Offroad jack
Discussion in '1st Gen Tundras (2000-2006)' started by ProfJ, Dec 23, 2024.
  1. Dec 23, 2024 at 4:01 PM
    ProfJ
    ProfJ [OP] New Member
    2006 TRD V8 AC 4x4
    Hi Folks,
    What jack do you carry in your Tundra? Currently I only have the little OEM bottle jack under the back seat, which I guess might work on pavement under ideal conditions. I don't see any good points to apply a high lift jack to the front tire area in an offroad situation. Some kind of 20" scissor or bottle jack might work?
    Cheers
    Jon
  2. Dec 23, 2024 at 4:02 PM
    Badland 3 ton from HF.
  3. Dec 23, 2024 at 4:03 PM
    And a back brace
  4. Dec 23, 2024 at 4:05 PM
    Tundra family
    Tundra family New Member
    Stock jack sucks on stock hight trucks, if you get a flat up front the stupid thing is too tall to get under the control arm, and almost too short to use on the frame. Someone seriously dropped the ball there.
    ProfJ[OP] and Mdl like this.
  5. Dec 23, 2024 at 4:13 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Lol true. My ProEagle Kratos is crazy heavy but it’s sturdy.
    I have a 6 ton bottle jack in my truck. Need to grab a piece or two of 4x4.
    Mdl likes this.
  6. Dec 23, 2024 at 4:16 PM
    After having a 2t aluminum jack fold on me in the dirt, I don’t mind the extra weight in exchange for safety and stability
  7. Dec 23, 2024 at 4:17 PM
    Tundra family
    That is terrifying :eek2:
  8. Dec 23, 2024 at 4:18 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have a 3 ton bottle jack in all of my rigs. And a collection of 16" pieces of 2x6 and 1x6 to gain height advantage if needed or find myself in soft ground. Small piece of 2 1/4" oak wood flooring to go between the frame and the bottle jack top.
    Full disclosure: I also keep a 1/2" breaker bar, 6" extension and deep well socket in each rig. And make sure all wheel lugs are torqued to NO MORE than 84 lb-ft.
    Most importantly: REHEARSE. In your driveway. Needing to change a wheel & tire out on the road, or off road, is NOT the time to try and learn how to make it all happen.
  9. Dec 23, 2024 at 4:21 PM
    No one was hurt, the “royal” me
    The Black Mamba likes this.
  10. Dec 23, 2024 at 4:26 PM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    An OJ? Not yet.
  11. Dec 23, 2024 at 4:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    2.5 ton aluminum jack in a pelican case
  12. Dec 23, 2024 at 4:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Stock bottle jack and a 4x4
  13. Dec 23, 2024 at 4:50 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    This seems like a good idea. I'd add a board to fit under the jack, inletted for the wheels, so the ground pressure is reduced for when on soft/wet ground.
    I currently have a 2 ton trolley jack in my truck on such a board. I keep a large number of 4x4 and 2x4 pieces in my truck for when I need to jack something and block it up (which I have used for others when I stop and help strangers with flats).
  14. Dec 23, 2024 at 4:53 PM
    Jack points are designated by the manufacturer to either be under the rear axle or under the boxed portion of the frame in front of the door. It’s in the owner’s manual.
    Bought2Pull and FrenchToasty like this.
  15. Dec 23, 2024 at 5:00 PM
  16. Dec 23, 2024 at 5:16 PM
    ProfJ
    2006 TRD V8 AC 4x4
    Damn right, build a 4x4 truck and then supply an OEM jack I wouldn't use on a corolla
  17. Dec 23, 2024 at 5:25 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Jack for what? Changing a flat, or something else? For changing flats, I've done my share, exclusively on dirt roads, with the OEM bottle jack. Never had a problem. When I'm home I rotate my tires using a floor jack. But otherwise I've never changed a truck tire on pavement. I now also carry a square of glued & screwed-together 2x6s that give me about a 6"x6" square, 4" high platform. Used to be what I'd use under my trailer tongue jack. But I changed a lot of flat tires off road without it.
    Under the leaf spring perch in the back, under a control arm in the front. I don't have problems getting it under the control arm on my stock height truck.
    des2mtn and Jack McCarthy like this.
  18. Dec 23, 2024 at 5:34 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ve got a skid for it
  19. Dec 23, 2024 at 5:40 PM
    ProfJ[OP], Tundra family and PNW15 like this.
  20. Dec 23, 2024 at 8:52 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Stock jack with 2 pcs of 4x6 wood
    Cthulhu, The Black Mamba and des2mtn like this.
  21. Dec 24, 2024 at 2:38 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Gas can only goes on long trips. Jack stays
    jerryallday and FrenchToasty like this.
  22. Dec 24, 2024 at 8:41 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I really don't understand the people that say the OEM jack is terrible. It lifts up the vehicle and it is mechanical rather than hydraulic, one less thing to fail. If you have bigger tires, use it with a 4x4 block for the increased height and stability.
    I mainly use a 6-ton bottle jack these days, but I got by plenty with the stock jack and still use the stock jack to supplement the hydraulic jack for field repairs. If you're off-roading in the right surface, you can also dig under the tire instead of jacking the truck up as high.
    FiatRunner, snivilous, Mater and 4 others like this.
  23. Dec 24, 2024 at 10:54 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  24. Dec 24, 2024 at 12:08 PM
    My truck wouldn't be lifted today were it not for the OEM jack! Great, functional piece of equipment, and with plenty of adapters (aftermarket) to work with it.
  25. Dec 24, 2024 at 12:13 PM
    Tell us more about these adapters. Anything with better biting power or grip? I was always concerned the rear axle might slip off the jack on a non-level surface.
  26. Dec 24, 2024 at 12:19 PM
  27. Dec 24, 2024 at 12:37 PM
    Cthulhu
    Yep…
    Mater, RobertD, Nicklovin and 2 others like this.
  28. Dec 24, 2024 at 12:55 PM
    I'd feel better about using that if the footprint was plus-shaped so it can't rock back/forth. Maybe take a 4x4 and cut to height, then bolt to the 2-by stack you have there?
  29. Dec 24, 2024 at 1:16 PM
    Cthulhu
    Yes I definitely am mindful of the position when I situate it when changing a tire at home or offroad. I store the block at the bottom of my Swingcase so it fits perfectly, but I like your idea for better stability. :thumbsup:
  30. Dec 24, 2024 at 2:02 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    And how about those vintage Craftsman acetate handled screwdrivers on the wall. Bought my first set in 1983.
    Cthulhu[QUOTED] likes this.
