K&N yea or nay?
Discussion in '1st Gen Tundras (2000-2006)' started by evetsclary, Jan 1, 2025.
  1. Jan 1, 2025 at 2:45 PM
    evetsclary
    evetsclary [OP] New Member
    My 2002 was purchased with a K&N air cleaner kit. Is this preferable to the stock air cleaner set up?
  2. Jan 1, 2025 at 3:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    No. No power advantage and KN lets more particulates through. Also the oil can foul your MAF sensor.
    MadMaxCanon, HBTundra and ATBAV8 like this.
  3. Jan 1, 2025 at 3:37 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Nay. If it's just the filter, throw it out and buy an OEM filter. If it's the whole airbox, well, that's different. You can source a stock airbox from a junkyard. Either way, oiled filters aren't anything but hype, and can cause problems with the MAF sensors and throttle bodies. You'll probably want to clean both up with appropriate products. Search in this forum for "cleaning MAF and throttle body".
    coldcanuk and HBTundra like this.
  4. Jan 1, 2025 at 4:55 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Another vote for 'Nay'. Ditch the K&N
    The stock airbox / filter element from Toyota IMO is a very substantial setup.
    The location allows for the cleanest / coolest air as is reasonably possible.
    The element itself is large, with plenty of surface area, and the seal seems well designed.
    I change mine every 2nd or 3rd oil change, depending on where I've driven.
    Someone on here made a good point once regarding the stock air filter setups on these trucks . . . saying that the excellent filtration and air flow that it provides contributes to the longevity of these motors . . . provided it's changed at appropriate intervals of course.
  5. Jan 1, 2025 at 5:27 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Don't do it
  6. Jan 1, 2025 at 5:39 PM
    evetsclary
    Thank you all - I see the kit advertised and wondered why the previous owner made the modification. I plan to restore it to original. Thanks, again.
    G_unit3000 likes this.
  7. Jan 1, 2025 at 5:45 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    cause his ass dyno can feel the 2hp difference.......
    on the top end......
    cause he raced his tundra.
    whodatschrome likes this.
  8. Jan 1, 2025 at 5:55 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    They have great marketing. I fell for it at one point too. They also come as the stock filter in the Magnuson Supercharger kits and went straight into the trash.
  9. Jan 2, 2025 at 5:18 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I vote OEM airbox, OEM filter and the true cool air intake (snorkel)
  10. Jan 2, 2025 at 6:49 AM
    G_unit3000 and Outbound like this.
  11. Jan 2, 2025 at 6:53 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I had one way back, on my 86. Didn't notice any hp difference, but I bought the marketing so it made me feel good knowing it was there. Eventually started hearing all the things you're hearing here so I went back to paper filters.
    The Black Mamba likes this.
  12. Jan 2, 2025 at 7:12 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Nay!
    My 2000 came with one when I bought it. It made a LOT of intake noise -- so much so that it would scare my dog if I floored it when she was riding with me. I gladly sold it, and replaced it with a stock unit.
    EDIT: Here's a suggestion. List it on FB Marketplace or CL with an offer to trade for an OEM intake. You can probably make $50-$100 and get the intake you want. Just a thought.
  13. Jan 3, 2025 at 5:21 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I'd toss it. My truck also came with one, thing was filthy (never cleaned, my guess). I tossed it and put a standard filter on. I had used some K&N filters in the past, even their whole intake system. The filters just added noise, and the intake system seemed to be more trouble than it was worth.
  14. Jan 3, 2025 at 5:23 AM
    FishNinja
    Lee
    06DC2wd
    I'll also add.
    AEM and K&N are the same company.
    AEM makes DRY version of the same performance filter.
    If you INSIST on using a Performance filter. Use the AEM dry filter.
    G_unit3000 and shifty` like this.
