Front Proximity Sensors
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dag93, Dec 17, 2024.
  1. Dec 17, 2024 at 11:47 AM
    Dag93
    Dag93 [OP] New Member
    21 Tundra SR5
    Hey everyone, not sure if this is posted somewhere so I apologize if it is.
    I’ve had my tundra for about 2 months now and it’s the first vehicle that I’ve ever had (almost) all around proximity sensors on. The reason I say almost is I noticed I do not get alerts for things directly in front of me and only on the sides. It would be a nice to have in tight spots or parking garages. Does anyone know what’s up with this? Do I have them and they are broken? Can I add them? Is it a setting? Thanks for the help!
  2. Dec 17, 2024 at 11:53 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    You can see the sensors on the bumper end caps, rather off to the side. So they pick up things in front of them. For instance, a pole directly in the center of the bumper will not be seen by the sensor.
    Yours are working as designed.
  3. Dec 17, 2024 at 12:05 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I have one sensor front left that hasnt worked "correctly" since day one. Even the dealership couldnt find any issue or the dreaded "Cant duplicate" response.
    Sitting in the open, nothing around and its chirping like crazy. Soon as i drive off, it stops. Seems like a loose wire maybe, i dont know.
    Does however work when im pulling in or out of tight spaces, like the garage. I just turn them off. lol
    Tundra694 likes this.
  4. Dec 17, 2024 at 12:09 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Yep, they'd let you drive right into a brick wall if it's directly in front of you. :(
    Main reason I added the front cam when I upgraded the HU. Makes life SOO much easier.
    Tundra family likes this.
  5. Dec 17, 2024 at 12:40 PM
    Dag93
    21 Tundra SR5
    Got to love it!
  6. Dec 17, 2024 at 12:42 PM
    Dag93
    21 Tundra SR5
    How do you like the head unit and what year is your Tundra? I feel like there are to many settings linked to my head unit to remove it
  7. Dec 17, 2024 at 6:17 PM
    SD Surfer
    Bruce
    So Cal
    Love it!!
    I have a 2019.
    I think I lost a couple of the Entune settings that I didn't really use, and gained WAY MORE than I lost.
  8. Dec 19, 2024 at 10:55 AM
    Dag93
    21 Tundra SR5
    That’s an awesome unit, do you have the model number by chance?
  9. Dec 19, 2024 at 10:58 AM
    SD Surfer
    Bruce
    So Cal
    Yeah, I really like it.
    Kenwood DMX1057XR
  10. Dec 20, 2024 at 2:11 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    They get dirt in between the sensor and their housing. Sometimes if you just push on them and wiggle them a bit that’ll stop. Or you can remove the clip behind the bumper and just clean them. Mine still do that here and there too.
