton New Member
    That’s how I’ve done it 9 times out of 10 and it works great. Sometimes a little pry bar action in the sway bar pocket helps move the LCA down to get the coilover bottom leg seated or unseated. I also leave one top bolt on part way so the bottom leg will disengage the LCA.
  23. Jan 5, 2025 at 10:31 AM
    ZPhilip
    Philip
    West Chester, PA
    I think you’re complicating things.
    Remove sway bar from LCA.
    Remove 4 nuts on top of coilover. Ratchet or wrench will work as these are only on with 33 ft lbs.
    Remove cotter pin and castle nut holding spindle to UCA. Breaker bar will work as its only tightened to around 85 ft lbs.
    Disconnect lower shock nut with impact gun. Tap bolt out.
    No need to loosen the bolts holding lower ball joint to spindle or the cam bolts. They are both tightened to over 200 ft lbs and could be a bitch to loosen. You can push down on the LCA enough to remove and install coilover.
    bulldog93, grant.ducckk, Piki and 3 others like this.
  24. Jan 5, 2025 at 11:00 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I, too, never messed with the LCA...
  25. Jan 5, 2025 at 11:16 AM
    RobertD
    Robert
    DFW, Texas
    See, I tried this method and after removing castle nut, I could not get that bolt out. After a lot of effort, I reassembled and loosened the LCA components and that was sooo much easier for me.
    bulldog93 and Tripleconpanna like this.
  26. Jan 5, 2025 at 11:28 AM
    ZPhilip
    Philip
    West Chester, PA
    Usually 3-5 hammer taps on the spindle will release it (press fit). I’ve swapped out my suspension 3 times and it’s worked for me.
    bulldog93 and HulkSmurf14 like this.
  27. Jan 5, 2025 at 11:36 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This looks right up my buddy's alley as he's planning to install a CB underneath his single DIN radio with a floating display. He bought the Metra dash kit but sent it back and bought the Dasaita kit when he saw it was metal. Thanks for posting these pics, Casey.
    bulldog93 likes this.
  28. Jan 5, 2025 at 11:39 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I installed RAS a couple weeks ago and its been pretty remarkable so far for ride quality and control. The truck definitely feels different to me. Haven't towed yet, but I'm sure it will make a big difference.
  29. Jan 5, 2025 at 12:53 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Installed new rotors/pads from EBC yesterday..it was a challenge trying to get those green pads in. Sorry no pic.
    Henry1jg, bulldog93, Mater and 2 others like this.
  30. Jan 5, 2025 at 12:54 PM
    DrunkenChewbacca
    DrunkenChewbacca New Member
    Josh
    2020 Tundra TRD OR
    Just finished my 2020 Tundra...For now.
    -OME 3" lift with freedom Offroad uppers.
    -Powerstop brake upgrade
    -RCI skids
    -RCI Rock rails
    -Fifteen52 17 wheels, 0 offset with Wildpeak AT3W tires little over 34s, like 34.4s
    -RDJ fender flares
    Interior-
    -Wolfbox Rear view mirror camera system
    -Victory Offroad Dash phone mount
