General Supercharger Thread
  1. Dec 30, 2024 at 8:30 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    What mine ended up looking like. Just put it everywhere I could
  2. Dec 30, 2024 at 8:42 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That's definitely not what I did when I changed the oil. I turned that bitch upside down (maybe unbolted the back cover to inspect too), then flipped it over and filled it to the hole. The hole could be placed just about anywhere, so it being strategically low indicated to me it was a fill to the hole scenario. SCOL set me a little oil container which I only used about half of, and it didn't seem like anything special whatsoever, definitely don't remember it smelling bad.
    Hopefully I didn't fuck up, but I'd be shocked if there was some special amount it needed and the fill oil just happened to not be in the right spot. There's just two gears in the backside and you can see from the fill hole position that both gears would end up covered in oil filling to it.
    Oh well, I guess we'll see if the blower ever has issues.
  3. Dec 30, 2024 at 9:07 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Heck I don’t know, here’s some posts I saved about it. I’m just a master of regurgitating information I read online, not a master with the wrenches.:D Steven “Gadget” owns URD IIRC and Brian Zacuto is from SCOL. Both of them should know these units pretty well I think.
  4. Dec 30, 2024 at 9:10 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Holy contradictory info Batman!
    lol
    Is it safe to assume JB's kit is ok to use as instructed (it says it is the exact best oil & amount) I have 2 SCOL bottles coming some day, ordered the same time, it's still processing.
  5. Dec 30, 2024 at 9:13 AM
    Silver17
    Eastern PA
    e30cabrio likes this.
  6. Dec 30, 2024 at 9:17 AM
    e30cabrio
    We have Radix which is 7, so I need to use 1 oz less? Confusion you are an asshole.
    lol
    Called SCOL to see what was going on with the order, it is ready to ship but unshipped, I asked to cancel & they are charging 5%.
    They ware closed until today but there is no notification on the site, I called last week trying to order & it just rang, she said there was a message on the phone. NOPE.
    IMHO Kinda creepy
  7. Dec 30, 2024 at 9:35 AM
    Silver17
    Eastern PA
    I think I shared this one a long time ago on here, but it answers a lot of questions which I assume are somewhat universal across most Eaton superchargers.
    Takeaways were slightly less oil is better than overfilled. Don’t fill to the hole, and the best way to get it all out is to remove the cover whether that be front or rear in the case of your blower. https://m.youtube.com/watch?v=3NFfZaS1XBU
  8. Dec 30, 2024 at 9:42 AM
    snivilous
    SW UT
    e30, drain your supercharger again and fill it to the hole and tell us how much volume that is :D
  9. Dec 30, 2024 at 9:44 AM
    e30cabrio
    It's drained as much as an hour sitting on its back dripped out of the hole. I'm waiting for the JB kit to come. I'll report what putting the 8 OZ in does
  10. Dec 30, 2024 at 10:06 AM
    M3Tundra-JK
    Scott
    2005 GX470
    also tell us if it smells lol. The Taco s/c oil definitely did, and is notorious for smelling bad over on tacoworld thread.
  11. Dec 30, 2024 at 10:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Procharger oil used to smell like absolute cat piss. Never had a positive displacement blower smell as bad as that. Whipple also sent pre measured amount to use. I would fill recommended. That oil doesn’t go anywhere else
  12. Dec 30, 2024 at 10:24 AM
    e30cabrio
    Doesn't smell good but it's not awful (oil that came out)
    I emailed JB & asked how much to put in.
    Maybe I'll send it to Blackstone.
    That's all I had. Did the best I could.
  13. Dec 30, 2024 at 12:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When I used the ptr29-34087 service kit from Jon Bond it was Eaton oil. I was able to drain it and it took all 8 oz/205ml. Even included the Toyota service bulletin that I posted a few pages from.
    Wynnded, snivilous[OP] and e30cabrio like this.
  14. Dec 30, 2024 at 12:17 PM
    e30cabrio
    I know and appreciate all of your input. The JB kit came, I loaded the Amazon bigger syringe with the entire bottle and used all of the oil.
    Thanks!
    carn_dogg, Mdl[QUOTED] and reywcms like this.
  15. Dec 30, 2024 at 3:29 PM
    e30cabrio
    JB's response:
    Guess I'm taking 2.9 out.
    FUN!
    Mdl and armyoffoo like this.
  16. Dec 30, 2024 at 3:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well I guess I've been running 8 oz for 9 years.
    As per Toyotas service bulletin...is there a different design?
    e30cabrio[QUOTED] likes this.
  17. Dec 30, 2024 at 3:38 PM
    e30cabrio
    So leave it? Confused needs to be my middle name.
    I got a cart so I'm not going back & forth to wherever I left my tools (assuming I stick to putting them back on the cart)
    lol
    M3Tundra-JK likes this.
  18. Dec 30, 2024 at 3:40 PM
    Silver17
    Eastern PA
    If it were mine I’d 100% follow SCOLs recommendation of 7 oz above all others. That said, probably won’t make a noticeable difference, but 1 ounce is over 14% more.
    e30cabrio and Mdl like this.
  19. Dec 30, 2024 at 3:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    So much confusion.
    Scol 7oz
    Jon Bond 5.1 oz
    Toyota 205 ml =7.2 oz
    So I guess the bottle I got is correct and my math conversion sucks as 205ml is not 8oz! Carry on!
  20. Dec 30, 2024 at 3:44 PM
    e30cabrio
    Right now I have 8, I'm going to remove 1.
  21. Dec 30, 2024 at 3:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Was the bottle 205ml?
  22. Dec 30, 2024 at 3:47 PM
    e30cabrio
    8oz, it was the JB kit you linked.
    The Google says it is 236.588ML
  23. Dec 30, 2024 at 3:48 PM
    Silver17
    Eastern PA
    I think 205mL and 7oz. Are used interchangeably for the simplicity of us likely not having a measuring device in mL and it’s pretty damn close. Let’s be real, it won’t blow apart over an ounce, or fraction of one lol.
  24. Dec 30, 2024 at 3:49 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Guess it must be easier to have 8oz bottles. I went by the kit instructions of putting entire bottle in...
  25. Dec 30, 2024 at 3:50 PM
    e30cabrio
    I'll take out 1 oz if it blows up, I'll get a Uber pass & stop messing with cars.
    lol
    Land Bruiser and Mdl like this.
  26. Dec 30, 2024 at 3:51 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Very true. But I don't want to state/show document something and then have someone have an issue later on.
  27. Dec 30, 2024 at 3:51 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sippy straw...
  28. Dec 30, 2024 at 3:56 PM
    Silver17
    Eastern PA
    It would be shitty of them to give you 8oz. If that’s exactly what it needs and not even a little extra. They really think we won’t spill a single drop? All the kits are 8oz cause I don't think any Eaton supercharger uses more than 7.4oz. so 8 covers all of them and they can stock and sell one kit.
    Mdl and e30cabrio like this.
  29. Dec 30, 2024 at 4:01 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Nice!!...I'm a new member in Texas,Katy Texas to be exact.
    You anywhere close to my neck of the Woods?
  30. Dec 30, 2024 at 4:20 PM
    koditten
    Kirk
    Midland of the Mitten
    Oz's and mL's are different units.
    One is weight the other is volume.
    Nice of them to confuse the amount even more.
