Test drove a GMC Sierra 1500 Elevation (heated steering wheel)
Discussion in '2.5 Gen Tundras (2014-2021)' started by JC21Tundra, Nov 2, 2024.
  1. Dec 25, 2024 at 6:06 AM
    #91
    woods
    woods New Member
    2021 SR5 TRD Sport
    Hey Guys,
    I opened the wheel this morning as a gift to myself. I don't see any sort of spring in the box. @RainMan_PNW do you have a photo of what things should look like? I've never messed with a wheel before and not sure what it even should include.
    Thanks and Merry Christmas.
    Rdrcr likes this.
  2. Dec 25, 2024 at 6:59 AM
    #92
    JC21Tundra
    JC21Tundra [OP] If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    see picture #3 in the first post, it is wrapped in bubble wrap in the center of the steering wheel, you cannot miss it, if you did not get that maybe you did not order the heated version, or there was a picking error at the warehouse.
    clock spring on the left, wire harness on the right
    woods[QUOTED], Rdrcr and bulldog93 like this.
  3. Dec 25, 2024 at 7:04 AM
    #93
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Been a bit busy - they did reply and sent a link to this video, which is basically instructions for centering the clock spring.
    https://www.youtube.com/shorts/gCig3m_0IX0
    I'm hoping to get mine installed here a little later this morning finally.
    woods, Rdrcr, bulldog93 and 1 other person like this.
  4. Dec 25, 2024 at 7:55 AM
    #94
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Man, you've been lucky that it didn't deploy right in your face. Never do this, never. Any time you mess with airbag please do disconnect the battery and wait for good 10-15 minutes for all capacitors to die out.
    bulldog93 and Rdrcr[QUOTED] like this.
  5. Dec 25, 2024 at 7:58 AM
    #95
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Any idea if this fits Gen 2? The only thing wife misses in her Sequoia is a heated steering wheel.
    The steering wheel controls are 1 to 1 like in my 2019 Tundra. I guess, it may work? See no reason for Toyota using another kind of connector or different pinout.
    bulldog93 and woods like this.
  6. Dec 25, 2024 at 8:25 AM
    #96
    RainMan_PNW
    Casey
    Clark County, WA
    I would recommend you hit the EWD thread in my signature, grab the different wiring diagrams, and compare the pin-outs and connector shapes.
    I will tell you for starters that the shape of the wheel and the airbag is completely different between Gen 2 and Gen 2.5.
  7. Dec 25, 2024 at 8:35 AM
    #97
    RobertD
    Robert
    DFW, Texas
  8. Dec 25, 2024 at 9:12 AM
    #98
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Nah, late Sequoias steering wheels are like in gen 2.5 Tundra:
  9. Dec 25, 2024 at 9:16 AM
    #99
    RobertD
    Robert
    DFW, Texas
    Oh! Asking about a Gen 2 Sequoia. Did not get that at all
    Ignore my above post. Definitely looks like its the same wheel that the 2.5 gen Tundra uses but you would still want to check the wiring diagram for the pin map yo verify their harness is set up the same.
  10. Dec 25, 2024 at 9:24 AM
    #100
    woods
    woods New Member
    2021 SR5 TRD Sport
    Thank you! I do have the spring then. Like I said, never done this and I was looking for a literal metal spring. :monocle:
    Appreciate all you guys and your help!
  11. Dec 25, 2024 at 9:35 AM
    #101
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    My heated wheel got stuck in customs Monday, so who knows when that bad boy will be here. Been in transit for 22 days.
  12. Dec 25, 2024 at 12:27 PM
    #102
    RainMan_PNW
    Casey
    Clark County, WA
    Gotcha - missed the Sequioa part.
    Then I'd recommend comparing the EWD for the particular year of Sequoia to the Tundra just to be sure. There's a surprising number of differences actually.
    RobertD likes this.
  13. Dec 25, 2024 at 12:28 PM
    #103
    RainMan_PNW
    Casey
    Clark County, WA
    mine was close to a month as well.
