General Supercharger Thread
  1. Dec 30, 2024 at 4:33 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Fluid ounces is volume. 1 fluid ounce =29.57ml.
    HulkSmurf14, koditten and e30cabrio like this.
  2. Dec 30, 2024 at 4:42 PM
    blenton
    blenton New Member
    but what about… fluid ounces… ?
  3. Dec 30, 2024 at 4:43 PM
    blenton
    blenton New Member
    Dang it! U beat me to it..
  4. Dec 30, 2024 at 4:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It is crazy...I don't even know how I correctly bake anything anymore. Did you weigh the flour? No, it calls for one cup...but it calls for 125 grams or is it 227grams. Crazy crapolla!
  5. Dec 30, 2024 at 5:20 PM
    koditten
    Kirk
    Midland of the Mitten
    Oh, now you throw FLUID ounces at me! I did not see that qualifier.
  6. Dec 30, 2024 at 5:22 PM
    blenton
    blenton New Member
    If we as peoples of the interwebs were more specific, this would be a very boring place…
    :bored:
  7. Dec 30, 2024 at 5:34 PM
    Silver17
    Eastern PA
    All the talk of ounces and milliliters I didn’t yet watch this. Pretty cool being able to control boost and log data on an app. It was weird he didn’t mention which rotor pack it has. I don’t see how it isn’t at least the 2650, maybe the 3.1L 3 lobe rotor pack they never released and that’s why it’s a secret?
    reywcms[QUOTED] and e30cabrio like this.
  8. Dec 30, 2024 at 6:09 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Imagine the possibilities...boost ramp to control traction, limit boost time to keep stock parts happy, valet mode, control boost if running larger pulley for elevation and lower for going to sea level, pretty cool stuff! If they integrate with OBD they could do things like limiting boost based on IAT or fuel levels, which could save people from making expensive mistakes.
  9. Dec 30, 2024 at 6:31 PM
    Silver17
    Eastern PA
    Totally unrelated but good for a laugh.
  10. Dec 30, 2024 at 7:58 PM
    blenton
    blenton New Member
    I think we discussed an electronic boost controller a while back. I don't recall if it was this one, but SmoothBoost makes a retrofit kit for Magnuson, Whipple, and a few others. Unfortunately it appears that they are application specific due to the fact that they tie in to the Throttle Position Sensor to control boost, rather than vacuum. I'm guessing you would need a translator box to interpret the TPS, but 0-5v is 0-5v, so maybe not. Costs a grand to start.
    https://www.smoothboost.com
  11. Dec 30, 2024 at 8:12 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Hopefully simple question. Is the bolt for the idler pulley below the Supercharger pulley right or left handed? Wanted to confirm before I crank on it haha, it’s an awkward one to get to. It would seem odd to me that both top idlers are threaded in the same direction since they spin in different directions.
  12. Dec 30, 2024 at 8:19 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Interesting video. It definitely clarifies the inconsistent amounts. Shows how spec would have changed over the years through more testing. The recommended amount is lower now than when the SC first came out but there is still an acceptable range that will still work fine. Cool info.
    e30cabrio[QUOTED] likes this.
  13. Dec 30, 2024 at 9:01 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I've talked to that guy a bunch. They have a kit that will fit the 2650 on our trucks. Taps into the 5v output on the throttle body or into the gas pedal.
  14. Dec 30, 2024 at 9:22 PM
    blenton
    blenton New Member
    Praytell...
    nobodyintexas likes this.
  15. Dec 30, 2024 at 9:33 PM
    helidave
    flagstaff
    2015 DC 4x4
    That's about it. Bolts right on. hook up power, ground, and signal. knob sets the max psi, and you can add a scramble button if you want. throw on the party pulley and you can dial in any boost you want at any elevation. he said they have some customers with tundras running it with no issues
  16. Dec 30, 2024 at 9:45 PM
    blenton
    blenton New Member
    That might actually be worth it to me. It's not uncommon for me to go up 2 or 3k feet in elevation, pulling a trailer. I wonder what other considerations one might need to make in order to keep from fragging the motor.
  17. Dec 30, 2024 at 9:55 PM
    helidave
    flagstaff
    2015 DC 4x4
    I dont think it would add anything new to worry about. Just don't dial the boost up past what your setup can handle. Sounds like the boost curve might ramp up different than the vacuum bypass, so tune might need adjusting
    I'm always going up and down in elevation too, so it's at the top of my wish list
    e30cabrio likes this.
  18. Dec 31, 2024 at 6:21 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I was concerned the pulley was too far forward. I was able to move it back with the pulley attached. Answering the question can it be done, my eBay tool did not make any contact with anything but the hub.
  19. Dec 31, 2024 at 8:33 AM
    ARES35
    ARES35 New member for life
    Mile high
    Got 2 quotes for gear/LSD install. First was $1700 front gear and master kit, $1700 rear gear, lsd and master kit. This is a well known local transmission shop. 2nd is $995 plus shop supplies, tax and axle seals. This is from a high review drivetrain shop. Not only that, he scheduled me this Thursday and said he be done in one day:eek:
  20. Dec 31, 2024 at 10:03 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Only the tensioner pulley is left handed rest are right. You probably already figured it out...
  21. Dec 31, 2024 at 11:11 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Question....
    Whipple vs Magnuson for the Tundra?
    The price is close enough that price isnt an issue.
    If I remember correctly Magnuson made the TRD Supercharger for the Tacoma and I was very happy with it.
    I'm kinda leaning towards the Magnuson at this point.
  22. Dec 31, 2024 at 11:18 AM
    koditten
    Kirk
    I gotta make the same decision soon.
    I'm leaning towards the Whipple.
  23. Dec 31, 2024 at 11:25 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Debated to death. Get what suits you. I went from a magnuson 1.9 to Whipple and it’s night and day different
    nags, Mdl, ARES35 and 3 others like this.
  24. Dec 31, 2024 at 11:40 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    See this is the kind of info I need.
    Going into this blind really sucks!!
    Back then the TRD SCer was my only option.
    So what do you like about the Whipple over the Magnuson?
    ARES35 and e30cabrio like this.
  25. Dec 31, 2024 at 11:44 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Guess I'm not done with my research.
    While it's nice to have options it sometimes can be a pain in the Azz!!
  26. Dec 31, 2024 at 11:44 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    He likes that it lets him blow the tranny.
    Oh wait, could that be in part due to biggest tires smallest gears (@snivilous :thumbsup:) and no trans work (modified valve body?).
  27. Dec 31, 2024 at 11:47 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    About to find out! Had to go buy offset metric wrenches as that appears to be the only thing that can remove the 15mm on the crossover Idler Pulley. Toyota replaced my alternator under warranty believing that was the source of the sound (spent all day at Toyota… ya). Then handed me the keys and said that didn’t fix it and it’s likely the supercharger, which I doubted as I replaced the coupler myself 10k miles ago. I then got a mechanics stethoscope and Im no expert but one of the idlers was so loud with it you can’t keep the stethoscope rod on it, so guessing that’s the issue (TBD lol).
  28. Dec 31, 2024 at 11:49 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Definitely something to think about!!
    I just retired and it was tough to convince the Wife I need a Blower on my truck!!
    I start tearing up transmissions I'll never hear the end of it!!!
    e30cabrio and carn_dogg like this.
  29. Dec 31, 2024 at 11:53 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Any particular reason?
  30. Dec 31, 2024 at 11:54 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Twinscrew over roots- and bigger displacement. Easier to get to things in the engine bay. And it’s different than what everyone else is running lol
    nags, HulkSmurf14, Mdl and 4 others like this.
