2003 ac 2wd ,my manual says type +4 trans fluid,dealer says dex ,now what?
Discussion in '1st Gen Tundras (2000-2006)' started by Mark4x2, Dec 21, 2024.
  1. Dec 21, 2024 at 9:02 AM
    Mark4x2
    Mark4x2 [OP] New Member
    Ohio
    2003 AC stepside 4x2,2021 SR5 Crewmax 4x2
    whats a person to do ,want to drain and fill,129K on OD, fluid is still red/pink????
  2. Dec 21, 2024 at 9:17 AM
    Mark4x2
    Ohio
    type T-4, or dex that is the Q???forgot dealer did a trans flush arround 60K,, previous owner,,, wonder what fluid that dealer used?
  3. Dec 21, 2024 at 9:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  4. Dec 21, 2024 at 10:23 AM
    Bookmark this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    One of many bits of info in there, note red text:
    After you buy the truck (or sometimes before)
    • Register for an account at the Toyota Owner's website: https://www.toyota.com/owners
    • Plug your VIN number in and assign it to your account so you can check for open recalls, register yourself as the person to call/email in the event of a recall, and see any dealer-performed service history, including any frame inspections, recall work, regular maintenance, etc. This could give you a good idea of what the truck's had done already, where it lived, how regular the maintenance may've been.
    • Start to get a baseline on critical 1st-Gen-Killer maintenance items that needed to be done: Timing belt/water pump/pulleys/tensioner. Radiator. OEM lower ball joints. Fluids: Differential(s), oil, power steering which takes ATF, brake, pink long life coolant, drain and fill transmission with correct fluid for your year (2000-02 takes DEXIII, 2003-04 takes Type T-IV, 2005-06 takes Type WS). Filters - you DO NOT need to replace transmission filter! For all other filters, stick with OEM, Toyota has specifically lenient flow characteristics that mate perfectly with their vehicles: Oil, air, and for 2000-2004 consider replacing with OEM fuel filter even though it's a PITFA. Check/replace plugs with the specific brand/model# printed in your owners manual.
  5. Dec 21, 2024 at 10:34 AM
    Mark4x2
    Ohio
    Thanks to all ,found receipt 4 trans flush,does not call out what type, just says Bulk fluid..........???
  6. Dec 21, 2024 at 10:47 AM
    If it was done at the dealer, they'd have run the VIN to confirm the fluid to use.
    It's when a chain store does work you really need to worry. It'd be really unusual for the dealer to make a fluid mistake.
  7. Dec 21, 2024 at 11:06 AM
    Mark4x2
    Ohio
    THANKS shifty!!!
  8. Dec 21, 2024 at 2:34 PM
    bfunke
    bfunke Tundra Curmudgeon
    I got the impression my local stealership was just using WS in everything. If you try to order the Toyota PN for Dex III, it can’t find any match. My understating is GM no longer licenses Dex III since they stopped using it in 2005. DEX-MERC is supposed to be the same fluid as Dex III. Dex VI definitely is lower viscosity.
  9. Dec 21, 2024 at 3:00 PM
    All Dex fluids are backwards-compatible by design. Higher number works fine with lower ordered designation, even if lower viscosity, the claim is, it functions fine and meets the minimum requirements of the lower rating. Do I believe it? “Meh”. I didn’t believe it when I first heard this but all the digging I did way back then confirmed it, back then at least.
