RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Dec 27, 2024 at 8:03 AM
    #1231
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Not sure about @TRDFerguson ‘s Z rated Trail R/T’s are doing but mine have become really hard of late. Not sure if something happened to them when they sat for 12 weeks earlier this year but they’ll chirp if I brake too hard and are like driving on ice skates with any moisture on the ground. Anyway, just my experience..
  2. Dec 27, 2024 at 8:05 AM
    #1232
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Mine seem to be holding up okay, other than being beat to hell from driving over/through sharp rocks...
  3. Dec 27, 2024 at 9:10 AM
    #1233
    TaquitoBandito
    Joel (AKA Bif)
    I get it man. The HEB and Costco parking lots have been hell on the Bifmobile's tires.
    ToyoMafia, bulldog93, 1794TX and 5 others like this.
  4. Dec 28, 2024 at 5:29 PM
    #1234
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I've been needing to tear back into the backside of my Alpine head unit to troubleshoot why my backup camera has been intermittently working, as well as routing the cables needed for my Icom radio install so that the control panel and speaker can be mounted up on the Rago dash plate. I was also having a minor "creaking" sound from the radio mount on bumpy roads that I wanted to solve. So today I decided it was time to tear into things.
    Original radio install post here.
    First, let me say: Alpine, this cluster-fuck is absolute bullshit. There is absolutely no reason you need to have all those little connector harnesses that then require additional connector harnesses to connect to the actual thing they will connect to.
    ANYWAY, back to the matter at hand. First order of business was to strengthen the mounting interface so that the creak would go away. My plan was to use the factory head unit brackets and "sandwich" the Dasaita radio trim brackets. Of course, the holes don't entirely line up. I also noticed that the Dasaita trim stood a lot taller than the actual head unit body, and there was some risk of the wiring that was stuffed in the opening rubbing against those side walls.
    I started with the factory brackets - part numbers 86211-0C080 and 86212-0C080. I don't remember which is Right and which is Left, but you need one of each.
    I first marked a where the Dasaita side brackets extended above the head unit, then I overlaid the factory brackets onto the Dasaita ones and traced that outline as well.
    Because the factory bracket would only cover one of the existing radio holes I was using, I decided to layout a new hole in the Dasaita brackets that would sit within the outline of the factory one. I used some blue tape to do this by popping holes through the two existing holes and the new hole that matched threaded holes in the head unit. Then line that tape up on the holes in the bracket to mark the bracket.
    Then, once the holes were drilled in the Dasaita brackets, I ground the little locator nubs off the factory brackets, lined them up over the Dasaita ones so that the dash mount holes were aligned, and marked the new hole locations in the factory brackets.
    Then we moved on to a cut-off wheel to chop off excess bracket that wasn't needed from both the Dasaita brackets and the factory ones before finally mounting it all back onto the sides of the head unit.
    Then I wrapped the edges with some Tessa tape for a little protection.
    Then, I moved on to the Icom radio controller cable and the external speaker. I popped the center speaker grill (this is also a great way to reach in and help maneuver the cables behind the head unit while stuffing it into place) and removed the center speaker temporarily. Then I fished the speaker cable and controller cable down behind the glove box and into the center console hump and left them in there for now until I am ready to finish the actual radio install. At least at this point I don't have to pull the head unit out again to route that.
    Finally, I buttoned everything back up, checking very carefully to ensure everything was properly connected, that connectors were double & triple checked for good connection, and that any "slip fit" connections were wrapped well with tape. The extra clearance from having the side brackets removed helped in fitting everything inside without pinching or cramming.
    The drive home there was no discernable creaking from the head unit, and the backup camera seems to be working like it is supposed to.
    Now I need to lay low on the mods for a little while and get some honey-do's done or I'm gonna be sleeping in my truck.
  5. Dec 28, 2024 at 5:55 PM
    #1235
    TaquitoBandito
    Joel (AKA Bif)
    You can sleep in my truck. Bring all of your tools and feel free to mod it to your liking. :)
  6. Dec 31, 2024 at 1:56 PM
    #1236
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Still haven't put mine in... So I keep watching your follies so that I only have to do it once :rofl:
  7. Jan 1, 2025 at 6:37 PM
    #1237
    RainMan_PNW
    Casey
    Clark County, WA
    Keep putting it off and we’ll be installing it in camp in April!
    TaquitoBandito likes this.
  8. Jan 2, 2025 at 7:15 AM
    #1238
    memario1214
    Colton
    Missoula, MT
    You promise?
  9. Jan 2, 2025 at 8:38 AM
    #1239
    RainMan_PNW
    Casey
    Clark County, WA
    That depends on what you offer in return…
    TaquitoBandito and TRDFerguson like this.
  10. Jan 2, 2025 at 8:53 AM
    #1240
    memario1214
    Colton
    Missoula, MT
    *Folds like a camp chair*
  11. Jan 2, 2025 at 8:56 AM
    #1241
    RainMan_PNW
    Casey
    Clark County, WA
    GODZILLA, TaquitoBandito and RobertD like this.
