Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Dec 11, 2024 at 8:51 PM
    #271
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Maybe they will. I looked at the pictures again. I just couldn't tell when I first looked. I know our years are a bit different there
  2. Dec 11, 2024 at 9:49 PM
    #272
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yours being a DC is likely the difference.
    I'm pretty sure my 2wd 03 and 4wd 06 are identical up front there
    Weagle[QUOTED] likes this.
  3. Dec 12, 2024 at 8:39 AM
    #273
    Weagle
    Prattville, AL
    Yeah, I looked this morning in the daylight and they will fit. Mine is definitely different and would not require the skid plate modification
    Not sure they will be visible. I believe the frame where mine are mounted is higher. Believe I'll still add them
  4. Dec 12, 2024 at 2:04 PM
    #274
    KNABORES [OP] Sarcasm incoming
    just have to trim the skid plate ear a little to fit these
  5. Dec 12, 2024 at 2:39 PM
    #275
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Dangit guys, now you're making me feel like I need to throw on some tow hooks. Because, you know.
  6. Dec 18, 2024 at 11:01 AM
    #276
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Group: What have you done to your 1st Gen Tunda today?
    Me: Everything @KNABORES has done :D
  7. Dec 19, 2024 at 7:58 AM
    #277
    After much deliberation as to where to mount my 20" lightbar, I've decided that it looks best........ nowhere on my truck. Going the ditch lights route instead. Ordered some Tacoma hood brackets and some three row compact 3" lights to mount on them. Had good luck and performance out of my 20" Nilight LED 3 row bar, so gonna try the pod lights of the same design.
    Weagle, 455h0le_dachshund and BroHon like this.
  8. Dec 19, 2024 at 2:01 PM
    #278
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So what you gonna do with that light bar?
    I'm thinking mount it sideways over the 3rd brake light on your cap, facing back, slightly tilted down.
    Use it for backing up, for lighting when camping, and for blinding tailgaters
    Weagle and KNABORES[QUOTED][OP] like this.
  9. Dec 20, 2024 at 12:51 PM
    #279
    Got under the truck and cleaned up all of the trailer harness wiring. It was a mess. Hooked up the new 7 pin in the bumper. Attached the 4 flat under the bumper stealth mode. Scrapped the old 7 pin that was hanging down and had the 4 flat tied around it. Also fixed my backup camera so it actually activated with reverse instead of just popping up every time I start the truck. Looks cleaner and feels good to have the rats nest gone.
    Tlar25, bmf4069, BroHon and 4 others like this.
  10. Dec 22, 2024 at 1:20 PM
    #280
    Couple things came in today.
    ditch light brackets. These are listed for Tacomas of the 05+ vintage, but they will work with some mild modification. Widen the mounting holes slightly and bend some of the angles to match the lines. Clears the windshield as is now.
    also my BOLT hitch lock that is keyed to the trucks ignition key. Loved this on my other truck, handy.
    Tlar25, bmf4069, BroHon and 5 others like this.
  11. Dec 22, 2024 at 6:36 PM
    #281
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Cute shackles
    KNABORES[QUOTED][OP] likes this.
  12. Dec 22, 2024 at 8:02 PM
    #282
    ún bébé
  13. Dec 23, 2024 at 6:40 AM
    #283
    Weagle
    Prattville, AL
    just to confirm, my 06 is the same as yours. I ordered the wrong ones - mine are black with red rubber instead of red with black rubber like yours, but still a good addition
    Edited to add that on my '06 DC I did not need to modify the skid plate
  14. Dec 23, 2024 at 6:43 AM
    #284
    Very nice sir
  15. Dec 23, 2024 at 6:47 AM
    #285
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Did you guys get these on the Rainforest? I see a cheaper set for 65 with the red shackles and then a Rough Country set for a little more.
    Tempted to copy this and pick up another hook like this from a junkyard.
  16. Dec 23, 2024 at 6:52 AM
    #286
    des2mtn[QUOTED] likes this.
  17. Jan 6, 2025 at 8:33 AM
    #287
    So ditch lights are wired up and aimed to be outside of the headlights reach. With just ditch lights on they look ok. But with the headlights on, I can’t tell the ditch lights add anything really. My LED fogs do an amazing job of filling both ditches currently. Probably gonna switch to one of the dual projector amber style to lower the profile and up the light output. These are merely truck jewelry and aren’t adding anything function for me.
  18. Jan 6, 2025 at 1:40 PM
    #288
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    What fog light bulbs are you running? I'm thinking about fixing my fog lights soon.
  19. Jan 6, 2025 at 1:44 PM
    #289
    These LEDs from Rockauto I believe. They are crazy bright with amazing spread.
    FiatRunner[QUOTED] likes this.
  20. Jan 6, 2025 at 5:38 PM
    #290
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Point em out to the sides a little more.
    Also you wanna wire mine next? :rofl:
    No pics?
  21. Jan 7, 2025 at 4:27 AM
    #291
    Pics
    Installed
    Ditchies
    Headlights and foggers
    all on
    Weagle, Bmktw2, bmf4069 and 3 others like this.
  22. Jan 7, 2025 at 4:43 AM
    #292
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why does it look brighter with headlights and fogs vs all on?
    BroHon likes this.
  23. Jan 7, 2025 at 4:50 AM
    #293
    Probably just the camera adjusting. In real life it looks the same. No difference when the ditchies are on. To be fair, I did not point them way out to the sides. And I really don’t need ditch light fill to improve my lighting, I really need more mid range and distance fill in dark rural driving. So it’s not the lights fault, I’m just looking for something different. Some of these may do the trick
    https://www.amazon.com/dp/B0BNQ3BBBB
  24. Jan 7, 2025 at 4:52 AM
    #294
    I’ve had a 20” lightbar spot / flood combo on the bull bar I had for years and that thing really lit the way when needed. Don’t have anywhere I want to mount a big light bar anymore.
    BroHon and 455h0le_dachshund like this.
  25. Jan 7, 2025 at 5:05 AM
    #295
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Looks so much better w/o that bullbar... I don't like how those look at all for some reason. Your neighbor has quite a collection of big equipment. Isn't that like a 5ton military truck?
  26. Jan 7, 2025 at 5:49 AM
    #296
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You have a big wide cutout in that front bumper just waiting for a light bar.
    bmf4069, 455h0le_dachshund and BroHon like this.
  27. Jan 7, 2025 at 5:51 AM
    #297
    You should wrap your hood and roof. It would make your truck look 5 years newer without costing a lot.
    shifty` likes this.
  28. Jan 7, 2025 at 6:05 AM
    #298
    shifty` You can call 1 (800) PP5-1-DooDoo
    Black matte or eggshell vinyl or carbon fiber vinyl would probably look great if done between the roof mount rails, down the hood, and the brow. Maybe the painted section above the bumper flare. Would give it a super-modern sport "built" look.
  29. Jan 7, 2025 at 6:16 AM
    #299
    Or even color matched vinyl. Bottom line, the truck is too nice to have that much clear coat failure visible.
    KNABORES[OP] likes this.
  30. Jan 7, 2025 at 6:44 AM
    #300
    He does. Several deuce and a half’s and a 5 ton
