Radio headunit- headlight trigger question
Discussion in 'Audio & Video' started by ps8820, Dec 19, 2024.
  1. Dec 19, 2024 at 5:27 PM
    ps8820
    ps8820 [OP] New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    Still looking for a heaunit that lets me choose when to change display Brightness; dont want to be required to use a headlight trigger.
    Can I rig my own trigger circuit switch [instead of headlights]?
  2. Dec 20, 2024 at 8:16 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Pretty much any aftermarket headunit these days has its own brightness control built into the unit.
  3. Dec 20, 2024 at 8:48 AM
    Snert
    Snert New Member
    2021 SR5
    As far as a switch to trigger the dimmer I'm sure someone smarter than I could figure out how to rig one up, in theory it'd just be putting a switch on whatever wire goes between the headlight switch and the radio dimmer trigger, but idk that might be done via canbus or something not as simple as just a wire. As far as head units go, I think most have the ability to turn on/off the dimmer in the settings. I was just looking at the new Alpine iLX-W770 and it has that ability. Briefly looked at the manuals of a couple others, the Kenwood DMX709S and the Sony XAV-AX3700 and both have the ability as well. Best bet is to go on Crutchfield, pull up the head units page, open the manual, and do a Ctrl + F for "dim" and see what settings the head unit has.
  4. Dec 21, 2024 at 12:41 AM
    ps8820
    joe
    thx @frichco228 & @Snert.
    I should have noted the reason i prefer to enable/disable Bright/Dim from a separate switch is that I dont think hunting thru 2-3 menus to adjust the display as Im driving is either safe or convenient. I don't like the headlight switch trigger either, since on fog/snow days, headlights are mandatory on most fed & state hwys and thus renders a DIM display on an otherwise bright day. As well, there are those times at nignt when you pull Into a brightly lit mall or gas station and you'll need to turn lights off to brighten display...
    So, the idea of a "ME" control switch [anywhere convenient] to DIM/BRIGHT the display when I want it.
    I see that the Alpine ilx407, 507 button panels have an ambient 'light sensor', which I guess might be the best built-in solution but it remains to be seen how well that performs.
    The only other solution would be if the industry would create an assingnable shortcut key that would step thru Brightness levels via a 'Long Press' button and subsequent presses to achieve display preference.
    [tongue-in-cheek]:
    But! ...and this is a really BIG BUT, that would mean the industry would have to trust USER judgement of 'what is a suitable display brightness for the current conditions?'
    "...Im afraid I cant do that Dave."..."this mission is too important for me to allow you to make that change currently. Please manipulate the parking brake first."
    Snert likes this.
  5. Dec 23, 2024 at 7:27 AM
    Snert
    Snert New Member
    2021 SR5
    Just a thought, but I wonder if you called iDatalink if that's something that could be programmed to one of the steering wheel buttons.
  6. Dec 23, 2024 at 10:59 AM
    ps8820
    joe
    would be nice and would be a big feature around here, but...i dont have SWC.
  7. Dec 23, 2024 at 11:06 AM
    ps8820
    joe
    Hip-shot: seems to me the headlight trigger wire of a given HU operates on sensing an energized circuit [not sure, but likely electronically]. So one way or the other, would appear a simple 'in-line SPST' [between HL wire & HU trigger wire] might do it?
