General Supercharger Thread
  1. Jan 1, 2025 at 12:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wishing you all a Happy New Year! Best of health and happiness in 2025!!
    Rip em up....
  2. Jan 1, 2025 at 4:06 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Merry New YEAH!!!
    May all your boosts come true!
  3. Jan 1, 2025 at 6:10 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Happy new year fellas
  4. Jan 1, 2025 at 10:36 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Happy new year guys. Just came to the realization that I’ve basically been running the equivalent of a 2.35” 1900 pulley with my 77.5mm Harrop pulley, since comparatively it’s an 82.5mm when factoring in the measuring discrepancy. Not a whole lot different than the flow had from stock pulleys offered on the Magnusons out of the box. Not nearly as spicy as I thought, but I’m actually happy to be doing more than expected with less effort as far as performance. The out of the box Harrop pulley (85mm) is really a 90mm. Seems they run the most conservative boost with their provided pulley. Maybe should have done the 75mm, but I guess I’ll spare my transmission. Shower thoughts.
    :monocle:
  5. Jan 1, 2025 at 11:00 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Bro! You still hold the fastest time on the spreadsheet. Get those gears installed and let the times tell you what you need. ;)
  6. Jan 1, 2025 at 11:12 AM
    Silver17
    Eastern PA
    I am excited to see the 5.29 difference for sure! And I guess it’s up there on the sheet, although I think there are faster. @Mdl ran some real rippers lately granted with more boost, but he’s got the quickest I think with those of us with “normal” trucks, as in not Viktor. Lol
  7. Jan 1, 2025 at 11:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    This made me chuckle because of what "normal" has become. Seeing how we're only 14:20 into it, 2025 is already looking to be a record breaking year of spend. LOL
  8. Jan 1, 2025 at 12:22 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I envy you with your big pulley. I've been on the debate train lately about going to a turbo since I don't think the 2650s with the smallest pulley would make the boost I'd want. The altitude takes any excess and wipes it away, making you beg for even the stock blower experience :oops:
  9. Jan 1, 2025 at 12:36 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    i dunno, your small pulley on my 2650 at my elevation make a hell of a difference
    snivilous[QUOTED][OP] likes this.
  10. Jan 1, 2025 at 12:41 PM
    blenton
    blenton New Member
    Do both. Super-turbo V8's are a real thing.. :D
  11. Jan 1, 2025 at 1:00 PM
    Silver17
    Eastern PA
    What’s the goal? Built engine and different (non Toyota) trans levels of boost? The smallest pulley paired with a bigger crank pulley would net over 20psi at sea level based on Viktor’s setup as I recall.
    HulkSmurf14 and e30cabrio like this.
  12. Jan 1, 2025 at 1:03 PM
    snivilous
    SW UT
    I just want more power, with the 2.0" on the 1900 I'm lucky to see 8psi. I could do the crank pulley, but that sounds like a lot of screwing with stuff I'd rather not do hahaha
  13. Jan 1, 2025 at 1:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I got the 2.0 pulley and my ASP crank is 6.71or .75. Not too bad. Prospeed, I know you want to give them $, has the 7 inch adapter for the crank pulley.
  14. Jan 1, 2025 at 1:33 PM
    snivilous
    SW UT
    Don't you have to pull the radiator and stuff to get to it though?
    HulkSmurf14 likes this.
  15. Jan 1, 2025 at 1:37 PM
    blenton
    blenton New Member
    I hit 6.4 psi the other day.. :bananadance::bananadance::bananadance:
    The struggle is real...
  16. Jan 1, 2025 at 1:37 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Didn’t pull the rad for the new light weight harmonic balancer.
  17. Jan 1, 2025 at 1:39 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Just the fan
  18. Jan 1, 2025 at 1:40 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I had to remove the radiator, might just depend on your pulley removal tool, I could have cut mine down and made it work without removing the radiator. It still would have been tight with the shroud in the way, and the radiator has to be drained to remove the shroud, so might as well yank it out.
    snivilous[OP] likes this.
  19. Jan 1, 2025 at 1:43 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    And you'll need an adapter to relocate the oil pressure sensor, depending on the pulley size. The ATI pulley I got is stock belt pulley, but larger damper so I had to modify mine.
    Silver17, Mdl, HulkSmurf14 and 3 others like this.
  20. Jan 1, 2025 at 3:10 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Race truck stuff...
    Silver17, reywcms and Mdl like this.
  21. Jan 1, 2025 at 4:26 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I didn't have too. I have the e-fan so no fan in the way. But I remember swapping it with the mechanical fan on. I didn't require a puller either. Just used this to hold for removing and torque.
  22. Jan 1, 2025 at 5:08 PM
    snivilous
    SW UT
    Is the crank pulley not press fit on?
    At $400 from Prospeed I may as well design my own.
    ssmokedz, AZTundra, Ryuu and 6 others like this.
  23. Jan 1, 2025 at 5:40 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    ASP will make whatever size you want, and its a balanced crank pulley.
    I did utilize the 2 bolt holes to press it off. It wasn't on tight where I thought it would compromise the cover. But others may differ.
  24. Jan 2, 2025 at 6:21 AM
    ssmokedz
    Shelton CT
    It is not pressed on. I usually give the outer edges of the pulley a couple taps with a hammer quick and then pull it right off.
  25. Jan 2, 2025 at 6:30 AM
    nags
    nags New Member
    This. My dude is going on 6 months now of waiting for his Whipple.
  26. Jan 2, 2025 at 6:48 AM
    ARES35
    ARES35 New member for life
    Mile high
    Alright dropped truck off before work for the front and rear gears/mk's and lsd. Excited to take some strain off the tranny and hope she rips!:mudding:
  27. Jan 2, 2025 at 7:02 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Damn, you move fast!
    Mdl and ARES35[QUOTED] like this.
  28. Jan 2, 2025 at 7:07 AM
    carn_dogg
    Pat
    Eastern Shore MD
    6 months is insane. Not sure what is going on with whipple right now. Materials shortages maybe? Chinese new year effecting things. Who knows. But that's a gnarly lead time for a piece of metal.
  29. Jan 2, 2025 at 7:10 AM
    ARES35
    Mile high
    Just dumb luck. Between toyota being able to work out a deal, get a transmission and install within a week and this drivetrain shop able to fit me in this week with a good price luck has been on my side. I'm gonna buy some loto tickets lol
    Mdl likes this.
  30. Jan 2, 2025 at 7:17 AM
    blenton
    blenton New Member
    That CAN’T be right?! Their lead time was 4 weeks before Black Friday and 12 weeks afterwards. Did he order direct or through a retailer?
    ARES35 and nags[QUOTED] like this.
