Powdercoat sway bar ideas
Discussion in '2.5 Gen Tundras (2014-2021)' started by Moss01, Sep 12, 2017.
  1. Sep 12, 2017 at 8:29 AM
    Moss01
    Moss01 [OP] New Member
    17 Crewmax SR5 MGM
    Pavement princess here.... so ive had my trd sway bar sitting in a box since i bought my truck. Im extra and not a fan of the red so i will be powdercoating it a different color before install along with the calipers. So just looking for inspiration and color ideas. Any pics would help. I have a MGM CM.
  2. Sep 12, 2017 at 8:31 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Are you looking for some bling? If not just go with black. I spray painted mine black because I wasn't feeling the red either.
    tomsinamerica and GNTundra like this.
  3. Sep 12, 2017 at 8:35 AM
    Moss01
    17 Crewmax SR5 MGM
    Nothing too fancy but i want it to pop out just a little more. Im leaning towards a blue or a yellow. Just need to look into colors a bit more.
  4. Sep 12, 2017 at 8:37 AM
  5. Sep 12, 2017 at 8:39 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Bright orange or lime green
    Pudge likes this.
  6. Sep 12, 2017 at 8:42 AM
    Let's see your ride...
    Moss01[QUOTED][OP] likes this.
  7. Sep 12, 2017 at 8:44 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    personally, i have no idea why sway bars should "pop"... it is just a sway bar. Always thought it was weird that toyota made it red. It's like painting mudguards red to me.... Same thing with calipers, unless they're Brembo and even then, I'd take some black brembos over red. just my opinion
    :crapstorm:
    Patriot, Moss01[OP] and GNTundra like this.
  8. Sep 12, 2017 at 8:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Chrome.....;)
  9. Sep 12, 2017 at 8:54 AM
    Moss01
    17 Crewmax SR5 MGM
    Havent got serious into the build yet but so far just magnum steps and swapped my grill from chrome to a full colormatched platinum grill.. next will be a small lift and retrofit or maybe the 18 LED headlights. Oh and the truck is dap tuned.
    GNTundra likes this.
  10. Sep 12, 2017 at 8:55 AM
    Moss01
    17 Crewmax SR5 MGM
    I understand bro... like i said im just extra lol
  11. Sep 12, 2017 at 8:58 AM
    tomsinamerica
    Tom
    Wilmington, NC
    with a truck that pretty... I'd paint it MGM to match... subtle but cool.
    Other than that... chrome with sparkles.
    joonbug and Moss01[QUOTED][OP] like this.
  12. Sep 12, 2017 at 9:05 AM
    Tundra Fan
    Toby
    Nooooo.....
  13. Sep 12, 2017 at 9:19 AM
    showtime240
    showtime240 New Member
    I powdered mine white
  14. Sep 12, 2017 at 9:20 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    You can powder coat the swaybar another color if you want. Pending the color choice you select you most likely will need to have it sandblasted then re-powder coated. The two end links have rubber grommets that are a little tricky to remove. I would suggest using a little wd40 or something to help slip them out. If your handy I would remove the grommets yourself and bring the the two end links and bar to the powder coat shop. If you want to order a special color look at prismatic powders for color options. They're a lot of choices! If you plan to do a 6" lift or bigger then I would also suggest having the end links extended before you powder coat. If your only doing stock or a 3/1 lift you can leave the end links stock. Ekstrom design or coachbuilder will weld and extend the links for $75. Here is a photo of my rear swaybar. IMG_1842.jpgIMG_4524.jpg
  15. Sep 12, 2017 at 9:33 AM
    Moss01
    17 Crewmax SR5 MGM
    Perfect. This is exactly what i was looking for. Thanks!
    1UPPER[QUOTED] likes this.
  16. Oct 9, 2017 at 7:09 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Help me understand why a sway bar is recommended...
    My MGM 2014 SR5 TRD double cab is my DD. I don't notice much lean or roll on corners / ramps, etc.
    Does the sway bar help more when carrying a heavy load in the bed or trailering...or is it 6 to 1/2-dozen of the other.
    Ty
  17. Oct 9, 2017 at 7:25 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Adding a rear sway bar helps prevent body roll. By increasing the stiffness of the truck with a front and rear sway bar you can help to decrease oversteer in a corner. If you plan to off-road and want more articulation then you may not want a rear sway bar.
    Moss01[OP] likes this.
  18. Oct 9, 2017 at 9:39 AM
    Masshole
    New England
    1UPPER likes this.
  19. Oct 9, 2017 at 12:54 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    If it were me I would powder coat the same color as my aftermarket coils..just another idea. I have 700# red TT coils, so when if I add the red sway bar it works for a color match.
    NewImprovedRon and Coolhardy like this.
  20. Oct 9, 2017 at 3:18 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