  14. Dec 26, 2024 at 8:33 PM
    #104
    RainMan_PNW
    Casey
    Clark County, WA
  15. Jan 5, 2025 at 12:48 PM
    #105
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Got mine installed today, I used the spot where the auto high beams are for the heated switch. I never use that button so made sense for me. IMG_0425.jpg IMG_0421.jpg
  16. Jan 5, 2025 at 1:25 PM
    #106
    woods
    woods New Member
    2021 SR5 TRD Sport
    did you just leave the auto high beam switch behind the dash?
  17. Jan 5, 2025 at 1:28 PM
    #107
    Abell207
    Abell207 New Member
    Anthony
    Maine
  18. Jan 6, 2025 at 9:17 AM
    #108
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Got my steering wheel kit today. Opened the box and my clock spring clip was not attached. I watched the video and got it centered. I used some tape and the clip so it wont move. Hopefully when it warms up again I can get it installed.
  19. Jan 12, 2025 at 9:29 AM
    #109
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Got mine installed today. Man was I nervous messing with the clock spring! Got it done and it works! IMG_0317.jpg IMG_0318.jpg
  20. Jan 12, 2025 at 9:36 AM
    #110
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Did you also put your auto high beam behind the dash?
    Rdrcr and woods like this.
  21. Jan 12, 2025 at 9:49 AM
    #111
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Yes i did. Seemed the easiest way to find a spot for the switch.
  22. Jan 12, 2025 at 6:23 PM
    #112
    RainMan_PNW
    Casey
    Clark County, WA
    Could always move the window switch to the center console…
    :D
  23. May 21, 2025 at 2:21 AM
    #113
    woods
    woods New Member
    2021 SR5 TRD Sport
    So I got mine installed yesterday. Wheel is great, and very happy with it. The issue is, now all my electronics sensors are screaming. Basically every single sensor is saying its not working or needing to be calibrated. Has this happened to any of you? I have an appointment early next week to try to get everything reset from someone with the right scan tool programing, but just trying to get an idea of where things went wrong.
    Abell207 likes this.
  24. May 21, 2025 at 2:35 AM
    #114
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I did not have this issue. Hopefully it’s an easy fix.
  25. May 21, 2025 at 3:08 AM
    #115
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    I've looked at this hard, but wasn't sure about ordering..
  26. May 21, 2025 at 3:09 AM
    #116
    woods
    woods New Member
    2021 SR5 TRD Sport
    fingers crossed :fingerscrossed: From what I understand, it can be recalibrated, but I hadn't seen anyone else with this issue on here so I am just trying to get an idea if anyone ran into this.
    Rdrcr likes this.
  27. May 21, 2025 at 3:10 AM
    #117
    Abell207
    Abell207 New Member
    Anthony
    Maine
    All your steering controls work correct? I’m guessing if they do then it’s probably the steering/angle sensor that’s throwing all the codes.
    Rdrcr and woods[QUOTED] like this.
  28. May 21, 2025 at 3:14 AM
    #118
    woods
    woods New Member
    2021 SR5 TRD Sport
    That's what the guy who put it in said, he didn't have the option to calibrate it on his scan tool, he mostly does Ford stuff, so I am guessing he didn't have the most up to date toyota stuff. He said it was probably related to the clock spring, I just don't have good enough understanding of the issue to use all the correct lingo and words. The shop I take it to for normal service, said they can handle it.
    The wheel is a huge upgrade imo, so worth the little bit of hassle if that's all it is.
    Rdrcr likes this.
  29. May 21, 2025 at 7:39 AM
    #119
    Rdrcr
    Rdrcr New Member
    2019 Toyota Tundra TRD Sport
    I will say I was extremely careful with the removal and installation of all components being especially mindful of the electronics while installing my steering wheel. I didn’t experience this issue and no problems since. The heated steering wheel has been a worthwhile upgrade.
    I wish I could help more.
    woods likes this.
  30. May 21, 2025 at 9:26 AM
    #120
    woods
    woods New Member
    2021 SR5 TRD Sport
    I might have even shook it around before hand looking at things. I honestly don't know. Sounds like I am the only one who experienced this though, so I'll make sure to update what they do to get it all fixed. Might be helpful to someone in the future.
    Rdrcr[QUOTED] likes this.
