PCV Valve Replacement Instructions-4.7L
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2019.
  1. May 30, 2022 at 2:36 AM
    #61
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The foam cover appears to be:
    Toyota 12236-50010
    Cover, Ventilation Valve
    DarkMint likes this.
  2. May 30, 2022 at 4:40 AM
    #62
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The FSM for our 04 calls for 20ftlb and rotate as shown below !
  3. Jun 18, 2022 at 7:50 PM
    #63
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Found the foam cover thanks to @w666
    The PCV hoses differ between V8 and V6. Had to do some digging to ensure I got the V8 hose and not the V6.
    For the record, part numbers for a new V8 PCV hose, hose clamps, and foam cover:
    Pnwtundy and shifty` like this.
  4. Jun 19, 2022 at 8:03 AM
    #64
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I had a feeling that grommet would be a PIA. Had a new PCV installed, the grommet leaks like crazy. Crikey.
  5. Jun 19, 2022 at 8:22 AM
    #65
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So let's suppose you find a valve cover from a later generation truck that threads in. Could you just swap valve covers to be rid of the grommet?
  6. Jun 19, 2022 at 11:41 AM
    #66
    I don't see why you couldn't if everything lines up.
    Another member on here - @txagg ? - went through the "generational valve cover" swap, I think? I'll see if I can dig and find that. It was someone within the last 6 months, around the same time I did my gaskets. If I can find in the next 3-5 mins I'll update this reply.
  7. Oct 18, 2022 at 4:15 PM
    #67
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    2006 threaded...gunked up but still sounded good. Quick and easy. Let it warm up to go get beer and still a little tough to get loose. Foam was crumbly too but able to put back on.
    Sorry, phone decided to focus on the gloved hand...you get the point. Having issues with it connecting to laptop, looked a little more clear on the handheld computer.
    richsadams, FrenchToasty and shifty` like this.
  8. Mar 2, 2023 at 12:04 PM
    #68
    suley
    suley New Member
    Suleman
    2002 Sequoia Limited 2WD
    Hello Everyone!
    I am new here and would like to ask if there are two PCV valves on the 4.7 V8. I see the one which is being discussed but there seems to be another one on the other bank on a 2002 engine which looks like the threaded valve. Any ideas?
    Thanks!
  9. Mar 2, 2023 at 12:12 PM
    #69
    There's only one on my 4.7, on the driver's side. I've got the VVTi 4.7 that's in the '05-'06. Can you snap a pic of the PCV you're looking at on your truck's 4.7?
    Hi06silver likes this.
  10. Mar 2, 2023 at 12:30 PM
    #70
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    richsadams likes this.
  11. Mar 2, 2023 at 1:17 PM
    #71
    Do you know if it's actually valved, or is it just a vent?
  12. Mar 2, 2023 at 1:21 PM
    #72
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    On my 04, just a vent thru that 90 deg fitting. Not sure why Toyota Engs felt driver side needed an actual PCV unless it was there way thru throttle body to intake :notsure:
    shifty`[QUOTED] likes this.
  13. Mar 2, 2023 at 2:06 PM
    #73
    Yeah, dunno. I guess I just glanced over it when I did all my gaskets. Mine has it too. Huh. But I'm 90% positive it was just a crankcase vent, not a valve.
  14. Feb 3, 2024 at 8:38 PM
    #74
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Replaced mine today.
    Pretty tight but do-able.
    After removing the hose, I was able to get the closed-end of a 7/8" wrench over the old one to remove it.
    Didn't look bad, but since I already bought a new one & it was cheap, I swapped 'em.
    It's gotta be my imagination . . . but the truck seems to run a tad better . . . felt a little 'crisper', but I can't see how that could be.
    Dad01 and richsadams like this.
  15. Feb 10, 2024 at 1:41 PM
    #75
    bfunke
    bfunke Tundra Curmudgeon
    I don’t recall seeing any schedule to replace on our trucks but back in the day most maufacturers recommended replacement at 30K IIRC.
  16. May 29, 2024 at 7:28 AM
    #76
    Andy do
    Andy do New Member
    2006 tundra
    Thank you
  17. May 29, 2024 at 9:12 AM
    #77
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Could be partly imagination, partly reality. I swear my Tacoma always drives better - smoother, quieter, more pep - right after an oil change. I'm sure most of it is me knowing it's been taken care of. But I think it really is noticeable when everything inside the engine has fresh, uncontaminated, un-broken-down lubrication.
    My new PCV and grommet will be in my hands by the end of today. Another project for the weekend unless I decide to go camping. I've had this thread bookmarked.
    HBTundra likes this.
  18. May 29, 2024 at 2:22 PM
    #78
    bfunke
    I don’t notice anything after oil changes on my Tundras but my 2005 Suburban has noticeably less “vortec-tic” when the oil is new.
  19. Jun 2, 2024 at 12:06 PM
    #79
    MT-Tundra
    Montana
    Did this yesterday. Not sure if it had ever been done before, but it was really pretty clean. Replaced it anyway. Gasket is definitely a pain, but I got it out without dropping any bits into the valve cover. If nothing else, I feel better knowing there's a fresh gasket in there that'll take many years to get as hard and brittle as the one I pulled out.
  20. Jan 2, 2025 at 1:16 PM
    #80
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    On 2002 FSM. Recomends replacement or inspection every 30k I believe.
  21. Jan 2, 2025 at 1:44 PM
    #81
    MT-Tundra
    Montana
    Wow. That feels like way too often. Might be on my every 100k schedule. :D
  22. Jan 2, 2025 at 2:16 PM
    #82
    bfunke
    I just replaced mine on my 2000 AC. Old one didn’t look terrible and rattled when shaken. Rubber grommet was stiff but came out in one piece. Replaced ‘em both since they are cheap and I already had new ones.
  23. Jan 3, 2025 at 4:46 AM
    #83
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    If you haven’t done it already you may want to get a new hose for the pcv valve. I replaced my valve and the hose was so old and dried out that it split when I disconnected it.
    bfunke likes this.
  24. Jan 3, 2025 at 6:46 AM
    #84
    Mine too. Ends were completely cracked up. Can't remember if I posted pics on here or not.
    I need to go through and replace all my rubber hoses in the engine bay sooner than later, but I've been too damn lazy to look them up.
    I feel like @Tundra2 posted a website on here once that shows you the hoses you need by year. I know with our VVTi engines, the hoses are slightly different, if for nothing more than you have the hoses between the SAI solenoids above the passenger valve cover, which link to the SAI valves on the back of the intake.
    KTM_AJ421[QUOTED] likes this.
  25. Jan 3, 2025 at 9:26 AM
    #85
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I got quite a shock when that tiny hose piece was over $50!
  26. Jan 3, 2025 at 9:48 AM
    #86
    bfunke
    Ventilation hose #2 is NLA for early FGT. I had to improvise to make the later hose fit over the smaller nipple.
  27. Jan 3, 2025 at 11:07 AM
    #87
    Fifty-what? This is before the applied 15-25% off seasonal discount (I forget what it was last year), so not even $45 for all of them. It's for '06 also, so price and part number should be identical for your year. #2 is passenger side, #1 is driver side.
    Purchased from Lagrange Toyota online, but Serra Toyota of Birmingham's prices were within $10 of this.
  28. Jan 3, 2025 at 11:13 AM
    #88
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I think I was thinking $50 because I bought two at the local dealer. One for my truck and one for the 4Runner which both have the v8 but the hoses were very different
