General Supercharger Thread
  1. Dec 20, 2024 at 11:49 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Was just going to say that should be your next item...
  2. Dec 20, 2024 at 12:43 PM
    ARES35
    ARES35 New member for life
    Mile high
    First thing first pinning the thermostat and getting to tuning! Hopefully @JustDSM can take a look at my calibration for transmission tables before I begin!
  3. Dec 20, 2024 at 12:52 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I’m waiting on hp tuners to help with those tables too. I have to submit a trouble ticket and they’re going to look at everything. I’ll submit this weekend now that I have my mpv3 back to be able to provide them the log data file and current read file of the truck.
    Interested to hear what you get back on your end.
    e30cabrio, Mdl and ARES35[QUOTED] like this.
  4. Dec 20, 2024 at 12:55 PM
    ARES35
    Mile high
    The more tables available the better!
    e30cabrio, Mdl and carn_dogg[QUOTED] like this.
  5. Dec 20, 2024 at 2:15 PM
    carn_dogg
    Pat
    Eastern Shore MD
    How did the pick up go?
    e30cabrio, ARES35[QUOTED] and Mdl like this.
  6. Dec 20, 2024 at 4:07 PM
    ARES35
    Mile high
    Smooth as butter! Pulled it into the garage, looked around and pinned the thermo right off the bat! The reman is shiny lol
    e30cabrio, HulkSmurf14, Mdl and 2 others like this.
  7. Dec 20, 2024 at 4:21 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Dude yes congrats. I had mine pinned but here in MD we do get 0-15 occasionally so might as well leave it. I’ll pin in the spring to keep trans temps down towing from APR to NOV. New VB here you come lol
  8. Dec 20, 2024 at 4:22 PM
    ARES35
    Mile high
    I'll monitor trans temp. Now need to get the gears, LSD and VB going asap!
    e30cabrio, HulkSmurf14 and Mdl like this.
  9. Dec 20, 2024 at 4:28 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Money, Money, Money.
    Can't remember what everyone did - are you going 5.29 with speedmaster?
  10. Dec 20, 2024 at 4:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe there were 5 of us including ares35 that grabbed the speedmaster that I know of. The sales woman I spoke to said there were a bunch sold.
    e30cabrio and ARES35 like this.
  11. Dec 20, 2024 at 5:00 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Right on. He will probably have his gears and LSD in before me lol. Still torn on doing it 1 stage at a time, or just doing both at the same time. I'm not 100% convinced on 5.29. I def think stock 4.3 is not ideal, but with SC you don't notice. 4.88 (in my head) makes more sense, but them I'm like hmm well if I'm going to regear, then I may as well do 5.29.
  12. Dec 20, 2024 at 5:21 PM
    ARES35
    Mile high
    Yes sir the motive and speedmaster setup. Went 5.29 with my 35s, believe this should be a good combination especially towing in the rockies.
    e30cabrio, carn_dogg[QUOTED] and Mdl like this.
  13. Dec 20, 2024 at 5:21 PM
    ARES35
    Mile high
    What size tires you run?
  14. Dec 20, 2024 at 5:28 PM
    carn_dogg
    Pat
    Eastern Shore MD
    315/70 so about 34.5
    Chose those because they're the ford racing developed ko2 for the raptor. Load C. So damn smooth. Much smoother than my old 35/12.5r17 ko2 load E.
  15. Dec 20, 2024 at 5:40 PM
    ARES35
    Mile high
    I run toyo at3 35x11.5 r20 pizza cutters because of body mounts back in the day. Probably go back to a 12.5 now that I've chopped all mounts. Both these size tires are heavy as shit......transmission sweats everytime going over Loveland pass with a trailer and gear lol
    e30cabrio and Mdl like this.
  16. Dec 20, 2024 at 6:33 PM
    koditten
    Kirk
    Midland of the Mitten
    Curious:
    All this talk about 5.29 rear gears:
    This can not actually work while leaving the factory 4.3 gears in the front?
    I've actually ran a size different tires in the front vs the rear. The wheel speed sensors did not like that at all!
    Switching to 4hi or out of 4 hi was not remotely smooth.
    I just can't imagine how much the 4 wheel drive ECU would complain and trip lots of dash lights.
    Please enlighten me.
    ARES35, e30cabrio and Mdl like this.
  17. Dec 20, 2024 at 6:41 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You will need the same ratio in the front, or the wheel speeds will differ and cause error codes.
    ARES35, e30cabrio, Mdl and 3 others like this.
  18. Dec 20, 2024 at 6:50 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah you need to do none or both. Unless you want to do rear only and never use 4wd
  19. Dec 20, 2024 at 6:53 PM
    koditten
    Kirk
    This was my assumption. Just never saw it specified.
    Anyone who wants to regear a 4wd needs to multiply the cost 2x.
  20. Dec 20, 2024 at 7:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Like me...hope to tackle the fronts soon. Either remove front drive shaft or big sticky that says: No 4wd, do not engage!...
    :fingerscrossed:
  21. Dec 20, 2024 at 7:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Those aren't too bad. I'm running 35x11.8r20 and got a spare set of mt's in 35x12.5r20.
    e30cabrio and ARES35[QUOTED] like this.
  22. Dec 20, 2024 at 7:37 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    pinned mine before heading out of state and my converter still got crazy high temp. pan temps didnt stay as low as some of yalls
    ARES35 and bflooks like this.
  23. Dec 20, 2024 at 7:56 PM
    carn_dogg
    Pat
    Eastern Shore MD
    What temp did you see?
    ARES35 likes this.
  24. Dec 20, 2024 at 8:00 PM
    ARES35
    Mile high
    Seeing over 200 degrees? What was your convertor temp?
  25. Dec 20, 2024 at 8:13 PM
    NatesNightMare
    Pinetop Az
    @carn_dogg @ARES35 converter temp got over 200
    pan temp i think would get close to 200.next time ill have to take a SS. but its def when the converter is unlocked
    ARES35 likes this.
  26. Dec 20, 2024 at 8:16 PM
    ARES35
    Mile high
    Thus the reason to pin. Wonder what you would have been unpinned, probably over 225 at least
    helidave likes this.
  27. Dec 20, 2024 at 8:20 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    one of the best things you can do to keep trans temps low is tune it to lock the converter as much as possible in 4th-6th. it generates a ton of heat when unlocked
  28. Dec 20, 2024 at 8:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    This! You can setup tow/haul for towing with better shifts and lower lockups than what they have pre-programmed.
    ARES35 and helidave[QUOTED] like this.
  29. Dec 20, 2024 at 10:17 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Most of you guys running 35s, do you mostly run them for looks or do you really need the functionality? Genuinely curious. I have 33.5s on mine, load E, and I really dislike the reduction in ride quality and power and fuel economy lol. I decided I really have no use for the oversize tires other than looks, so I'm going to be going back to a stock size and lowering the rear. Just wanna try it and kinda be a little different than most.
    ARES35 likes this.
  30. Dec 20, 2024 at 11:06 PM
    blenton
    blenton New Member
    I am in the same boat as you. I love the look of 35's but haven't found a need for them with how I use my truck. I ran 33's once, and am now on 32.5" tires (long story) but have run five other sets of stock 32" tires. The truck has done everything I've asked it to, including plowing through snow up to the doors and dragging the underbelly on muddy two track. Heck, look at what was packed in my spare this week from 200 miles of unplowed blizzard roads! Doesn't mean I don't appreciate or want 35's though... it just doesn't make sense for me.
    j_supra[QUOTED] likes this.