  12. Jan 2, 2025 at 10:05 AM
    #1242
    TaquitoBandito
    Joel (AKA Bif)
    Y'all talking like that makes Tundras 2 Sedona camp sound like the Olympic Village... Good thing I've got Taquito Bandito branded Vegan rubbers in production... Look for the Taquito tent at Sedona for your Taquito Tents.
  13. Jan 2, 2025 at 10:06 AM
    #1243
    memario1214
    Colton
    Missoula, MT
    TAQUITO TENT! TAQUITO TENT!
  14. Jan 2, 2025 at 10:08 AM
    #1244
    TaquitoBandito
    Joel (AKA Bif)
    Tripleconpanna likes this.
  15. Jan 2, 2025 at 10:56 AM
    #1245
    1794TX
    Steven
    N.TX
    '20 1794
    "TAQUITO TENT! TAQUITO TENT!" - Mrs. Bandito every morning. Allegedly.
    WILLINH, Kung, Tripleconpanna and 5 others like this.
  16. Jan 5, 2025 at 3:16 PM
    #1246
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Any thoughts on the new suspension?
    Abell207 likes this.
  17. Jan 5, 2025 at 4:22 PM
    #1247
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I would also like to hear feedback on those Bilsteins.
  18. Jan 6, 2025 at 6:38 AM
    #1248
    RainMan_PNW
    Casey
    Clark County, WA
    Absolutely love it
    Haven’t gotten to go bang on much because of life stuff around here, but have been finding plenty of rough pothole-filled regular roads around here to try and hit harder than normal.
    The back end with the RAS removed isn’t quite as tight as with the RAS, but still feels good. Enough so I’m not missing the RAS (haven’t put a big load in the bed yet though).
    We have some notoriously bad sections of freeway around here with massive settlement gaps/uneven spots/holes (the state’s answer was to put up “Rough Road 50 MPH” signs for 5 miles) that are crazy how little you feel with the new shocks.
    Still need to find time to get out and hit some old forest service roads, but not sure when that will be.
  19. Jan 6, 2025 at 6:43 AM
    #1249
    ZPhilip
    Philip
    West Chester, PA
    What are your low and high speed setting at right now?
    I went full soft on both and will experiment from there. I don’t miss my RAS but I will be hooking up my dump trailer in a few weeks to test out the sag level without it.
  20. Jan 6, 2025 at 10:13 PM
    #1250
    RainMan_PNW
    Casey
    Clark County, WA
    I’m currently set where Bilstein sets them from the factory - which is 1-2 clicks “soft” from middle according to the instructions.
    I’ve just been to swamped to do any playing around - I’m amazed I got them installed before 6 months had gone by.
    WILLINH, TaquitoBandito and RobertD like this.
  21. Jan 7, 2025 at 7:30 AM
    #1251
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Although the Fogster is super simple to install, I'm glad I read this post for a different idea of how to access the Headlight Plug. I had been looking from above and convinced myself I was going to have to remove the Headlight to access the completely inaccessible plug. Appreciate that you documented this super simple install.
  22. Jan 7, 2025 at 8:05 AM
    #1252
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    I don't trust the dealer to install a gas cap, much less my oil drain plug. Free or not, no one does maintenace on any of my vehicles, other than myself. They just don;t give a shit about your property
  23. Jan 19, 2025 at 7:24 AM
    #1253
    ZPhilip
    Philip
    West Chester, PA
    @RainMan_PNW
    What are your thoughts on using the CB spacer shim vs dialing up the adjustment on the shock bodies for more lift?
  24. Jan 20, 2025 at 10:30 AM
    #1254
    RainMan_PNW
    Casey
    Clark County, WA
    Leaning heavily on @memario1214 on this one - the consensus is to keep the shocks in the middle of their “sweet spot” as set by the factory for valving performance. Their default setting is offset to account for driver’s side lean but running them up to max doesn’t necessarily put them in their ideal position.
  25. Jan 20, 2025 at 12:23 PM
    #1255
    ZPhilip
    Philip
    West Chester, PA
    Ok cool. Thats what I assumed was going on. Are you running the 1/2” or 1” lift shim?
  26. Jan 20, 2025 at 1:04 PM
    #1256
    RainMan_PNW
    Casey
    Clark County, WA
    1/2" lift (the shim measures 1/4" thick)
    WILLINH and ZPhilip[QUOTED] like this.
  27. Jan 26, 2025 at 3:21 PM
    #1257
    tjacob95
    tjacob95 New Member
    2014 toyota tundra limited
    what wheels are these?
  28. Jan 26, 2025 at 3:33 PM
    #1258
    RainMan_PNW
    Casey
    Clark County, WA
    RobertD likes this.
  29. Jan 27, 2025 at 1:03 PM
    #1259
    tjacob95
    tjacob95 New Member
    how did you get them to stick tried this with a patch couldnt get it to stay
  30. Feb 2, 2025 at 12:57 PM
    #1260
    RainMan_PNW
    Casey
    Clark County, WA
    Lots of mashing, smashing, and twisting…and even then they are precarious at best.
    TaquitoBandito and Patch999 like this.
